HOW to POLLIAT CONSCIOUSNESS ON RANDOM number GENERATOR casino
Check the connection between human consciousness and physical world
Post Reply
User avatar
лексветер
Post by лексветер » Tue Jan 17, 2012 1:23
Random event generators (REG).
We begin with the simplest part. Random event generators REG or is essentially a high-speed electronic analogue of the usual coins. Instead of an eagle and tails REG produces the pulse: plus or minus. These pulses are converted to 1 or 0, or bits of information, which operates the computer. Bits can be counted as the number that they were given well-known mathematical distribution of random numbers. Therefore, REG is also often called a random number generator (RNG), and last name similar to the name of some computer programs that generate actually "pseudo" random numbers according to a given algorithm. REG primenimy in the project differs from these programs in that it gives a really unpredictable number, or an unpredictable sequence of ones and zeros.
The project uses three types of REG. They are all electronic, and they are sources of "white noise" that is produced completely unpredictable quantum fluctuations. For example, the work of REG used in the laboratory PEAR based on Johnson noise or fluctuations in the flow of elektronov in the resistance, which is due to thermal effects. The ORION work is based on two diodes , each of which generates two random bit stream independently from each other. MICROREG applies a special effect transistor (FET) as a source of "white noise".
2. The effect of consciousness
A clear or complete understanding of how our minds, thoughts or emotions can affect the behavior of REG is missing. We think that resonance and coherence are good definitions-metaphors for understanding the effect of consciousness on REG. We find some useful accents in models of David Bohm, which operate with the concept of active information, however, we expect that the global consciousness effect is more than just a connection with nonlinear dynamic models. But we don't know what mental state the type of intention or emotion can affect the physical system. In addition, all the data that we have in evidence the influence of consciousness on the physical world is statistical in nature, and the ratio signal/noise is extremely low. This means that we usually can't be completely sure that anomalous readings specific, one REG is due to the influence of consciousness. Random fluctuations certainly exist. But when we collect the weak signals from many separate events, we can see that trends and the structure of the data was due rather to the influence of the conscious field.
However, we can say quite definitely that the effect of consciousness on the behavior of REG is quite measurable. Something like "conscious field" exists in reality, and the emotional state of people passed some information that can affect the behavior of unstable physical systems. Data REG would have been different if the influence of consciousness was not.
3. Measurement
We get data from REG that output a stream of random bits of information. Each EGG produces packets of information from the packet per second. Each package consists of 200 events . Software on the host computer (host) outputs the sum of zeros and ones in each package. If zero and one are thrown out purely by chance, the number of zeros and ones separately should be close to 100. Random fluctuations exist, but they have to give in the General case, the well-known bell-shaped curve distribution of random numbers. The most frequent result should be close to 100, and only few packages can give less than 70 or greater than 130 zeros or units. Distribution for a large number of packets are quite predictable, although it is impossible to predict the results in each packet of bits.
Our idea is that we can use the scale of the variations of the numbers in each package and unusual deviations from the expected average value to explain the influence of some factor. If, by analogy, you throw a coin many times and get a significant deviation in the number of tails from the average value, it is possible to suspect that the coin is "wrong". Years of laboratory experiments have shown that conscious intention can influence the behavior of electronic devices like REG. These experiments were conducted under controlled conditions. In the field studies have shown that in certain situations when there is reason for "a certain coherent group consciousness", there is a deviation of data from expectation. How would the zeros or all ones are emitted by the generator in these cases more or less often than it should be according to the distribution of random numbers.
4. Group consciousness
Our data show that if people are United in certain groups through the concert, meditation, prayer, or some ritual, the REG produces an ordered sequence of zeros or units, which deviate from pure random sequences, and we one or the other of accuracy can predict this deviation.
5. Network EGGs
Definition : a computer that has a REG, is called the EGG or "egg". A network of such computers on the INTERNET creates a network of "eggs" or EGGs network.
At our disposal there have been instances when some of the events that took place thousands of miles from REG, still affect him. We therefore adopted the hypothesis that all the world may become a "group" in those cases where some global event that attracts the attention of a large number of people. To test this hypothesis we have established a network of "eggs", consisting of the REGs that are connected to computers that have permanent access to the INTERNET and appropriate software. This software records the data stream from the REGs and transmits them to a Central server at Princeton University for statistical processing and storage. Network EGGs operates in the continuous mode, since August 1998, and their number gradually increased and by December 2000, reached 37. In November 2002, the number of EGGs is 56.
6. Global Consciousness
In the Global Conscious Project for each EGG and for their entire set we predict a measurable streamlining data flow in a continuation of the events that will attract the attention of large masses of people. These data streams have a very definite expectation and we just look at the empirical statistics to see if they match with our expectations. And we see that something is happening with our data during global events, not always, but often enough that the odds ratio in favor of a purely random explanation is about 1 to 1000. In other words, there is only one chance in a thousand that the ordering of the data is due to purely accidental causes.
7. Conscious box
Why is there some effect of influence on the device REG, when billions of people celebrate the New year, watching the funeral ceremony of some of the world's personality or record the beginning of the war? Although it may be just a concept, but it is useful to assume the existence of a "field of consciousness". You can imagine that each mind radiated into space a package that communicates with another information package and creates some interference packages depending on our intentions, desires, or emotions. Perhaps this is the conscious field takes the information from our minds, which affects the behavior of random electronic devices. It is important to emphasize that the human race must experience some similar emotions, reactions, feelings, global events, and this generalized flow of universal information somehow interacts with the physical matter, which shows the behavior of the REGs.
WHO THAT KNOWS ON THIS SUBJECT AND IS NOT AFRAID TO SHARE! For MANY it will be interesting! Thanks in advance!<
User avatar
Has thanked: 1 time
Been thanked: 182 times
Re: HOW to POLLIAT CONSCIOUSNESS ON RANDOM number GENERATOR KAZ
Post by Андрей Кабанков » Tue Jan 17, 2012 9:44
Moved this topic here from "Talking about".
Right here these issues are under discussion.
In a casino,as far as I know no devices operating on the basis of physical noise generators,a generator is a program,and in fact it is not a random generator.To win the casino should be more talk about the need not to affect the generator,and to be in the right place at the right machine at the moment when he is going to give money.
I have at one time worked employee playing machines.Zakonchilos all the huge debts,the collapse of the family,layoff,most likely in the end he killed himself because no one else has seen for many years.
Judging from my experience,to win in a casino is much easier to get into the resonance with a human dealer roulette,not just hit on a solid streak of wins,but it rapidly suppresses the Manager,changing the dealer after replacement to play at this table have no meaning.
User avatar
лексветер
Post by лексветер » Tue Jan 17, 2012 18:27
The question is open for online casinos where the system works supposedly for the random number generator ROULETTE! HOW to affect this generator!
User avatar
Has thanked: 1 time
Post by Андрей Кабанков » Tue Jan 17, 2012 18:44
In any program of generating random numbers further depends on the number of the previous numerical range.
What you have described above, refers to the hardware generators based on physical processes.
Want to win at roulette,use devices to influence events,just the goal of winning at roulette,without any guessing specific numbers.No matter real or roulette Online.
I played roulette twice a year in Vegas and never in red has not been using the recommendation.
One time big win,accidentally putting the past where I wanted to put.
Астранавт
Post by Астранавт » Wed Apr 18, 2012 17:41
Here was a discussion in a similar context:
http://www.upad.ru/viewtopic.php?f=2&t=956
User avatar
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Post by Ланцелот » Wed Apr 18, 2012 21:11
And if you go the other way.
Winning in a casino is a special state of "man". Record and replay is a condition in hardware. How big is the probability of winning, though not in the quantity or volume of mnt, but at least, to stay in the black?
User avatar
Has thanked: 1 time
Post by Андрей Кабанков » Wed Apr 18, 2012 22:31
There seems to me not only as a player, usually when you come into this strip, as it is a mental zavyazyvaetsya with the dealer and he throws out what you need. This was closely watched managers and as soon as you see this streak of luck, change the dealer. This, in my experience, it is safe to leave the table.So as there is more interaction to the dealer.Recorded in one case, the state probably will not work in another context and is not universal.
I already noticed one lady dealer at the Bellagio, well, we are not trying to play with her , never once won a single bet. Conversely there are the dealers , who almost always bring you a win.
User avatar
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Wed Apr 18, 2012 22:40
Read the book one American. He does Castaneda and play in the casino.
He writes that
1. A large amount of personal energy helps you to win.
2. Casino is a parasitic structure that can drain from a person's almost all the energy, no matter how much a lot of it may be.
The longer you are inside the casino there is less energy and more likely to lose. The author is not recommended to be in the casino more than an hour.
User avatar
Has thanked: 1 time
Post by Андрей Кабанков » Wed Apr 18, 2012 22:59
Generally casino the interesting thing is, even if you don't play, it can be a lot of interesting things to notice in terms of the human impact on the result of the roulette game.
For example, if several people put large sums on a bet on color ( the probability of winning is 1 to 1), then his energy of waiting, they take away the win, and in 9 cases out of 10 lose.
Or, if someone persistently put on one color and it all fell out and blew the money, then the next color after the game is just that he's been waiting for.
I noticed some pattern, and use them in the game.
User avatar
Димас
Сотрудник mindmachine.ru
Post by Димас » Thu Apr 19, 2012 0:46
Andrey Kabanov
Yes, it's almost all the way only to spit (let go), everything just falls into place. In a casino it happens quickly, as if there is no money, so why not let go (and before it was invested in a desired sufficient quantity of energy), and therefore falls to the desired color. Yes, and Murphy's law has not been canceled :)
Дмитрий__
Been thanked: 27 times
Post by Дмитрий__ » Thu Apr 19, 2012 11:21
There are many different tantric practices, attracting prosperity. In addition, there are specific "essence", the patron of the players in gambling. With them is also theoretically possible to establish a connection. The problem is that the practice of this level of money has not particularly catchy. Not to mention the excitement.
ПОЛОТЕНЧИК
Post by ПОЛОТЕНЧИК » Fri Mar 20, 2015 18:43
In online casino roulette and similar logic games laid the formula for calculating the drop in the number depending on the rate, and only sometimes , it switches to the RNG. To win at the odds is almost impossible. I use extra RNG to determine the shift (displacement) of the roulette table and just calculate the odds with him to identify the "distortions midrange" on the chances. When "distortions midrange" define a new sequence and play SCH not on the chances and the midrange (there is also a bet amount to the game involved the RNG). If you constantly invent their own numbers, the formula roulette still calculate opposite to the expected result "if you so, then I'm different" or involve RNG.
KRC. Casino is not so simple.
нева
Has thanked: 21 times
Been thanked: 90 times
Post by нева » Sat Mar 21, 2015 0:56
Still..I wonder..in gambling games.the law of the inverse sine, the formula can't remember...but the point is.. that..if you will play..one of two..type deepe red..or black..or even-odd,I never 50na50..will not work in series..one hundred..and work on & nbsp; 30..70 this can be verified empirically..making 100 throws of a coin..)
and when the casino all honest(which is doubtful)..you should..just for statistics to watch.in the series...since that time, as you prescribed..and not there..flog..your stats..and then will become clear.)
Statistics are a great thing..)
And..the game is better to build than to try to influence...because with foul play you can win realizing what was happening...just like at the fair play you can play..not understanding what was happening..
User avatar
Has thanked: 1 time
Post by Андрей Кабанков » Sat Mar 21, 2015 14:17
In a casino, in my opinion, all is fair. No deceptions there, with the exception of errors of the dealer which are sometimes in one direction or another. If we're talking about roulette, the casino profit is zero in Europe and zero and double zero in America. Initially, the chance of winning/losing is not 50/50 , as it may seem. Here again and running statistics on a global scale , on average, every 16 hit ball for American roulette is 0 or 00, when all bets burn up in favor of the casino, except those that put on these numbers.
арте:м
Been thanked: 8 times
Post by арте:м » Sun Mar 22, 2015 0:39
the topic is "how to influence consciousness on the RNG", but such influence is already constantly happening. described many experiments on the role of the observer in the generation of random sequences and the influence on their character, even without any conscious effort. referred to on this forum pilinovsky sensors, and mental play is one of them. you can even easily check by purchasing a certified to work in a casino quantum hardware RNG based on the count passing through the semitransparent mirror single photon, the choice of which "does" the photon then ceases to be random in the presence of the operator and you can say the begins information about it (the statement) current state of consciousness to encode.. so rather, the question should be put: as on the contrary to avoid the influence on the RNG to not to disturb him behave in a predictable manner (being truly random). and "close" it not only its influence but also from the superposition of the expectations of all other active session players, who do not know the internal algorithm casinos for the transformation of electrical signals from the sensor in the numbers, you won't be able to consciously want the original sequence to itself to form.
Post Reply
