You wrongly assume.
In any of our products there is no element of "basic" and the more "expendable" of charge.
Learn more about it has been said and written including in person meetings/webinars. Take any "modern" subject and get 4 options:
1) there one way or another sewn thought, and finds itself under water, it efficiently and quickly erased
BJ even the first versions from the water becomes even stronger and not Vice versa, in Otley
2) if the object is of type "key" and is a symbol stitched with under-egregorial "capacity" then the physical media is irrelevant and its value is the appearance of the object (symbol-key) and his work is due to the functioning of under-egregorial scheme. The keys to a different level is usually different. It is clear that our products, this is also not true - here is an example, actor Beso without any graphics done remotely
3) if the subject of the planted things (parasite, program, artificially created entity), then it is a subspecies of option 1, with the only difference that the system may have the beginnings of intelligence and ways of enhancing its supply capabilities/life expectancy. That can give nourishment to the strengthening of its structures, but overall it still depends on the initial build. The essence while not usually connected rigidly with the subject (does not have to be linked) but replication of these things are not amenable (have to work on creation of the instance). Obviously this is not the case
Although sometimes parasiticus entity type to the larva of humanity perfectly reproduces/replicates just as the consequences of their obsessive thoughts under the action of egregorial machines (under the action of external motivation and incentives Intrusive).
4) at the resonance when using a subject-communication or picture communication or other resonant connection with something possessing specific properties (well, for example places of power stone is to bring is the simplest example it will be the subject of the cemetery fonyaschih 13ба).
It seems nothing is forgotten ?
well, of course this is a conditional division, as a whole it can be narrowed down to 1 type, or expanded to hundreds.
BJ, and other products to any of the subspecies do not belong. Including TO in no way apply to entities.
I've seen 3-4 (multiple) third-party intervention desecrated BJ, but there it was externally suspended structure and the BJ itself was not touched, and that someone well ooooooooooooooooooh wanted. Well, I saw TO the dead, but
About Pandora. Even those kernels which are on the card - not mandatory. Just unlike omnivores TO panacea and other classic BJ , reconstruction TO Pandora in normal conditions is too slow and therefore core and an additional external source. Otepoti of the map TO Pandora maybe thousands of years of living itself is just slow to grow. Pandora is the only product that has such conditional "external" feeding - just not implement it otherwise. This makeup has nothing to do with this world at all. Conditionally can say that she was from some "put out" point. It will be invariant to any movement of the product in any worlds. Physically including. But if we assume that it is when it shuts down, the kernel will work anyway. And the cells themselves Pandora will work without that and without the other, it just will become weaker grow.
About the usual items - as a rule, they "obtained" a change in the essence of things, for example a change in the attitude of the world to the fact that there is this thing. Therefore, there is not involved even the resonant nature of the creation of the artifact. Therefore, not erased. Therefore, the water adds to (removes external info dirt leaving the essence of things on the surface), so there is nothing to "erase".
In the case of a paper sample can theoretically be a wear item due to fundamental changes in himself.
Example - if you apply something to the material, and then change its molecular structure many times (to melt for example) that may be lost initial form and communication with the fact that it was a long time ago. The paper probes - soft, malleable and so on. So it can "age" but almost certainly wear for a long time. I heard that people wore six months, the probes AMB.
But I do NOT recommend to deal with cheating. And that my humor is my strongest trait. You know the old joke about "not pissing sons, I will give you money for your Mercedes" ? I recently some funny aunt decided not to give money for charging for my designs
for wholesale order placed through one good friend and colleague. Well they just violated the agreement and while the money is not handed over and the party deceiving another colleague managed to pick up. I will not elaborate as I was joking, but when I remember giggling very loudly
For fun sometimes to hang out don't mind the time spent
but it is now not very dynamic in this respect age
I'm not against the use of probes for the purpose
but don't turn this into a circus.<
