Page 1 of 12
Manifestation and Astro-Dynamic program
Posted: Wed Feb 17, 2010 17:33
by Шалтай Балтай
Karl
1. Do I understand correctly that there should some plug from PC to Radionic? If it be so, How does it look like? Is this a USB one?
2. What Radioncs devices support Manifestation™ Programs?
3. Does Manifestation™ Programs works only for Windows? What about other operation systems, Linux for instance?
4. What are the technical requirement for PC?
5. Do I understand correctly that in case I am dealing with Manifestation™ Programs I should NOT care about the dials (at the device), all the 'job' regarding the link between trend and target are performed by means of the program? Is this correct or in any way the dials are to be adjusted for better performance? If so - what would be the best way to adjust them?
Thank you
Posted: Fri Feb 19, 2010 18:43
by Владимир Никонов 2
Posted: Fri Feb 19, 2010 18:52
by Шалтай Балтай
it would appear it answers one question:
Шалтай Балтай wrote:2. What Radioncs devices support Manifestation™ Programs?
RAD-2000 and higher, I would guess
Posted: Mon Mar 01, 2010 19:47
by Шалтай Балтай
Шалтай Балтай wrote:1. Do I understand correctly that there should some plug from PC to Radionic? If it be so, How does it look like? Is this a USB one?
It would appear it does NOT. There is a structureal link between the prog and the regarding
Шалтай Балтай wrote:5. Do I understand correctly that in case I am dealing with Manifestation™ Programs I should NOT care about the dials (at the device), all the 'job' regarding the link between trend and target are performed by means of the program?
Nope
Posted: Wed Mar 03, 2010 12:26
by Шалтай Балтай
Шалтай Балтай wrote:3. Does Manifestation™ Programs works only for Windows? What about other operation systems, Linux for instance?
I tried to set the prog up under linux Mandriva 9.1.
Setup was successful but the program started incorrectly. There were no pictures at all - and it crashed pretty soon.
I will try to use VirtualBox - that should work
Posted: Wed Mar 03, 2010 13:15
by Шалтай Балтай
Received the disk with manifestin
at first glance it looks impressive
installation Tree
Code: Select all
/cygdrive/c/Program Files/HSCTI/Manifestation$ ls
Background Images
Images
Import-Export
Orgone Transfer
Saved Operations
Sound Files
SystemFiles
def
Magical symbols
Code: Select all
/cygdrive/c/Program Files/HSCTI/Manifestation/Images
9 Packs French
9 Packs German
9 Packs Italian
9 Packs New AoD
9 Packs Spanish
Abramelin
Action
AlphabetDesErfolges
ArchangelsDemonsPlanets
AstroSet
AstrologyPack
Backgrounds
Chakras
Classic Packs
Crystal Spirits
Emotions
FengShui
Kabbala
KeyofSolomon
Miscellaneous
PlanetarySquares
ShintoTalismans
Targets
Tarot
elements
feng shui
fixed stars
glyphs
gnostic
gnosticsymbols
hebrew
hebrewtalismans
houses
iching
planets
planetspirits
runes
runes reversed
signs
voodoo
Code: Select all
find . -type f -name "*.jpg" | grep -c jpg
2136
More than 2000 symbols of magic!
long can understand
Well there are Templates
Templates
Code: Select all
/cygdrive/c/Program Files/HSCTI/Manifestation/Saved Operations/Starter Templates$ ls-al
5-Position-Starter.RAD
BusinessMoney
Creativity
Gambling
Legal
Magical
Physical
Productivity
Relationships
The Mind
other
All Templates - 54
Here for example Templates for business:
Code: Select all
/cygdrive/c/Program Files/HSCTI/Manifestation/Saved Operations/Starter Templates/BusinessMoney$ ls-al
Attract-Customers.RAD
Brainstorming.RAD
BusinessSuccess.RAD
Good-Management.RAD
Marketing-Success.RAD
Money-Opportunities.RAD
Negotiate-A-Deal.RAD
Posted: Wed Mar 03, 2010 17:54
by Шалтай Балтай
That way even manifestacin from another manufacturer:
http://www.mysticalwonders.org/radionics-software/
Posted: Wed Mar 03, 2010 19:56
by Ванька-встанька
Maybe it works, but alarming presentation of the material, global discounts on a program and ...a lot more then. The site is made from ready-made designer again. My opinion - the program is garbage, not working
Posted: Wed Mar 03, 2010 21:55
by Новик
I don't quite understand but it turns out that it can be used separately from the device?
Ie Pro is a self-contained product that can Dowa the result?
Posted: Wed Mar 03, 2010 22:26
by Ванька-встанька
Новик wrote:I don't quite understand but it turns out that it can be used separately from the device?
I advise you to read carefully
https://mindmachine.ru/catalog/shop/manifestation/
Possible in principle, but it is better to use 2 anchors - as stated in the English proverb
Posted: Thu Mar 04, 2010 0:33
by Новик
Ванька-встанька wrote:Новик wrote:I don't quite understand but it turns out that it can be used separately from the device?
Read it read it Yes, but there was too much ageyou to purchase the device itself.....
So we can conclude that in itself it is not a full product.
Or there is the relationship between man and touch on the computer using that the transfer map?
Posted: Thu Mar 04, 2010 10:24
by Ванька-встанька
Honestly, I don't know exactly how valid transfer card (and also: does it have fields to fill in, can it be transferred to another person together with the program, etc.). But buy radionik-radionic program still have - read the posts above and in the adjacent forum thread about Radionics.
In my opinion Carl ought to include them in one set. Moreover, what is this simple little app as a modern operating system. But as they say "the boss" - and the final choice is always yours
Posted: Thu Mar 04, 2010 11:28
by Андрей Кабанков
I understand that the transfer card is placed on the field of trend,thereby expanding it to the level of the program,where a set of template trends,compiled by Charles on the basis of astrology and magic sets symbols.
Carl said you can just take pictures of trends from the program,receiving sets trends,then just put these cards on the field, a trend instrument.
by Шалтай Балтай
Ванька-встанька wrote:I Honestly don't know exactly how valid transfer card (and also: does it have fields to fill in, can it be transferred to another person together with the program, etc.).
Because use - otpishu
A very simple
The map (paper) - there is the text 'Life energy transfer' + number
Exactly the same picture+number (Jpg) on CD.
The Jpg is imported into the program, the card is placed on the trend Radionics voila a bunch ready. You can run the prog
Posted: Thu Mar 04, 2010 11:30
by Андрей Кабанков
The transfer map is an image having a match with one of the files in the program.Each individual card.
Posted: Thu Mar 04, 2010 11:32
by Шалтай Балтай
Ванька-встанька wrote:But to acquire radionic-radionic program still have - read the posts above and in the adjacent forum thread about Radionics.
This is a private matter.
The fact that You say of course makes sense.
The program gives a great opportunity but on the other hand You nobody enforces, for example, I can make my prog or buy from third-party developers
Ванька-встанька wrote:moreover, what is this simple little app as a modern operating system.
This is probably why - and go separately
There still is a super Manifesto - do - 500
Posted: Thu Mar 04, 2010 11:37
by Шалтай Балтай
Андрей Кабанков wrote:To each individual card.
The system is quite flexible.
It is possible for example to run multiple instances of the same program on a computer with various trends (business, magic....) and also razlichnimi targetapi (just different people) - all of them bind to one Radionics, and can and different.
It is clear, if you vspomnitj about these "hounds" as RAD-5 or ATG-12, where both operate on 5, 12 orgone generators (resp). Can office "to senisitivity"
Posted: Thu Mar 04, 2010 11:42
by Шалтай Балтай
Mmmm.... Yes, you can.
But the effect is weak. (this depends on personal qualities, intention, energy)
It is possible on paper to write what you want - this also works.
And you can Bamako and radionic put
Posted: Thu Mar 04, 2010 11:43
by Андрей Кабанков
I wonder if connected in parallel a dozen of these 12-orgone generators-on-one trend that will
Pulls great
Posted: Thu Mar 04, 2010 11:52
by Шалтай Балтай
at target - mozh will melt
Posted: Thu Mar 04, 2010 11:59
by Ванька-встанька
So he had soup and has a price of about USD 10,000 (in size resemble mackerski remote control for DJs), but who will buy them - that is the question. I apologize for the bluntness, but Carl elementary wants to "get more dough." Maybe someone will make a different conclusion, but I had exactly the same feeling.
About the imposition of will give a simple example with solar calculator: Yes - it runs on these batteries, in bright, Sunny weather, but in other cases you insert the batteries. Whether it's from the manufacturer's imposition of batteries? Yes and no
Posted: Thu Mar 04, 2010 12:04
by Андрей Кабанков
I think the demand will be,especially in Russia.Now people will understand how to twist the handle and start buying.While stopping in the first place the number of handles,not the price,I think.People in Russia who can afford to buy such a thing weight.
Posted: Thu Mar 04, 2010 12:15
by Ванька-встанька
If a potential buyer confused only the number of pens we zamami popular are the Junior model of Radionics
Posted: Thu Mar 04, 2010 12:49
by Логик
Андрей Кабанков wrote:is stopping the first number of handles
Until people stop the lack of instructions in the Russian language and General lack of understanding of how to work with miracle-devices. And unknown efficiency of appliances.
All hope for unselfish of eksperementatory!
And with the number of handles razobratsja. I was sitting at the mixing Desk. When you understand the General gist of the process - the number of different knobs and sliders, promises of refunds on the effects of groups of channels, mute and solo buttons, etc. are not scary.
Posted: Sat Mar 06, 2010 2:11
The use of a program for the realization of desires
