Page 1 of 1
Psyleron is not working on windows 7
Posted: Mon Sep 10, 2012 23:20
by Стаспси
Several times installed and uninstalled the TV series and driver do not see the program psyleron - possible to work with only the pseudo psyleron.
Please advise how to be. Manufacturers of 3-week silent. When was the XP system it was all good. It looks like the project psyleron finally closed(judging by the lack of response from manufacturers).
I would be grateful for advice.
Thank you.
Re: Psyleron does not work on windows 7
Posted: Tue Sep 11, 2012 0:53
by Михаил_
and why am I working then? under all types of Windows.
There is a standard driver, it is used not only pelerinaj.
Posted: Wed Sep 12, 2012 12:29
by Стаспси
Good afternoon, Michael.
Are you sure you are working with psyleron, not psyleron pseudo?
Thank you.
Posted: Wed Sep 12, 2012 23:01
by Дмитрий__
The problem is the place to be - at least on 64-bit 7-ke the device is not visible. Attempt to install the driver manually hung the system.
I apologize to Stanislaus for the delay in replying - just a little patience...
Posted: Thu Sep 13, 2012 1:02
by Стаспси
Thank You Dmitry.
I'll be waiting.
With Respect Stanislav.
Posted: Thu Sep 13, 2012 2:38
by димыч
if you tell a hardware ID, I will try to help
what it is and where to look view the link
http://ddriver.ru/kms_catalog+stat+cat_ ... ms-20.html
Posted: Thu Sep 13, 2012 4:04
by Михаил_
Стаспси wrote:Good afternoon, Michael.
Thank you.
sure sure, I'm not using native software, just the driver.
and my program tells me the number of actually discovered devices(I have many of them connected), the TV series and information for the data flow.
A pseudo is not from the API, and within the program simulation.
Another thing is that I have a 7ka 32разрядная, and now she and all virtual (Virt. machine parallelism, which started on Ubuntu).
I only vaguely remember what driver set once in a manual, but now can't remember exactly how long it was.
Posted: Thu Sep 13, 2012 23:04
by Стаспси
USB\VID_0403&PID_B5E8&REV_0600
Here is the ID
Thank you for your willingness to Help!
Posted: Thu Sep 13, 2012 23:57
by димыч
pichurova on the Internet found out that the chip responsible for USB communication with the computer
issued by the company FTDI, and is intended for an Amateur instrument that, in principle,
suitable for small-scale production of psyleron. Therefore it is necessary to try the driver from the manufacturer,
then it would be good to know the specific markings of the chip, but who will agree to open the casing?
a bit of information there is here
http://www.filur.net/index.php?mod=art&id=48
and the drivers on the manufacturer's website
http://www.ftdichip.com/FTDrivers.htm
on the left is the inscription VCP Drivers D2XX Drivers, there are 2 types of drivers, which of them do not know
try it, hope will help
Posted: Fri Sep 14, 2012 2:59
by Михаил_
IMHO there is slightly patchany driver, because when I put the driver chip for clone arbanowski Board from dfrobot, psyleron was paramali to work and then had to roll back the driver.
But if still not working then you can try.
Posted: Fri Sep 14, 2012 21:39
by Стаспси
Downloaded driver. And here is how to install do not understand.
Posted: Sat Sep 15, 2012 0:44
by димыч
downloaded the driver, have analyzed, it seems Michael is right, the manufacturer tweaked the
files ID of your device is fully out there, there is only VID_0403 is a manufacturer code.
the only way to find out the marking of the chip and put the drivers for it forcibly
I don't know, I posted a photo of the insides of psyleron, but if you can, take a picture and write to the PM
or just stupid to force install these drivers and try work, maybe something will work.
instructions on how to do it
http://ddriver.ru/kms_catalog+stat+cat_ ... ms-60.html
the downloaded archive to unpack in a separate folder first, and incite her
Posted: Sat Sep 15, 2012 22:49
by Стаспси
THANK YOU VERY MUCH!
I will try!
Posted: Sat Sep 22, 2012 13:46
by Дмитрий__
While the problem cannot be solved. The driver, even downloaded from the website of psyleron, on 64-bit system is not working. The manufacturer says that they are in the States so far, such problems did not arise - like people with 64-bit systems don't complain.
Posted: Tue Sep 25, 2012 14:51
by Дмитрий__
In General, a part of me the problem was resolved. It consists in the absence of (or at least, prepoznavanje) the digital signature of the device driver. This is how it looked in my case.
1. Set the driver to unpack the file reg1windowsdrivers.exe
2. Connect the device - it appears in the device list as non-performing due to alleged lack of driver.
3. Open that device by double-clicking and act according to the method specified in the message
dimych in his exile (this is just so I can avoid unnecessary paperwork). At this stage I have a critical system failure (blue screen with message about critical error at such and such address), and then the computer restarts. At THIS POINT press F8 and choose a way to boot WITHOUT CHECKING DRIVER SIGNATURES. - After the download, the device appears in the list as normal working.
4. Put FieldREG, Reflector and enjoy life.
Slightly overshadows its just that in normal mode the device still is not working. I'll try to podatocite digital signature of their own, the blessing, the means:
http://www.ngohq.com/home.php?page=dseo
The results will be reported.
Posted: Sun Feb 03, 2013 19:54
by Илья Черненко
Please help with drivers for XP. Not get them to deliver. native disk such feelings do not have firewood, as the system does not perceive them. And device ID USB\Vid_044e&Pid_300c&Rev_1915. What can I do?
Posted: Mon Feb 04, 2013 0:59
by димыч
your device called the Bluetooth USB Controller (ALPS/UGPZ6)
are you sure that it is relevant to Psyleron?
with CP in my long I have no problems here
Posted: Mon Feb 04, 2013 12:51
by Дмитрий__
Ilya Chernenko
Your actions (if Your device do psyleron):
1. Install the driver according to the steps described in the user manual
2. Misleading, at which stage there is a failure and describe his character.
Posted: Tue Nov 22, 2016 16:20
by Шалтай Балтай
Дмитрий__ wrote:2. Connect the device - it appears in the device list as non-performing due to alleged lack of driver.
not appearing
BUT
to be honest, tried to plug device WITHOUT installing droff. There were reports errors. I have them covered. Then put the driver. Then when you connect the device nothing happens
PS
It is this psi
Posted: Tue Nov 22, 2016 19:06
by Дмитрий__
Install the driver again. But not unpacking the distribution and control panel showing the folder where they are already folded after the first installation. On 32 bit systems should work without problems. On 64-bit as lucky.
Posted: Fri Nov 25, 2016 16:43
by Шалтай Балтай
I put the wood hands REG.sys drops system with a blue screen some there the address....
