Page 1 of 1
Shape pendant orgonite
Posted: Sun Apr 10, 2011 21:16
by Турист
Good day to forum users. I want to ask You. Going to make a pendant or keychain from ORGANICA.All the components you need are already there, but I don't know what form to betray him, and most importantly, can the form affect the operation of the device? And is it possible pine resin (which I want to use instead of epoxy) cure using the curing agent for epoxy? Thanks in advance.
Posted: Sun Apr 10, 2011 22:52
by к-13
What like, this and go(here the main comfort while wearing).
Cure pine resin and hardener will not work - when heated from your body it will still swim and get dirty. Easier than ever to cover(ship paint, for example, a layer of a few millimeters to several approaches).
Posted: Mon Apr 11, 2011 16:02
by Турист
K-13 is grateful for the advice,I will try) When do you post a photo of the device)
P. S And if the second layer of coating lacquer and the same epoxy?
Posted: Mon Apr 11, 2011 20:05
by к-13
Varnish is also organic and also a dielectric(special conductive if not caught). There could be(in Lac) powder metal sprinkle, but will organic high density, then you need inside an even higher density to do otherwise, efficiency falls dramatically... There is an option varnish/foil/lacquer/foil/lacquer thick layer(so it will be something like the orgone accumulator on top of orgonite), but may not be very aesthetically pleasing to get...
Posted: Tue Apr 12, 2011 0:48
by МерКаБа
Tourist
Program the crystal. For example for the aura, unconditional love, etc. in addition, it greatly increases the intensity of the radiation of the crystal in Bovey.
Posted: Tue Apr 12, 2011 2:56
by Турист
Can fill regular epoxy (without pine tar) and not to morochte the head) I understand resin tint than anything that she was not transparent.
Posted: Tue Apr 12, 2011 3:11
by Турист
МерКаБа wrote:Program the crystal. For example for the aura, unconditional love, etc. in addition, it greatly increases the intensity of the radiation of the crystal in Bovey.
The Merkaba and how to do it? For this we need what devices?
Posted: Tue Apr 12, 2011 14:43
by МерКаБа
Tourist
no, not necessary, only a mental programming. the network has information on this subject, here's an example: http://www.aums.ru/ezoterika/98.html
Posted: Tue Apr 12, 2011 16:30
by Турист
МерКаБа wrote:no, not necessary, only a mental programming. the network has information on this subject, here's an example: http://www.aums.ru/ezoterika/98.htm
Thank you for the link. Now crystal of quartz for several days to be in the sea salt solution, but now before pouring ORGANICA will hold and mental programming.
Posted: Thu Apr 14, 2011 22:04
by димыч
I used Indian prayer when casting
Let the beauty in front of me.
And behind me is beauty.
And me - beauty.
Beneath me - beauty.
Be around me a beauty!
from the film"the sunchaser"
when testing with the pendulum showed 100 thousand bovi, but there I still have a lot of other features
Posted: Tue Apr 19, 2011 1:02
by Турист
Tell me how to add pictures to the message.[/url][/list]
Posted: Tue Apr 19, 2011 1:03
by Турист
Posted: Tue Apr 19, 2011 2:15
by МерКаБа
[img]link%20am%20фото[/img]
Posted: Tue Apr 19, 2011 2:57
by Турист
That's what happened. For the first time I think it will come))
[img]D:\Р-Р°RSSR·Rre\New%20папка%20(2)[/img]
Posted: Tue Apr 19, 2011 3:10
by Турист
The campaign photo you need to upload to file storage and include their link. Do I understand correctly? As usual directly from a computer failed([/url]
Posted: Wed Apr 20, 2011 18:09
by Турист
Posted: Wed Apr 20, 2011 20:21
by МерКаБа
Posted: Wed Apr 20, 2011 20:42
by к-13
In reference to enlargement should be jpg, png or gif and no spaces between the tags...
Posted: Fri Apr 22, 2011 1:35
by Турист
The effect of the pendant on my health which is incomprehensible. First time wearing it, after 15-20 minutes I felt cold in the chest, after which it was removed. Repeated experiments with him, the cold feeling is not caused but the feeling that the energy arrives and, on the contrary decreases, there is. What can be the reason? Maybe too great a density of metals in orgonite.
Share considerations.
With HC. Tourist
Posted: Fri Apr 22, 2011 20:30
by димыч
but a pebble of some sort in there?
Posted: Fri Apr 22, 2011 22:45
by Турист
The crystal had pointed form and from the Druze, (double-edged) length about 2.5 cm.
