Page 1 of 4
Posted: Fri Mar 04, 2011 16:07
by Алексc3000
Gray
Us flame from here turn out, the last question is off topic, but also with ergonom connected, what do you think about the Joe cell
Posted: Sat Mar 05, 2011 0:08
by Седой
Do not turn out are to blame that I have of these cakes an overabundance of energy, just nowhere to put it except in the forum to merge.
But to stop of course is or in the flame to transfer.
The Joe cell is that gasoline charges ? This good piled a lot of different forms, much works really.
Posted: Sat Mar 05, 2011 2:07
by Тапка
Sed - I look at your posts and the feeling is that you are young at heart just PPC!!!
Positive is good))))
I'm not a psychic but people like that feel)))
Posted: Sat Mar 05, 2011 21:30
by Алексc3000
Gray, thank you :ay
Posted: Sun Mar 06, 2011 3:04
by Седой
Lancelot
sent you 4 messages. Look not sent even don't know what's going on in short.
Knock in ICQ 475 052 478.
or soap erics@mail.ru
Posted: Sun Mar 06, 2011 4:04
by Михаил_
no, not gasoline, and the whole car.... it tube without physical contact moves to the engine (mass of metal) and allows you to gradually reduce fuel consumption to zero, ie we are talking about the materialization in General. ACC. from a biological point of view there is a very powerful field around.
Posted: Sun Mar 06, 2011 5:16
by Седой
Михаил_ wrote:to reduce fuel consumption to zero, ie we are talking about the materialization in General.
:shock: :roll: On wielkanocny plant we would be.
And the living witnesses of it are ?I look for the network in more detail what it is.
Posted: Sun Mar 06, 2011 9:45
by Ланцелот
Gray
Thank you, three letters came safely. :D
Posted: Sun Mar 06, 2011 14:00
by Михаил_
too many witnesses, and the processes are very clear.
Posted: Sun Mar 06, 2011 16:19
by Димонъ
Michael, and where you can read on this subject?
Posted: Sun Mar 06, 2011 19:46
by Седой
Up all night reading about the elusive Joe.
Again the same question. alive and not sick witnesses are ?
Design clear the principle of operation is the same. But now I have actually the same problem. Sucks the air very strongly and from everywhere. Three phase bifilar-kadylanyi coil convert it into electricity. But people are suffering very much.
Sucks the air because with them too, and along with it the energy of life. The information field that they generated thoughts.
And I need it sucked directionally from one point a narrow beam. Preferably from the top.
Considerations already have how to make and use orgonite, let's see what happens.
Posted: Sun Mar 06, 2011 22:23
by Ланцелот
Седой wrote:All night reading about the elusive Joe.
There is a method - mental scanning. Throw in my detailed description to the drawing, the main thing that it was not the idea and working model. I'll try to describe where it is useful or harmful enters or leaves. Not coasu of course, but for a month or two maybe.
Posted: Sun Mar 06, 2011 22:54
by Седой
And two months to be killed this will :lol:
Shas will find that there is. drawings a lot but the number of plants that I noticed in the network.
Posted: Sun Mar 06, 2011 23:30
by Андрей Кабанков
There is material on the cell Joe.
http://vvsh-bird.nm.ru/Projects.htm
Posted: Sun Mar 06, 2011 23:34
by Седой
Turn out so, and so be it.
Really worth the elusive Joe in a separate topic.
Posted: Mon Mar 07, 2011 3:39
by димыч
I'm just in awe of this thing! starting to learn! but I have 2 of the project, and so I will not say that hanging but the action is. accumulate theoretical basis. it yourself SP and ormus. well a couple of smaller ones.
Lancelot
here is the plan
Posted: Mon Mar 07, 2011 11:55
by Андрей Кабанков
Михаил_ wrote:ACC. from a biological point of view there is a very powerful field around.
http://vvsh-bird.nm.ru/JoeCell/joe-cell-zimnyaya.htm
...and I even have the impression that the exhaust is colder than the air around it, although perhaps it just seems. And yet, the hand under it is better not to substitute, because my husband, after these experiments a few times ill brush.
In General, the experiments continue...but I want to notice that all the walls in our garage got a strange blue-greenish ottenok and it is felt that in the room where the cell was located, some special power. In General, this house is better not to do!
Posted: Mon Mar 07, 2011 14:21
by димыч
uploaded the archive with books and videos on the cell in a convenient location
http://depositfiles.com/ru/files/qr36i04pr
taken on ris.cc.ua
Posted: Mon Mar 07, 2011 21:10
by Ланцелот
Lancelot
here is the plan
Not dimychI not compatible with the English. :shock:
Posted: Mon Mar 07, 2011 22:48
by димыч
well, look in my archive, it is in Russian , but I was under the impression that organic poprodukcyjne will be cast in the forms of tube and the same to collect only quartz sand. and let organo properties of gasoline or oil. I do not know whether the liquids resonant frequency.
Posted: Mon Mar 07, 2011 22:55
by Ланцелот
And that these schemas threat? It says that is foolproof, that is a bad man with bad thoughts and so on. Plus you need to comply with sterility physical, and I would add energy. As I understand it, though it's small, dangerous things with the rotating circles. And cell Joe does not. Here can be lethal?
If you can't repeat a working Joe cell, then you are not pure in their thoughts? No offense.
Posted: Mon Mar 07, 2011 23:38
by димыч
I didn't make one, but I think I'd be good. I meant that 5 of the tubes have low efficiency output orgone. in the beginning of the topic about the SP was the photo of a wide ring with a hole for the crystals. here it is the fact. all IMHO of course.
Posted: Tue Mar 08, 2011 1:06
by Ланцелот
The output of the Joe cell tube is smoothly bent at 90 degrees. Orgone on it will not go. Orgone tube on the drum. IMHO.
Or ogron hundreds of species. And each has its own laws of motion.
Posted: Tue Mar 08, 2011 1:40
by димыч
need aluminum to do. he is known for his energy reflecting properties. take, mirrors of Kozyrev, and Logan in the pulsator reflector. as a variant-foil
Posted: Tue Mar 08, 2011 1:49
by Ланцелот
Can Orgon and one, but he has a different vibration?
And so it behaves differently?
Cell Gotiere
Probably first need to read in order to try to understand submission to BJ about it.
