Page 1 of 87
Discussion broadcast. Reviews.
Posted: Tue Sep 24, 2013 0:45
by Михаил_
It's time to finally announce the prices and other parameters are important and very effective actions, called "stream".
http://www.mindmachine.ru/translation.htm
As already known from the neighboring branches, the stream occurs in groups of 5 "slots" per person.
Each slot can transmit a separate "product," i.e. its virtual counterpart. Some products take more than 1 slot. For example, the PC in the broadcast occupies 2 slots. There are products that occupy 4.
One of the slots can be used for a tighter "binding" broadcast to the operator, however this action not only takes up a slot, but some part of my time (in creating the data file) and requires a separate payment (installation).
One operator can be included any number of groups of 5 slots.
But it is recommended not to gain more than 3 groups (15 slots).
Payment of the service broadcast is performed in two separate "service".
First service - the actual rent of the slots. Which includes the entry 1 of the basic operator ID (which is broadcast). If a person has nickname on the forum -this is enough to bind. If not, then you have to send for a man name and any photo (preferably).
In other words, the base (small) user ID is created free for each group of 5 slots.
Rent is slots with monthly payment:
450 rubles per month
or when you pay six months, discounted
450*5=2250
or when paying yearly, more discount
450*10=4500
or two years
450*18=8100
ATTENTION. This amount also includes a FREE stream 2.2 in all slots.
When buying more than 1 group of slots, you can keep some of the groups in the temporarily "frozen" state (e.g. for operational inclusion on someone). It paid for the slots that are not used and they didn't go, but they can quickly connect (to pay it is not necessary). Paying a small amount you can have reserve slots, so you can use on yourself or someone from the family quickly and efficiently.
You can (story about this in next topic) to turn the stream on someone without warning or consent, it can not bear to negative consequences.
Filling in part of the slots different from 2.2 carried at special rates (I'll describe later).<
Re: Stream. The basic features and rates.
Posted: Tue Sep 24, 2013 2:20
by Михаил_
The "mode" of translation there are 6 different "States" or modifiers that can be included in different combinations.
1. basic (enabled by default, it is the most soft and he's the weakest, if the word "weak" is generally applicable to the broadcast somehow).
2. reinforced base (gives more rigid and strong signal).
3. chronological (giving retrospective - there is a stream in the past, the degree of integration with cocoon now growing, in addition there are studies on the past auto).
4. multiplexer - provides a more dense and multifaceted introduction to the cocoon.
2-3-4 modes can be enabled simultaneously with the other in addition to the basic, basic is always.
5. mode 5 - detailed. For resources it's much more succinct (approximately 4 times) Gives a very detailed study of the broadcast, large effects.
6. the mode of "chaos" or stream through the chaos - gives a huge potential for personal change creates opportunities to undergo a number of changes over an extremely short period of time. Can cause very abnormal things in life (literally can transform lives in an unlinked chain of events, but rather slides).
The power of this mode is extremely high. Use should be considered and limited. This mode also creates additional load on the hardware.
modes 5 and 6 can be combined with 2-3-4, but I would not recommend to do so, especially 6, and 3 and 4
at the time of writing this text reviews the test group, you can see the "reaction" to the modes 2-3-4. Working with 5-6 will be spent in the near future.
Posted: Tue Sep 24, 2013 2:31
by Михаил_
the translation modes are changed for an additional charge upon customer request. Payment - monthly. Discounts on multiplying coefficient no.
mode 1 =*1 is the basic mode, with no extra charge.
mode 2 =*1.1 - multiply your rate for the purchase of slots on the coefficient 1.1
mode 3 =*1.1
mode 4 =*1.3
mode 5 =*3
mode 6 =*1.5
for example, if You pay for 1 set of slots for 1 year, your mode 1 (automatically enabled) =4500r
connection modes 2 and 3 is calculated as follows 4500*1.1*1.1=5445
connection mode 6 without extra, it will be 4500*1.5=6750
connection modes 2,3,4,5 =4500*1.1*1.1*1.3*3=21235.5 (recall the example we considered for 1 year)
Posted: Tue Sep 24, 2013 2:45
by Михаил_
Products phantoms which you can connect to the stream, conditionally divided into three categories - basic, an "information package", abbreviated as SP and VIP. For example, a stabilizer and SK4 belong to the latter category.
The VIP products are restricted - they connect ONLY when you pay the full cost right away. Their base cost in the broadcast close to the base cost for physical products (generally should be higher because they are more powerful and more convenient....).
Basic products you can buy with monthly payment, payment over a longer period of time is subject to the same discounts as when purchasing slots. (6 months, 5, 12 pays like 10, and 24 as 18).
Product categories of IP sold without discounts for a prolonged interval of payment, and have a simplified billing in three categories (see below). Most of the products of the series SP has no analogues in the form of physical products or is not the full analogues of (mostly weaker).
Purchase of products from group "basic" (3.0, panacea, 2.x, PC, etc.) entails the obligation to redeem the result of a year's subscription to each in not more than 2 years.
In other words, if You buy a 3.0 with a monthly payment and actually pay 1 time per month, for two years you have to buy 12 times for 1 month but not continuously.
Violation of this obligation will result in loss of broadcast and the renewal will be possible only after the payment of the "tail" (in other words no other and the new products won't be connected). It is also no cost, through the "other registration" for the person.
This limitation is also connected with the fact that we are not going to devalue the cost of the desired and important physical products and that really "fluent" reflect the same "three rubles" may not be sufficient and you will receive a semi-finished product, instead of a quality product "always with you". This warning applies to freeloaders who can arise the idea of paying 1 month and the abyss.<
Posted: Tue Sep 24, 2013 2:57
by Михаил_
Products 2.5 2.6 2.7 2.8 and panacea, have to broadcast the basic cost 800R per month each
(rounded down and close to 10 000 per year, which corresponds to the base value of a number of their material counterparts).
discounts are calculated the standard way.
half a year = 4000R (800*5)
year = 8000R
two years =14400р
3.0 has a price of 2000P per month (annual rate for monthly payment of just above 3.0 S though is a more powerful version).
PC has a cost of 1000R per month (but takes up 2 slots) i.e., the price is 1000 rubles per 2 slots.
3.1 has a cost of 500 rubles per month.
OZ has a cost of 2000P per month.
Posted: Tue Sep 24, 2013 3:08
by Михаил_
To the product FE right now
1.Color dreams 500r per month
2.activation of male sexual energy (as well as with cards is the elimination of the blocks which impede the normal work of the cocoon, because embedded in a chain of incarnations of artificial restrictions) 500r per month
3.activation of female sexual energy (the same) 500r per month
4.stoppage special versions (4 slots) 2000P per month
5.work with the weather 500r per month
6.working with memory of the past 500r per month
7.weather control 500r per month
8.the standard 500r per month
9.navigation (anomalous zones and other worlds) 500r per month
10.internal living space 500r per month
11.integrated mode is the new 500r per month
12.energy in sex (total, without dividing mg) - activation of memory and the actual flows and their correct variants of "looping" in time... as well as the management appointment of energy held such a transmutation 500r per month
13. genome (4 slots) 2000P per month
14. territory 500r per month
15. FRM 500r per month
16. call 500r per month
17. the normalization of male urogenital sphere (3 slots) 1500R a month
18. Baby calm (2 slots) free
19. Building (5 slots) 2500 R in the month + 2000 R the inclusion
20. dominance (2 slots) 1000 R per month
21. Road safety (2 slots) 1000 R per month
22. Panacea-youth standard (2 slots) 1000 p per month
the list is constantly updated...
To connect the broadcast of the Genome and Stopmovie special version need 4 free slots.
The normalization of male urogenital 3 slots.
Restrictions on the date of purchase no (You are not required to purchase year)<
Posted: Tue Sep 24, 2013 3:13
by Михаил_
Products VIP group =
1. Stabilizer = 80T at a time (something between a large and small)
2. SK4 = 180 tons at a time.
3. Range of 5 = 50t at a time and 2 slots in the short term (1слот now, will upgrade). recommended with mode 6 in combination.
4. u4 = 40t at a time.
Further, the stream of these products is possible as long as paid slots.
With the resumption of the payment slots more than one year or any other period as additional payment for the products themselves is not taken.
Posted: Tue Sep 24, 2013 3:27
by Легенда
Payment methods and order only through the office or some automation ? Well, let's say payment via kiwi wallet.
Posted: Tue Sep 24, 2013 3:34
by Михаил_
through all point of sales on the same terms.
would there be some automation in the near future or a little further - life will show (depends on its feasibility, which depends on the number of users).
You need to understand that without me (without my direct participation in the inclusion of certain options) it will not work and options will not change. Unfortunately, as I wrote above in the answer not the question, I know a very limited number of people in this world who would like to steer and they are generally busy with their own Affairs
In other words, 100% full automation actually launch - not possible.
Simplification of paid procedures it is highly likely useful, but see above - look at the number of subscriptions and the amount of manual work after some time....
As for easy payment schemes is in the office plus the development of this direction is their prerogative.
Posted: Tue Sep 24, 2013 3:41
by Михаил_
The connection is created after payment, in a few days(1-3). We will try to optimize to daily processing updates, BUT because it will always be partly manual work (there is a bunch of transmitted with reference to the operator requires including the mental activity of mine), online mode will not work, this is not the story of U2-3 where I like a bunch of just "program" level testing (automated) request from the forum, with transley it's much-much harder and smarter, it's a completely different level thing and product.
In some exceptional cases may over-Express connection + 2000T.R. The possibility thereof is determined in each case individually. If the urgency does not work - payment for urgency is not charged. (in the case of an urgent request I will try to find in real time and pull from the cases).
However, subject to availability I will as quickly as possible to process applications without any extra charge.
Record a personalized user ID (which is 1 Jn a separate slot in the broadcast and enhances the effects) is made after the following data:
1. several photos of different ages
2. a brief history of "will I tell about myself, who I am and what I live for, to aspire to" = 5-10 sentences in a free style.
payment of this one-time services and costs 25T.R. the implementation is also within a few days (up to weeks, it requires certain conditions, more special than just something to connect). This thing is a decent quantum of my personal time of its creation (sort of exclusive).
Posted: Tue Sep 24, 2013 3:56
by Михаил_
There are unusual types of translation as:
1.
stream a group of people (a set of similar products, as well as on 1человека groups of 5 slots) effectively in small groups up to 20-25 people. Margin *2 slots +2000P for inclusion.
the entire group is one and the same stream. It does not lead to excessive alignment of people with each other. Preferably, the group was United on a certain principle (employees, relatives, etc.). When such translation efficiency is considerably lower, but sufficient for basic effects. Life qualities to their independent work with no translation most likely will not occur or will occur very soon, but it is good to use for General "pull" of the status of a group of people, such as workforce
2. stream in house, office, room. (protective qualities, panacea, Y4, of stoppage, 2.7 is also special design for this, and good use of options PCs and the internal living space).
the scheme is the same as with the stream on the group.
for setting up + 2000P + *2 of the cost of the slots.
here you can experiment, for example the office Manager may find an interesting view when combined 2.6+PC+of stoppage, by the way, I want to note that the new 2.6 very interesting (it is quite different, as well, and all 2.x in broadcast mode). We can say that it is a lot more powerful in his manifestation of qualities.
Posted: Tue Sep 24, 2013 4:19
by Михаил_
Also possible to stream to the process, firm (not a territory and not a group of people, but the commonality is not egregorial, although this factor is also affected), to the event.... in this case, the price-list is individual, send a request.
The basic condition - more than 25 people (e.g. in process) on one set of the 5 slots will be a little effective.
Possible stream purely individual things, a certain set of "requested for change" created by a particular person. Benchmarks of value - about 60 000 per slot(for developing special tools that would take several slots from a week to several months at a time), you might need 1-3-10 slots.
Under the "changes" of course, you need to understand in the first place a trend, a potential in interaction with the world, because the end result also depends to a significant extent from the actions of the person.
We also carry out some experiments associated with stream things directly affect the parameters of physics body. Is discussed individually.
Posted: Tue Sep 24, 2013 4:24
by Михаил_
Stream of products in stock, but are not now in the list of possible options are discussed for each product individually. In some cases, the option will be made without costs (additional) for eating. In some cases, is a failure. The reason for this is that the range of products for broadcast has its own characteristics and "unnecessary entities" it is not necessary.
In addition, financial products have their advantages (sometimes significant), for example, they can be transferred to another person, they persist from generation to generation, and so on.
So I'm not committed all the details to saublebeach in the form of possible translations.
Posted: Tue Sep 24, 2013 4:34
by Михаил_
Stream AMB. Which asked many of the test group and was refused.
Theoretically (and practically - we work with her) it is possible.
The problem, or rather a number of problems that are "insurmountable," but have their pros and cons.
1. need to stream 48 streams (slots)
2. need enhanced personal reference (occupies one slot on each group of 5)
3. preferably the strengthening options 2-3-4 or 5 or 6. option 6 is most appropriate but very extreme.
total. simple math
start-up costs 25T write enhanced binding on You (though she's not just for AMB), when used in each group of slots will for 4 free.
48 divided by 4 = 12 slots, no discount is 5400р per month
each flow broadcast AMB can be equated to PI 1st category is cost 500 rubles a month (maybe later, some parts and will be available separately from the General SBA).
it is still 48*500=24,000 in a month.
total, without discounts, the monthly costs almost 30K.R.
Cheaper to buy 4 physical AMB
(although translation has a number of powerful advantages).
for resources and other reasons, much to adesivil this process does not work. Some discount and if you pay monthly broadcast AMB certainly possible (e.g. 30%).
Posted: Tue Sep 24, 2013 4:35
by Михаил_
In other words, the stream of AMB per person 12 is identical to the broadcasts on different people basic 5 slots each (for used hardware resource....)
Posted: Tue Sep 24, 2013 4:57
by Михаил_
The pros and cons of broadcast.....
Pros - generally mainly some of the pros
effects is more powerful, no need to make up the "tree" and the product "root", then they can not wear, but they "always with you", this is especially interesting for such things as V4, SK4, stabilizer....
particularly in his pocket, not shabby
But for other things....
Effects in some cases MUCH more powerful than physical products.
Cons -the physical product it is possible to transfer, donate, lend, give temporarily to the needy. Broadcast ... here is more complicated. Although the quality that You speak fluently, no doubt can be perfectly transmitted to others, but this is some special skill.
Physical products can live for years, centuries and tysyacheletiyami handed down by the family, and stream for thousands of years in your cocoon, always with you, it's baggage that's not going anywhere. Conclusion - both very useful.
In some cases, physical products are easier to work (for example stabiliser).
For some, the presence of the physical hand of bracelet easier and more understandable, tangible and helps not to feel doubt (or try several of them at least).
Draw your own conclusions.
Posted: Tue Sep 24, 2013 6:53
by Petr99
Michael, can buy to rent slots?
Posted: Tue Sep 24, 2013 7:23
by Михаил_
Yes, it works.... everything described above is available to all. Well , I reserve the right of someone to refuse certain options, but I think that it is rarely useful.
Posted: Tue Sep 24, 2013 12:54
by арте:м
in what category of the broadcast comes FRM ?
Posted: Tue Sep 24, 2013 13:13
by Михаил_
to FE first category, 500r per month, one slot.
Posted: Tue Sep 24, 2013 16:42
by ВитЗлат
Question: 3.0, 3.1, PC and O3 - discounts six months, a year apply?
Posted: Tue Sep 24, 2013 18:53
by ВикторРусс
And where you can see the description
series entrepreneur ?
14. territory
Posted: Tue Sep 24, 2013 20:35
by СтАвР
what demokratichnenko happened
it on my account
someone work pribavitsya
Михаил_ wrote:Basic
2.5
2.6
2.7
2.8
Panacea
3.0
PC
3.1
OZ
E-cure is a strong reference?
Михаил_ wrote:series SP
1.Colored dreams
7.weather control
8.standard
14. territory
15. FMR
these products to SP as I understand it or not?
Shield, stop, broken ties?
Map "freedom of the mind, a mode of the ocean"?
Map "Fairing"
Map "Self-Hypnosis"
what about the SOC line probably before?
Михаил_ wrote:VIP
Isn belong to this category?
well AMB is clear
Panacea-Youth?
Posted: Tue Sep 24, 2013 20:52
by Андрей С.
You can not score all the slots?
That is, to rent the same group of slots (5 PCs) and, for a start, a single product?
Posted: Tue Sep 24, 2013 21:58
by Пианистка
Question: can you detail about these topics, or where the description read?
7.weather control
14. territory
More questions:
1. there is a module Store - to attract customers, is it possible to make such kind of specialized stream - to ideas, goods, services easily found an appreciative buyer)))
2. is it possible to make specialized on the stream restoration of family ties?
3. is it possible to make the stream to improve memory (for learning foreign languages, for example).
More clarification: will it be possible to pay on the card of Sberbank?
