Measure with a voltmeter the power of the airwaves and +\- power
- Леонардо-да-Винчи
In short something like that somewhere here saw, I did ask. Take container little I took the dropper 1 cm in length, filled it with water and salt, and put there 2 Mednis pins in my case, two copper wiring, has sealed ends to part the wires were in the flow, part of the Rouge. the ratio does not really matter. So then I was samarajiva etu H. If it is full the drip of reserves. Then gave the water to thaw in box new clean and without information. when thawed I AO measured resistance 13.34 Ohm. I have it was a zero. Vobshem then experimented(those who know water changes its molecular structure from the impact of any information, that's my say so is not contestable proof of the existence or magic well, it she says the work is just magic, watch the movie water who do not know)
vobshem went to the cemetery the resistance of polychaetes and Church resistance fall into place..
With experiment prishol to the conclusion that positive energy uluchshaet structure in any water of poor worsens.
Yes escho if you're not sure what source carries the negative protestthe a candle from an altar boy if it is negative it begins to tresat and smoke
If you decide to do this divays I want to give advice that water structured need some time, and preferably the capsule led on the source of radiation more cost effective and faster. my result came in 15-20 min. who cares waiting komentov
- Леонардо-да-Винчи
Re: Measure with a voltmeter the power of the airwaves and +\- power
escho top of these gizmos to prepare pobolee. for each measurement new I had 2 pieces. After working their cistel freezing. the water loses its properties and memory molecules Vratsa.
By the way can yo make experiment if you don't believe it's from the movie water. and it looks like the water after obrabotki.
Ah esperimento need microscop or moshiny umilitelny glass
I did take a drop of water put on a piece of glass somewhere with poppy seed pellet.
Dick nao mother on the bed in plasmaboy case, the current caution that the drop is not flowed. the bed in the freezer, take out of the freezer after 15 min - 1 hour. will smotrem the structure of snowflakes uzhos.
done, too, say the prayers we perform the aforementioned procedure and observe the beauty of snowflakes. the charging time of the water, I took 10 min.
This invaluable observation and experience. Thank you.
And the water temperature when this was measured? As far as I know when cooling (well, at least metals) the resistance decreases.vobshem went to the cemetery the resistance of polychaetes and Church resistance fall into place..
- Леонардо-да-Винчи
temperature room I too followed.
- Экко
- Has thanked: 2 times
- Been thanked: 4 times
- Contact:
Yes, I saw experiments with simple water changes, the water resistance after the prayer (and even after a positive navarivanija on it)
only the name of the topic correct: a voltmeter that measures the voltage..
And EMP is suitable for measurements?
- Экко
- Contact:
EMF = Electromagnetic field?
For measurements I would recommend to do UPT at operatsionnyi, this accuracy and measuring small fluctuations in resistance
Yes, the electromagnetic field. Tried to measure, like nothing, if only from the current in the wire connected to audio equipment...
UPT needs to be done and not known how to apply it...
Leonardo da Vinci
And what have you had the device and what mode is set?
Just now took ham radio tester, put
the mode 200мегаОм (at smaller limits
water no reaction), took a glass of water, poured there
water from the tap, we measured the resistance
1.3 Megohm. Then took the water from the bottle that has thawed
after freezing yesterday - the result was the same of 1.3 Megohm.
Maybe I'm not doing it right?
Please describe in detail the experiment.
need more salt... someone recommended a medical solution.. sold in pharmacies..Denisko wrote:Leonardo da Vinci
- Леонардо-да-Винчи
Yes lutshe add escho salt saline as we have in the blood. With soprotivlenie need to poeksperimentirovat. korektirovat until you start to measure. Freezing to reset the information. Try on this water pateritsa or read a prayer and then look at how much has changed resistance
