OZ
Locked
Акела
Has thanked: 28 times
Been thanked: 64 times
Re: OZ
Post by Акела » Fri Oct 05, 2012 17:27
Each frame, according to Michael, is the structure, pulling them at random then what many will be lost. And each of them, so there 52400, a year will take that on photoshop!
Been thanked: 906 times
Re: OZ
Post by Михаил_ » Fri Oct 05, 2012 18:27
Yes, you can print one or a piece and will still work, just the resonance will be slightly lower, not complicate life speculation.
Example - go to the bookshelf and catch the feel of the covers of books by taking them in hand.
Only a small part - also will start the process.
Just a complete roller special special equipment and usually forms in the space of a phantom in which there are processes of processing of products (word charging really poorly suited).
Александър
Has thanked: 17 times
Been thanked: 1 time
Re: OZ
Post by Александър » Sun Nov 25, 2012 1:08
Guys, I mean, what was interpreted once Michael decided that I was cool enough and began to wear along with a self-made bracelet 3.0 N ebony and matrix OZ.
A lot of whether were, little did, but in the first week of November so I was covered... in Short there was a feeling that I am not me , the strongest feeling that the eyes are not in focus, and all arose and then, and I'm a nerd, not immediately guessed that this was artifact.
And went to the doctor. I looked around on the machine with Doppler effect-the doctor said that he sees some sort of artery in the head is not quite right characteristics, but it is necessary to check the eyes first . I have not yet checked them.
Temporarily removed all artifacts with yourself. Recently started gently worn day 3.0.... OZ without feeling more or less normal.
I just don't know what it should look like as 3.0 , the more that it and especially not to describe.
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Re: OZ
Post by МерКаБа » Mon Nov 26, 2012 20:25
Alexander you are not alone in these symptoms az I also have "I am not" and "how did I get here?" :) the eyes see it is also very strange :)
I wear 3.0 and panacea, without OZ.
Александър
Re: OZ
Post by Александър » Tue Nov 27, 2012 1:34
Merkaba, I strictly follow him (each of us) and to dose and to measure for 7 times :) . I still shoot invisible hat to the experimenters, not having a clear vision proishodyaschego, still trying to learn and move on.
User avatar
Has thanked: 24 times
Been thanked: 142 times
Re: OZ
Post by Маг.нет » Tue Nov 27, 2012 8:00
МерКаБа wrote:I, too, "I'm not me" and "how did I get here?"
Describe your vision, can clarify....... In 3.0 your consciousness "I" is seen as a small part of a more complex consciousness, but not external, I'll try to explain in comparison, when "raise" the experience of past incarnations (part of the "not me"), the identity becomes more complicated and stretched in time linear in the 3.0 differently, here the observations "rise up" and integrated into "consciousness 3.0" ("Over I"), parallel identity (many branching chains is reduced 3.0 is consolidated at one point), receiving your experience in the moment (i.e. working together "in the same boat"), with itself as 3.0 "out of time", i.e. it contains all possible configuration as the current personality and past and future (already have some predetermination) of the present moment. Here it is the presence of "parallel personalities" of the present moment can be troubles of the past to today's personality (if it resonates with her on this parameter has a similar experience), in the current branch we coped with the problem, but there are threads where this has not happened yet, and imposes a "burden" in as 3.0, on the other hand, this condition allows to help to cope with this problem parallel personalities (and they let small, often not perceived, but "as it is" affecting a part of each of us the solution to these "parallel" problems increases the integrity of our consciousness), because of our experience with our current.......
Something like this. By the way OZ promotes resolution (focusing on them in 3.0) and such problems. Comments are welcome.
Sincerely, MAG.no 〠
User avatar
Has thanked: 5 times
Been thanked: 16 times
Re: OZ
Post by Вячеслав. » Tue Nov 27, 2012 13:08
MAG.no respect!...
МерКаБа
Re: OZ
Post by МерКаБа » Wed Nov 28, 2012 0:13
MAG.nothank You! A little bit reminded of "triangulation of light fibers, the most sacred forms in space..." :) Izotermicheskoi a joke. :oops: az
I'm more worried about another problem. What to do with the dark part, which, from wearing bracelets that much aktiviziruyutsya and just absorbs them with his head.
Александър
Re: OZ
Post by Александър » Wed Nov 28, 2012 0:53
MAG.no, thank you! Here is the description in my opinion you are voicing for the first time when synced different "editions" of a single individual, or even drafts! Or I did not read? In any case, breathtaking.
Re: OZ
Post by Михаил_ » Wed Nov 28, 2012 1:50
Just different people in different ways in the course of basic subjects....
It all sounded and sounds, but ... apparently in forms that are understandable to those who are in the subject.
Petr99
Has thanked: 3 times
Been thanked: 15 times
Re: OZ
Post by Petr99 » Mon Jun 10, 2013 6:57
The new version of OZ is very well felt, especially in printed form. Oschyuschenie other than brasta OZ made in the video, it seems to me more powerful and softer although still a little time passed, I could be wrong. I think that matters experience in the use of (or use) a PC.
If that even makes sense, then such Association: in the center of the source of energy and (or) source structure (PC), and four balls is filled with arrays. The star from the centre is the interface arrays to the main processor, and the outer ring is the bus system.
Re: OZ
Post by Михаил_ » Mon Jun 10, 2013 12:32
All written glitches. (in the sense of Association).
OZ has a reinforced interface with the PC but PC a PC is. Well, everything else too.
There should be absolutely other associations.
It's just a resonance current to your personal "settings".
By itself, the version of this OZ remains OZ. I.e. it creates as "the Lord inside the world" - a pretty "violent" :) in this case the presence of a zone of a PC, the operator shifts out of it here, although the use of the existence of area - remains. This is one of the reasons why OZ is not included in the Communicator in full form. Here it is (or can be located there, and in the other, but not personal world, i.e. where there is work).
Petr99
Re: OZ
Post by Petr99 » Mon Jun 10, 2013 14:47
Yes, the manifestations are the same as from a bracelet. After some time, start the headaches. And pain, not that at a certain point, or changing, and in the entire head, like behind a computer sit out, maybe ad nauseam to reach, if not in time to react. Is not ready yet. I couldn't bracelet long wear, I think that a maximum of 3 days was able to carry it continuously. Without it easier. Apparently, the body can't endure such a load, still need to recover.
User avatar
СтАвР
Re: OZ
Post by СтАвР » Fri Aug 02, 2013 17:07
did it for myself, maybe someone will be useful, solution of large
http://yadi.sk/d/pVSS1Ngm7V0AG - oz
http://yadi.sk/d/ZyQ12Acg7V0B0 oz 3D
User avatar
Даррья
Been thanked: 3 times
Re: OZ
Post by Даррья » Sun Mar 30, 2014 23:13
All kind time of day! I want to share experiences.
I even draw this matrix did not - just presented it in front of him. Letters immediately lit up bright and I covered. Rabid euphoria, drive, a desire to dance and laugh (and in the background just randomly played "Dragon" Mill, which I later read that Mill as well on the 3.0 and 0.3 configures), the space around has become a sort of viscous, chtoli, and when I moved the hand as if they met the resistance and it seemed as if these movements waves diverge. And something else that words cannot describe.. I took this as no more than 5 minutes, there was some understanding of the responsibility for what can pile up, and immediately wiped the image matrix, and then I was sick, but the feeling of joy, drive and love for the world kept for a long time, although it was much softer.
However, to repeat the experience somehow is not drawn yet. 3.0 N load now. The experience of wearing BJ almost 2 months with 4 1.0, one of them with Cure in addition, and it's very cool! Many things changed in my life for the better - work, communication, sense of self, the perception of many things, I forgot what laziness is energy in abundance, and wild pleasure from the fact that things are going exactly as make. And thinking even I feel like changing... Kittens, talking, doing reasonable? Heh.. from my personal experience I will say that people too...
Марат Г.
Re: OZ
Post by Марат Г. » Thu Dec 11, 2014 21:35
Good evening respected forum members and special thanks to dear Michael.
Made OZ a pendant by engraving. powerful turned I want to tell You.
The whole evening was sitting in some emergency Issa, a feeling that took some powerful medication to enhance the consciousness associated with gain powerful dose of endorphins.. :)
and then filled with epoxy a few times and each time were driven during drying, long movie oz.
In the end, came something even more interesting :)
First, increased power and seemed to become more voluminous or something.. :)
First couple days felt a new energy-status, yesterday was hard, but today is fine.
And most interestingly, the pendant is not even dressed, it hangs at about 60 cm from me on the wall, and this thing is valid, because when you get close to him and being near them, feel the change of energy.
With respect Marat :o
Марат Г.
Re: OZ
Post by Марат Г. » Sun Jan 18, 2015 0:06
today I decided to use the pendant of OZ not applied early by the way.
at a friend's friend (our Forester) fell ill daughter after giving birth that it's my kidneys, I realized what acute renal failure.
so took her for an operation in Moscow that then and there cut and in General she's in there now is in intensive care after surgery.
people came sad, well, of course people are depressed and so along the way told about it.
decided to apply to the situation of work by means of Coulomb, namely tried as follows to enter the state, and from there I got the idea to drain and shut down her state of illness and to apply impact by Gulf energy for the overall improvement of her health and full recovery.
since I've never seen her then walked through the father in his birth canal to itself.
well, seemed to be the most faithful..
well, everything today, it is my job in this vein, I hope that helped..
and, of course, about this person I said nothing, and did not intend.
certainly in such situation it is very difficult to intervene and do something, but once people found it necessary to bring it to me, I decided that this sphere of my responsibility and to just sympathize and I forget about it I don't have to, and should be optimized, if such a situation occurred in my area of the world perception, that is, once I found out about it..
only would, but in General wording and intent were correct and when the work is implemented correctly.
and to the person that I was then given a homemade bracelet, but he is not really reviled for a while and just had lying around the house and of course with modules and in General with the bracelet it is certainly not working..
Sincerely yours, Marat
АМарта
Has thanked: 2 times
Been thanked: 2 times
Re: OZ
Post by АМарта » Sun Jan 18, 2015 1:36
Stavr,Thanks a lot for your printing!
ЛЕТАВИЦА
Has thanked: 11 times
Been thanked: 4 times
Re: OZ
Post by ЛЕТАВИЦА » Mon May 22, 2017 21:21
Good time!!! Please tell me whether the new version of OZ pendant? If Yes, then this will be a new product , more powerful ? And what form of jewelry - map pendant? Cost?
Thank you!!! Magic time!!!
User avatar
Re: OZ
Post by Вячеслав. » Sun Sep 24, 2017 22:54
Lord, someone is able to paint conventional landscapes untethering of place and time ) This is akin to iconography, along the way, I want to stipulate that treat religions with respect and understanding-to help you to enter the desired state.Not to zaplivatj you can create a separate topic in conversations about everything... for example,who knows how, in the context of this section! So myself and Express :)
Re: OZ
Post by Михаил_ » Sun Oct 01, 2017 4:14
ЛЕТАВИЦА wrote:Good time!!! Please tell me whether the new version of OZ pendant? If Yes, then this will be a new product , more powerful ? And what form of jewelry - map pendant? Cost?
Until the re-release pendant in a new form not yet planned, but it is possible that in the near future will come, there is something to change and something to work on. It is likely that it will be an active product, for example an extension to I2. But I do not think that earlier spring.
Re: OZ
Post by Михаил_ » Sun Oct 01, 2017 4:19
Вячеслав. wrote:Lord, someone is able to paint conventional landscapes untethering of place and time ) This is akin to iconography, along the way, I want to stipulate that treat religions with respect and understanding-to help you to enter the desired state.Not to zaplivatj you can create a separate topic in conversations about everything... for example,who knows how, in the context of this section! So myself and Express :)
That refers to something with understanding, it is necessary for a good understanding how these mechanisms work from the inside, who and what and how to use them and what implications it gives for the place/society/specific users, and so on. This is partly studied in some seminar topics.
Just what does OZ do ? t/e did not understand the connection.
OZ is the operator in the here and now. The first time and place is obviously the opposite.
The icons initially (a long time) has been used in another assignment (read the blog Vladimiro on LJ, there is lucidly and correctly described). About tvorceskoj let's say the topic. Well, then it went something else.
User avatar
Re: OZ
Post by Вячеслав. » Tue Dec 05, 2017 10:43
To study this state of OZ,so it is best prescribed not fast and not slow effects.From the product the algorithm of workmanship which I have used.
Some opening was amazing,there are lots of products the same Pandora - black as if from the outside feed the process... then OZ is the way its resources and actions based on its understanding.
Even at the time of recording through video, said one effect called him a "mounting point"... It to the health and relationships works well.T.e.in one case, for example, to resume Jogging in the other to break through the knee... :) alien ideology.
Re: OZ
Post by Михаил_ » Sat Dec 23, 2017 0:59
OZ really recommend the TRANSLATIONS. This is a soft way to integrate correctly these properties.
As for the exit "on your life", that is the basis of the condition of 3.0 and poderina (narrow particular case) OZ, as well as what is taught in the seminars of the first theme (by the way in the near future probably will open the entry for the new 1st free, but is still "open", probably would be before the end of March, when there are some many people who wanted a lot, have a sense to immediately for a large group of people, not to scatter human resource demo)
Locked
