Page 3 of 4
Re: EP 5.1
Posted: Sat Oct 05, 2013 17:19
by Михаил_
start with the end - the size is quite small, housing less than the previous version.
6.4 is on the order of 1-2 weeks, in some cases, however, the wait can be above (now I have parts for 2 kits 6.4 all the delivery period is 3-4 weeks, the next order on the road....)
the power of the 6.4 will be about an order of magnitude above 6.0
the cost will be 170 6.4.
6.4 is a built in frm for a quick recovery.
Re: EP 5.1
Posted: Mon Oct 07, 2013 0:53
by Мастер 108
Михаил_ wrote: anomaly is created not here, not now and no where
but there is where we want to be. For no apparent valid reason. Very comfortable ....
What sizes and shape of anomaly?
Re: EP 5.1
Posted: Mon Oct 07, 2013 1:04
by Михаил_
as well as for эп5й series, melaina matryoshka.
Re: EP 5.1
Posted: Mon Oct 07, 2013 6:30
by Расторгуев
6.4 FRM more complete than the one with the figure posted on the website?
6.4 from 6.0 how many orders of magnitude more powerful?
What are the effects of such power can I expect?
Re: EP 5.1
Posted: Mon Oct 07, 2013 7:55
by Владмосква
6.4 6.0 how many orders of magnitude more powerful?
well written as that
many men, many effects.
Re: EP 5.1
Posted: Mon Oct 07, 2013 20:07
by Расторгуев
Today made a prepayment for EP 6.0 to myself, I note that already there is a General anomaly in the apartment,want to sleep and there was a General vicoletti from processes that occur outside the apartment.And another thing,when you walk down the streets of the mini screen too feels like from the transmission from the inside out.
Re: EP 5.1
Posted: Mon Oct 07, 2013 20:18
by Михаил_
this infection (EP new) and some translation modes have the retrospective.
Re: EP 5.1
Posted: Tue Oct 08, 2013 0:40
by Михаил_
it is obvious that frm is laid out is kind of a Lite version, in the translation of IP frm and frm in EP are naturally more full.
Re: EP 5.1
Posted: Tue Nov 05, 2013 20:29
by Андрей Кабанков
EP 6.0
The price of 75 000 rubles.
Re: EP 5.1 - 6.2
Posted: Fri Nov 08, 2013 18:04
by Расторгуев
1.If you make the screen on the bed in the ideal put VC 6.0 as well as EP 5.1 under the bed?
2.On the wall or the nightstand next to the bed,may affect the capacity of the bed screen?
3.Horizontally,vertically or on edge,what is changing?
4.If a function as in V4,the device in one place,the mental screen on the bed in another city,so it will work?
5.The plastic part will break off may affect the functionality?
6 Not included in the network works too,but weaker?
7.In the water when taking a bath can be omitted (for waterproofing)?
8.There is something to burn (the issue of possible overload,if it sounds correctly)?
Re: EP 5.1 - 6.2
Posted: Fri Nov 08, 2013 22:54
by Михаил_
to lower the water does not need
not sealed
placed next to the bed (10-50 cm) or a Desk, on Desk, on bedside table. In a semicircle to the side of the screened space.
Is clearly (on the bottom, otherwise you will not stand).
to burn nothing will happen (there is a microprocessor inside, as in the new V4, but there is no connection between the process and the electronics inside).
Mental stretch to another place is possible, but will be weak.
not included in the network is much weaker.
Re: EP 5.1 - 6.2
Posted: Tue Nov 12, 2013 18:22
by Расторгуев
Michael when you enable EP chaotically to illuminate the blue led on the case,then the process stops blinking,what is it?
On the network adapter that is inserted in the socket it is written 5V 500mA.
Question: there are external akkamulyatory under the same connector with the parameters to output 5v 1000mA and 5v 2100mA,is it possible to use such akkamulyatory with this device?
Re: EP 5.1 - 6.2
Posted: Tue Nov 12, 2013 21:59
by Михаил_
1. you can use any power source.
2. diode .... well, he's the kind of activity shows
in General, it may stop blinking when the screen density has reached the limit available for the device.
Re: EP 5.1 - 6.4
Posted: Tue Feb 17, 2015 1:30
by Владмосква
Michael, EP relaxation, and F1 for creativity. Yes?
Q: can the EP and F1 operate at the same time? What if EP to place on one edge of the table, F1 on the other edge, and work at the table? Whether this combined space to work better than pure F1?
Re: EP 5.1 - 6.4
Posted: Tue Feb 17, 2015 13:34
by Михаил_
Different devices will be in series F1 there all describe. Together - you don't need.
Re: EP 5.1 - 6.4
Posted: Sun Feb 22, 2015 1:28
by Мастер 108
But if you do physical EK - it must be the pipe or the form doesn't matter?
Re: EP 5.1 - 6.4
Posted: Sun Feb 22, 2015 11:22
by Михаил_
not necessarily, but the form is certainly important, I have a prototype (first EK), which is made of shields, but to smooth the field emission from the corners to still placed the pipe inside. Plastic. I think it is better to stick without angular shapes.
Re: EP 5.1 - 6.4
Posted: Mon Feb 23, 2015 20:49
by Мастер 108
And whether it is necessary as-that to Orient EK to the cardinal? Why it seems that the long axis should be along the line West-East.
Re: EP 5.1 - 6.4
Posted: Mon Feb 23, 2015 23:47
by Михаил_
1. It is not necessary
2. Really photo different from the last model, there is a ball upstairs
Re: EP 5.1 - 6.4
Posted: Tue Feb 24, 2015 9:45
by Мастер 108
I'm talking about fizicheskuyu EK had in mind...
Re: EP 5.1 - 6.4
Posted: Tue Feb 24, 2015 11:21
by Михаил_
depends on tasks and material.
Re: EP 5.1 - 6.4
Posted: Fri Nov 27, 2015 1:00
by 373Алекс
Михаил_ wrote:now just put the box in the desired side of the screened space
the right side from the lead wires or the opposite?
Re: EP 5.1 - 6.4
Posted: Fri Nov 27, 2015 20:25
by Михаил_
On the right side of the model where the semi-circle/arc - side thereof, and where balls - dome is stretched in any direction mentally.
On the new version will be different. Capacity will increase SIGNIFICANTLY.
Re: EP 5.1 - 6.4
Posted: Wed Dec 02, 2015 23:00
by 373Алекс
Михаил_ wrote:right side on the model where the semi-circle/arc - side thereof, and where balls - dome is stretched in any direction mentally.
Considering the device looks like a plastic box with a fixed size 130х70х20мм top mesh plastic ball. A ball attached to a plastic box closer to the power cord entering from the end boxes. Semi-circle/arc-not on the device. Generated by the device cloud is thrust in the direction opposite to the supply wire?
Re: EP 5.1 - 6.4
Posted: Thu Dec 03, 2015 1:27
by Михаил_
Generated by the device dome-shaped constraint space is stretched mentally where you want, the device is placed at the edge of a closed space (next to the table/bed, etc.).
