Page 8 of 9
Re: Audio for IC.
Posted: Mon Aug 13, 2012 9:58
by Воффка
Вячеслав. wrote:applying P-stick,I mean,closer to an audio input on the cable attach the USB flash drive,start applications such as audio cleaning energy space,the time is reduced at times easily and firmly capable of retaining desired images,more interaction between me and my beloved device
Do not understand how and where you attached the drive? The wire is like? What mode u-USB flash drive at this point? In what sequence between You, the UK and the drive interact?
Re: Audio for IC.
Posted: Mon Aug 13, 2012 11:46
by Вячеслав.
Voffka,it all started with the info transfer,at some point I needed to get the object lying on the object table,attach the flash to better draw out the characteristics I need lying under IC object,call it so,and I thought I could write something like programki-bridge for better interaction with this device,everything is increasingly happening on an intuitive level,although this long enough P-stick was lying on the object table,without any visible improvement,i.e. effects which I wanted to get,was not observed,intuitively, again, measured the distance,closer to an audio input in SK,then,and turned on the audio for the UK to reduce the negative.likely.because audio as far as I know there is one,it is clear that SK,me and insist me,but the effect was not like this,U-flash drive in this case acts something like a filter,and transmitter and retaining filler I needed condition,where that is so,I will be glad to constructive adjustments and comments,but believe me the last thing I'm interested in what soap bubbles.
Re: Audio for IC.
Posted: Fri Aug 24, 2012 15:09
by ФилиНН
Question about doses of the use of SK in the "mental dynamics"
Would not it be an overdose or "habituation effect" if twist days, or all the free time some files
- the standard
capsule
tablets
and so on ? He can't smell you.
Re: Audio for IC.
Posted: Fri Aug 24, 2012 16:47
by Михаил_
the capsule a day is not exactly right, and the rest in health.
Re: Audio for IC.
Posted: Fri Aug 24, 2012 17:17
by ФилиНН
Thank you! So sometimes on a night to recover...
Re: Audio for IC.
Posted: Fri Oct 05, 2012 15:52
by Петрос
Worked with a Conductor in the UK and noticed this peculiarity. Different effects from the way headphones. In the first case, headphones connected to the player, the player at the same time to SK. The second Player to SK from SK - headphones. Now, in the second case, significantly changed the perception of audio. Patrushev's voice was closer, clearer and alive or something. Or differently, how would the interference of perception left. Does anyone have similar effects from audio when you connect headphones to the UK?
Re: Audio for IC.
Posted: Fri Oct 05, 2012 18:20
by Михаил_
do not understand how is it podkluchit the second option? there, on the output connector cinch, it is not stereo
Re: Audio for IC.
Posted: Fri Oct 05, 2012 20:13
by Петрос
Михаил_ wrote:do not understand how is it podkluchit the second option? there, on the output connector cinch, it is not stereo
the splitter in the UK, it player, from it headphones
Re: Audio for IC.
Posted: Fri Oct 05, 2012 22:41
by Михаил_
hmm, but it is in fact just a parallel connection.
Re: Audio for IC.
Posted: Fri Oct 05, 2012 23:11
by Петрос
in General, I do not doubt it. the first thought that SK responds to my manipulation of audio. possible with connecting the headphone to the SC is a great mental reference to the device(in my case).
Re: Audio for IC.
Posted: Sun Oct 07, 2012 17:49
by Шломо
is it possible to use the audio track from negativity through СК1М,on the premises which are at this moment living people.
Re: Audio for IC.
Posted: Sun Oct 07, 2012 18:25
by Маг.нет
Anything that does not interfere, SK in this aspect is working with the energy of a space, people will only benefit, however indirect.
Sincerely, MAG.no 〠
Re: Audio for IC.
Posted: Sun Oct 07, 2012 19:08
by Шломо
thank you MAG.no. Just like always put "negativity" in an empty room
and as it is not even thought of.
Re: Audio for IC.
Posted: Sun Oct 07, 2012 20:28
by Михаил_
so there is no problem, often there is no possibility to separate the room from the people
just a possibly empty faster clean up ( it is minimized and other effects).
Audio for IC.
Posted: Tue Oct 23, 2012 13:41
by ФилиНН
Михаил_ wrote:the structuring of water in the regime of water contributing to more rapid recovery
sk1water_iscelenie.mp3
You can find out is the same for all the structure?
Or something based on information from the operator, the state of his meridians, energy, organs, etc.?
Re: Audio for IC.
Posted: Tue Oct 23, 2012 15:57
by Михаил_
both that and another together. If you need water for collective use, simply tell the device about it mentally.
Re: Audio for IC.
Posted: Thu May 01, 2014 7:54
by интересующийсябж
Hello,
5 tracks demo to affect me much, but 15 not demo to a lesser extent (the track "capsule" I felt (2.5 days played non-stop)). One gets the impression that the demo is more effective - is there really a trivial difference from demo not demo tracks?
Thank you.
Re: Audio for IC.
Posted: Thu May 01, 2014 19:56
by Владимир Ш.
interesuushihsa, well, the "capsule", the idea is that in normal conditions and should not be felt - it is for special situations. and not for long term use
Re: Audio for IC.
Posted: Thu May 01, 2014 21:02
by Михаил_
In normal conditions there should be no spec-brightness exposure, it is useful and good to smooth (more harmonious effect), so the demo is more visible (that does not mean that they are more efficient or something cooler).
Re: Audio for IC.
Posted: Sun Nov 09, 2014 22:42
by АндрейКо
I tried to twist demoenergy.mp3
From some reason I didn't feel, well, left in the cycle and went outside... But 40 minutes later there were signs of overloading - I had to return home urgently - disable
Half an hour later, everything returned to normal.
Play cleaning the room from negative led to physical cleaning-repair the rest of the apartment... (it looks like the UK-an IED immediately decided the whole apartment to clean... - gas cooker, water meters, permutation and finishing work...)
PS is a very powerful tool (a weight of only 1.5 kg - more massive than what can imagine...)
Re: Audio for IC.
Posted: Sun Nov 09, 2014 22:59
by ЛИЛИЯ-Р
Re: Audio for IC.
Posted: Sun Nov 09, 2014 23:20
by Вячеслав.
Still audio for the UK,is extremely important.Here is a small example...morning (prosypaeshsya and mental vkluchaet mode "capsule"),very quickly and kachestenno raspredelyat all Sergiu the body.Or,after energy operator (capsule),not selectively energizes.And nastraivaet in a working mood,by the way...
well vzaimodeistvuet with the designer of the body,boosts the energy for preobrazovaniya (and body transformation).
Re:
Posted: Tue Nov 11, 2014 12:17
by АндрейКо
Михаил_ wrote:8. Harmonization and normalization of the energy of the room
sk1room.mp3
Feeling as if to her grandmother in the village got
(35 years ago...)
Re: Audio for IC.
Posted: Tue Nov 11, 2014 19:48
by Михаил_
Yeah, SC is a great product .... actual literally indefinitely
Re: Audio for IC.
Posted: Tue Oct 27, 2015 12:08
by АндрейКо
Михаил_ wrote:capsule a day is not exactly right, and the rest in health.
And how much time?
(wife asks to leave, hours 11 as enabled...)
