Page 2 of 3
Posted: Tue Mar 17, 2009 4:06
by Бушуева
Tell me, how many games included?
mind reflection
Posted: Tue Jul 14, 2009 1:16
by МенталГеймер
Good day, friends
recently purchased a Mind reflection with games and want to ask a few questions:
-what do the colors of the indicator on the device
-what is the sacred meaning of konopacki on the device
-how best and where to mount the sensor. Usually attached to the fingers, as the girl in the picture, and also notice that if the hand to move, the ball will drastically change its movement
Posted: Tue Jul 14, 2009 12:30
by Андрей Кабанков
All this information should be in your user's guide to the Mind Reflection in one of the two attached to the games books.
Red led flashes when battery power is low.
Orange when loss of contact with the skin.
Short green flash-the unit is ready for use.
A button turns on the device and the indicator is solid red-yellow-green.
If you will lose contact with the skin,the ball will drastically change the movement.
Technical problems
Posted: Mon May 17, 2010 22:53
by Павел2863
Hello. When you start mentalgames2.exe gives message "...Progree_DB.cxt is not a Director file." The file itself is empty as all files with extension cxt in this folder. Reinstallation does not give result. What to do. Maybe CD is damaged? Can I download the package?
Posted: Fri Sep 10, 2010 0:05
by Амач
Finally bought the disc with the mental games, run through Hotstream really went without problems.
Now on first impressions:
1. It is possible to be engaged at level 1 need a little longer, but I have quite a long time spent trying to land this balloon at the target, and even took a NAP, but things are there. And what really there to talk about the last stage where you need the ball to hold without touching the clouds, someone was it passed?
2. Mine the degree of tightness of the sensor on the hand reacts much faster than galvanic skin response, a little chelonei and the ball in another place. Somebody tell me, maybe on my leg to shave the area and there attaches the sensor to avoid such incidents ?
3. In addition to level 1 and 2 on the Intro of the game viewed the following:
Level 3 - Emotion
Level 4 - Abstract
Level 5 - Mental design
Level 6 - Mental Meta
Level 7 - mental Trans
Somebody knows something about these levels and where they are in the case that you can preobresti?
Why nobody answered? Too worried
Posted: Thu Sep 16, 2010 1:10
by Guest
Posted: Tue Dec 14, 2010 15:03
by Раймондыч
Hello, friends!
Someone put the mental game on a seven?
Posted: Mon Dec 20, 2010 9:28
by Михаил 2
Раймондыч wrote:Hello forum users!
A seven do not know, tried on Vista, the program itself goes, but the device refuses Photstream not see him at all. Had to demolish and install XP, now it works fine.
Posted: Mon Dec 27, 2010 17:53
by Раймондыч
Good day to all!
Vista, however, not an indicator. A lot of hardware and programs refused to work on it. Seven of omnivorous slightly inferior to XP, but the risk is scary - great price mistakes. I would like to know the opinion of representatives of technical support, if any.
Posted: Sat Mar 05, 2011 18:39
by Лори-Мори
Раймондыч wrote:Good day to all!
Hmm... So no one answered about the compatibility with Win7...
Posted: Sat Mar 05, 2011 18:44
by Андрей Кабанков
On Windows 7 works.
Re: Question on mental games
Posted: Wed Dec 05, 2012 11:19
by Ъуро
Good day! On the box svejesobranna of Metalgama not light.Read the forum - I understand that the idea is to light up red (if the batteries) but no! What to do?
Posted: Wed Dec 05, 2012 11:33
by Андрей Кабанков
In operation, if I'm not mistaken, the light alternately blinks when the USB cable is connected.
You have connected the device to the computer, tried to use it?
Before sending all devices are checked for serviceability.
Posted: Wed Dec 05, 2012 12:17
by ЛИЛИЯ-Р
Ъуро wrote:Good day! On the box svejesobranna of Metalgama not light.Read the forum - I understand that the idea is to light up red (if the batteries) but no! What to do?
The "Guide polzovatelya" -a small booklet on page 7 describes what is the cause of flashing lights with a particular color. Do not blink at all ,unless batteries are installed in the device, or bad USB cable is connected. If the device is connected correctly,as described above ,the lights flash alternately.
Posted: Wed Dec 05, 2012 12:45
by Ъуро
The cable is connected, battery inserted, the manual to peruse.
by Ъуро
does not burn.
Posted: Wed Dec 05, 2012 12:47
by Ъуро
The computer gives a "Device not recognized"
Posted: Wed Dec 05, 2012 12:48
by Ъуро
It may need the driver any more? I have a 7-ka...
Posted: Wed Dec 05, 2012 13:05
by Андрей Кабанков
No, no driver needed.
Again check the batteries are installed correctly, do stuck all the cords, try to connect to another computer.
If does not help write to the post
mindmachine@bk.ru we will replace the device.
Posted: Tue Dec 25, 2012 19:19
by Павел Абрикосов
The problem is this. Over time, "while planting eyes" the program became less and less sensitive. Can't understand what it was until one fine day it ceased to appear, and at the bottom, next to the blue cube program startup, turns red ".com". Before you start in this place, a key test ports. Checked it out. There are no errors. Conclusion - over a free period or something. Registered, as written on the forum. But it did not help. The problem remains the same.
Posted: Tue Dec 25, 2012 20:38
by Андрей Кабанков
Most likely fell off the posting that goes from the metal kruglyashi on the sensor that is worn on the fingers.
Free term action program does not exist.
Posted: Tue Dec 25, 2012 20:48
by Павел Абрикосов
If only it were that simple... I installed it on the laptop, and it works)
Posted: Tue Dec 25, 2012 20:49
by Павел Абрикосов
Can add that the program prescribed in the registry is something indelible. I tried to remove all traces of it, but happened to see hidden files its a track that cannot be removed. So, after all, there's something...
Posted: Tue Feb 02, 2016 19:40
by ЯРинат
Hi all.
I bought a long time ago, somewhere 2010 MIND-REFLECTION. Launched. Then it was not before.
Help start resonant.
Computer that no longer exists. Disk no and I don't remember being on the disk.
The activation code is
Posted: Tue Feb 02, 2016 20:04
by ЯРинат
Hurray !!!!
Disc found.
Now try to register
