Page 1 of 2
frequency 30 KHz
Posted: Sun Apr 22, 2007 4:54
by индеец
What affects this rate?
And some say that it kills ALL the parasites in the human body. How can it be true?
Posted: Mon Apr 23, 2007 11:31
by Dimas
Wah....first time I hear about parasites!!!
In General, it is beta waves...Appear when arousal and readiness to act...
Posted: Wed Apr 25, 2007 4:59
by индеец
DemAs, betta wave is 30 Hz, and a question for you about 30 KHz (30000 Hz).
Posted: Wed Apr 25, 2007 11:10
by Dimas
I so read carefully!
And that can reproduce these frequencies??(by the way)??(of course the cream of echofon)...If these frequencies kill parasites,so parasites do not kill...Or the documents they ask(frequency)???
Posted: Thu Apr 26, 2007 3:25
by индеец
Device (generator) wires, wristbands. The authors argue that kills germs, viruses, parasites. It is logical to assume that if it works, then killed and the beneficial microflora, too, but it is then restored with buttermilk.
So I think, like a Scam or possible?
Posted: Thu Apr 26, 2007 11:41
by Dimas
Индеец wrote:Device (generator) wires, wristbands. The authors argue that kills germs, viruses, parasites. It is logical to assume that if it works, then killed and the beneficial microflora, too, but it is then restored with buttermilk.
I think the stuff some...Well a device that can create something there,but that's about germs and parasites...Apple uses with water and honey drink 20 days,no parazitov in the abdomen( and anywhere else) will remain!!!
Posted: Fri Apr 27, 2007 3:25
by индеец
Only a stomach ulcer...
To stomach-there's many herbal teas cleansing, and count up one man worms in eyes crawled!!! Inside... YOU five stars!!!
Posted: Fri Apr 27, 2007 15:17
by Dimas
Posted: Sun Apr 29, 2007 14:20
Abroad there is a device Zaper (not responsible for spelling), and we have stripped it Paracelsus who use weak electrical currents with various frequencies, including this one. In international forums, I often come across posts from users that it's total garbage - does not work.
We at the Department conducted research on the effects of pulsed magnetic field on slozhnosochlenennogo various microorganisms and insects. In principle, we can say that the effects are actually depends on the linear dimensions of the body. There were even samples of existing instruments under the influence of which the cockroaches were literally built a pillar and crawled, or crawling (depending on settings). But in consumer goods, these devices failed because they required fine-tuning on the configuration and volume of the room.
Why am I writing all this?.. To what does not exist and can not exist one frequency for all parasites, since different parasites different sizes. In the same Sapere and Paracelsus frequency wobbles constantly, capturing a fairly large range, and they write that the effectiveness of either small or non-existent.
Posted: Mon Apr 30, 2007 19:58
by индеец
In-in... Paracelsus... I mean...
Write: frequency 30 KHz plus or minus 1.5%.
Is sickly...
Reviews of users on the website and all that...
So why do some devices work and others not?
The principle of a one...
Incidentally, some time ago was advertised ultrasonic otpugivateli mice and rats. So after some time and a critical amount of useless purchases has been recognized nationwide that it's all garbage!
So what's the catch?
Posted: Wed May 16, 2007 21:03
by игорь
There is no trick.
The technique works when used correctly.
Have 5 years of experience........
Posted: Mon Oct 08, 2007 1:35
by Константин_
So, the fact of the matter is that each kind of parasites your corridor frequency in which they need to harass. 30 kHz is a common frequency to eliminate the parasites, which kills only the largest individuals, and they usually contain smaller parasites that continue to exist.
Correctly say Igor, it works on the correct application techniques
Posted: Mon Oct 08, 2007 1:42
by Константин_
Somewhere in the network there is a book Hilary Clark, "there are no Incurable diseases", she had mastered the techniques of tseppinga(zepping) parasites
Paracelsus 7
Posted: Wed May 21, 2008 18:26
by Доктор
Dear!
Do you know elementary physics. The parasite sits in man, and different in different environments. Passing through human impulses, part of their Bogatitsa by man, etc. But even assuming that killed the parasite. But apparently the developer somehow missed this question, parasites, and everything multiply, not live waiting for a verdict, and cysts, for example, none of these impulses do not act, and it is from them we get a bunch of new parasitical that also want to reproduce. Think soberly...
Second, you want to check the device, easy!
1. Hand before treatment analysis of IgA, IgI, IgG parasites.
2. Spend treatment.
3. A month later repeat the analysis. If antibodies do not decrease and may, moreover, marked increase in, the device against these parasites completely useless.
We have such data. But the reverse, laboratory confirmed diagnosis laboratory confirmed cure - no.
Will send how the doctor will be very interesting.
Paracelsus 7
Posted: Wed May 21, 2008 18:30
by Доктор2
totally agree!
A book written by the Gods???
My dears, books are written the same as You and me... and there is no one who would know everything... analyze THIS!
Posted: Wed May 21, 2008 20:29
by аурик
What to drink against parasitoid , and then I spent a year in India
Posted: Wed May 21, 2008 21:03
by Фипыч
aurik
After we traveled to Altai horses for us Easterner friend Zentel gave. Sort of prevention.
Posted: Sat Aug 02, 2008 7:54
by Игорь-7
Paracelsus-7 helps! I ordered it a week ago. The device even has not yet come, but the positive trend already is!
Posted: Sat Aug 02, 2008 7:56
by Игорь-7
see previous post.
I have them on the website sent this here opinion. Interesting, publish it, or still guess about the mockery?
Posted: Sat Aug 02, 2008 8:05
by Игорь-7
And the website-they have done very well. The phonies are becoming more sophisticated and isoscene. No one is saying that these are very clever people, because they really have to be a genius to sell a piece of the PCB in the plastic with the battery cost 50-70 rubles for 13 (!) thousands of wood! But the people are, I watched the dynamics of their sales, and even according to her at least half, then these idiots have about 3000 a month! The placebo effect, of course, has not been canceled, but not in such quantities!
Posted: Sun Aug 03, 2008 15:41
by Инкогнито..
A drowning man clutching at a straw.. If You promise a solution to all your problems for a certain amount of money..Why not.. what if???))
PS. And the post that are not there)
Posted: Fri Aug 08, 2008 14:04
by Бедный Котейко
Imagine how the placebo effect operates on parasio and they build with whooping and whistling leave the body in droves, what is very difficult life master who has to sit in places not so remote to be comfortable to release them.
Actually I read somewhere in the net that in Mexico something used in hospitals to increase the efficiency of medicines.
I'm still on some website I read that mindmachine is also a Scam - so it's not really clear.
Posted: Fri Aug 08, 2008 16:43
by Фденс
The organizer of Parasitology in Russia, the academician K. I. Skryabin, anticipating the dreadful prospect of infecting worms, said: "Neither economic prosperity nor the full income or the holding of mass events ozdorovitelnym will not give effective results of the recovery, if the country remains a General lack of awareness". So let's take a closer look at the science of Parasitology, which was banned in the 60's, and maybe even help your family and yourself the treatment of "incurable" diseases.
Not ethical to discuss this issue - all questions in PM, but if anyone is interested note: you don't have to kill parasites (not a problem) and bring them so as bring dead problems much more alive. For this there are special techniques appropriate to species and location. They are, oddly enough, not complicated but you need to make a computer bioresonance diagnostics required, and on equipment such as OBERON and the like. Body cleansing is desirable to 2 times a year. Where and how to get and poluchitsja - ask, I will give the exact coordinates in the surrounding areas where you live. About * Zentel * is a compound of inorganic chemistry ... We use only herbal remedies that have no idea of overdose. After a course of prophylaxis (approx 1.5-2 months) again you will do the diagnostics for reliability.
Standard program (the performance of at least 85-90%)
1. Chlorophyll, 1 tsp in a glass of warm water for 30 minutes before eating.
2. Under Arco at 1 drop 3 times a day during meals.
3 Black walnut 1 cap 3 times a day during meals.
4. Cascara to 1 cap at night.
5. HP fighter 1 cap 2 times a day during meals.
These drugs are required to have a certificate *GMP*
help-prompt
Be healthy!
Posted: Fri Aug 08, 2008 17:51
by ВитаКон
Childalert -inventor of zipper -hiding out in Mexico against all claims peredavlennyh her patients and their relatives in the United States.Yes, IF SOMEONE actually INVENTED the DEVICE.THAT CRUSHES ALL VERMIN.SO HE WOULD IMMEDIATELY NOBELEVSKOI AWARD WAS GIVEN.And all sorts of cool burzhuiny dragged the generators which are constantly connected and would live forever.But this whole thing is retarded.that physics in school is not taught.Clark gives a frequency table.what Bazil what frequency to push and how to determine what Bally sit in the body.supposedly they are also some frequencies radiate.But if you think critically-what instrument can detect radiation such as chlamydia.that sits inside human cells?Not so long ago American scientists created a powerful new device \a device for monitoring the human brain\So the biggest problem was the fact-and as it is shielded from external electromagnetic field of the earth.So the human brain generates hundreds of times more energy.than chlamydia and it is problematic.
Posted: Fri Aug 08, 2008 18:05
by Dimas
Vitakon
Reasonable!!!!!
