Page 1 of 4
Instructions and how to handle m/machines.
Posted: Tue Apr 17, 2007 1:11
by вероника
Hello! Acquired a machine InnerPulse and began to listen built-in the alpha session. The goal is to learn to relax (after many years of stressful situations completely forgotten how to relax). The result is, but have any questions. Or am I doing something wrong or the machine was acting up. It began with the fact that he decided to set session i02 preferred, ie so that when you turn the machine on, the display flashed to it. Did everything according to the instructions (Russian translation), but when you start i02 was not. Decided to repeat: logged in PPr mode , pressed PLAY, and the lights didn't want to blink. I think that's why i02 and not preserved. What to do? Next, try to upload session Patrushev. Did everything according to the instructions, highlighted 25 (apparently, the possible number of injection sessions), downloaded, shows 22. Looking for in the machine – not. Connect again, it shows again 25. Tell me, what am I doing wrong. Figured maybe I hit settings and it's back to the default settings. In the Options section menu information (in English. because the Russian translation of this part is not) found the option dEF as I understand it, it returns to the default settings, but can't find it. Included in oPL mode, read everything inside: oFc, obr, bSd, brP, icS, and this dEF is not. Tell me how to meet her? I do not understand with machine something not so or with me?
Posted: Thu Apr 19, 2007 2:16
by Владимир Никонов 2
To set the default session you need to:
1. Using the "Down" button to select "PPr"
2. Click the "Play"button
3. Select with the buttons "Select", "Up" and "Down" session that you want to remember(it will be included when you run mindmachine)
4. Two times to click on the "Play"button
All.
Posted: Thu Apr 19, 2007 2:31
I do Not understand with machine something not so or with me?
Veronica, with the machine and you're all right. All right, settings to reset until you need it. Try to upload session again for the user.
Later detailed answers to your questions.
Posted: Thu Apr 19, 2007 13:13
by вероника
Vladimir, thanks for the reply. That's exactly what I did, but the point is that after: 1.By “Down” I chose “PPr” 2.Pressed “Play” (for the user the indicators should blink, and they don't blink. I noticed after I was unable to set the default session). Next: 3.Select with the buttons "Select", "Up" and "Down" session that you want to remember (chose i02) and 4.Double-click on the "Play" button. Then turn off the machine, and include in my display again the old session. But I would just manually pick the session i02, according to the recommendations Patrushev alpha session, it is necessary to work for 2-3 weeks and after anyway I chose would have been different. The fact that I can't upload session Patrushev, and also operate strictly according to instructions. Have downloaded the program LSlib and 3 sessions on the computer, after you Chek System Connection program showed 25 available sessions of the 250 segments, then added 1сессию and pressed Download Session(Append). The program showed 24 instead of 25, but the lights on the machine again, not ran. Pressed Play, and pressing Chek System Connection program again it shows 25 free sessions their 250 segments. That's why I tried to reset to dEF, but this option I cannot find. I also want to thank You for the interesting information You post on the site.
Posted: Thu Apr 19, 2007 14:54
вероника wrote:Vladimir, thanks for the reply. That's exactly what I did, but the point is that after: 1.By “Down” I chose “PPr” 2.Pressed “Play” (for the user the indicators should blink, and they don't blink. I noticed after I was unable to set the default session). Next: 3.Select with the buttons "Select", "Up" and "Down" session that you want to remember (chose i02) and 4.Double-click on the "Play" button. Then turn off the machine, and include in my display again the old session. But I would just manually pick the session i02, according to the recommendations Patrushev alpha session, it is necessary to work for 2-3 weeks and after anyway I chose would have been different. The fact that I can't upload session Patrushev, and also operate strictly according to instructions. Have downloaded the program LSlib and 3 sessions on the computer, after you Chek System Connection program showed 25 available sessions of the 250 segments, then added 1сессию and pressed Download Session(Append). The program showed 24 instead of 25, but the lights on the machine again, not ran. Pressed Play, and pressing Chek System Connection program again it shows 25 free sessions their 250 segments. That's why I tried to reset to dEF, but this option I cannot find. I also want to thank You for the interesting information You post on the site.
Veronica, try to make Download Session(Clear). Inspect deeply inserted in the socket for plug points.
Posted: Thu Apr 19, 2007 15:31
by вероника
Andrew, the plug is inserted deep enough, there is no deeper. The program captures a car. I tried to do Download Session(Clear), then again the same thing. Possible marriage or breakage and how it to learn? Drive in service centre can't because I live in Kaliningrad.
Posted: Thu Apr 19, 2007 16:13
is it Possible to marriage or breakage and how it to learn?
Veronica, think about the good
Everything else works?
You just need to in order to understand the problem. Apparently at some step error occurs in the action of the user.
Try to set the default session. To reset is not necessary, make sure that you in step 4
2 times quickly press the "Play"button.
Reset and search for DEF you to anything, it's another topic.
If it is possible to consistently describe the fix sessions, right on the steps, maybe send screenshots to understand what could be wrong.
Posted: Thu Apr 19, 2007 16:19
Can still be not the machine for injection exposed.
Posted: Fri Apr 20, 2007 1:07
by вероника
I'm trying very hard. Just for relaxation and positive mood and bought the car a little earlier discs Patrushev. Huge thanks to him!!! Though not in the subject, but for many years I have not had this feeling, like after the first listen of the Conductor. After the second great reluctance of the 3 classes, and after that everything is just great. To part with the Conductor wanted, but decided to stay and started Healing. Somewhere in the middle came the m machine continue to listen to her. Thank You, Andrew, slowly coming back to life (for Your advice on the forum in parallel learn the Sedona method), if the shackles come off. Now of fix sessions:
1.Have downloaded the program and LSlib 4сессии.
2.Installed the program Lslib on the computer and unpacked archives with the sessions.
3.Hooked up the machine to the computer using the cord from the kit.
4. Turned on the machine, ran the program.
5. In the top pane of the program choose File then NEW, in the box Device chose InnerPulse. Press Download, then Select Com Port, specify COM1 and press Chek System Connection. The program captured the machine and showed 25 free sessions
6.Then click Add Session, select R01 And morning
7. Click Donwnload, choose Donwnload Session(Append). Fun, running lights, favorite cars, not to see, and the indicator shows the built-in session. But the program shows 24 available sessions and 223 of the segment.
8.Just in case I press Play, goes the count and it is the old session. That's all. If you double click Chek System Connection program shows again, 25 sessions instead of 24.
Can you send a screenshot to email if necessary. Because I do not know how to post them on the forum.
And in the default session in step 4 on the Play button, quickly click 2 times.
While listening to the built-in session (embedded work) and finish Healing. After going to engage in the Massage of the Brain. I want to hear this session Patrushev on the forum about them speak well, and I already know it's in absentia.
Posted: Fri Apr 20, 2007 9:18
Veronica, the archive not 4 sessions, but three. One file is the program file for downloading (library). Try to open it from this program, there You will see 3 sessions. On the file menu, locate and run the check path. Select the download library clear. If ogniki still does not appear, just in case, turn off and turn on the machine and click select search category "u". There should be three sessions u1, u2, u3.
Posted: Fri Apr 20, 2007 14:10
by вероника
Andrew understood:
1.Opened Alpha.LSL. First, the program said that session are invalid.
2. In the file menu launched check path and changed the path for the sessions. The program said that a session is now valid. There really was 3 sessions.
3. Chosen download library clear. The lights never ran, but the program showed that only 22 session.
3. Turned off and turned on the machine and click the select spinning: P. 0.1., d.0.1., S. 0.1., L. 0.1., E. 0.1., c.0.1., F. 0.1., b.0.1., i.0.1., r.0.1.
Friends, I'm uncomfortable to torture you. Most likely, it is still something with the machine. Thanks for the help. While I listen to the built-in, in the case of passing the car in Moscow.
Posted: Mon Apr 23, 2007 13:10
by Dimas
the typewriter isn't the case...I have the same garbage was...the whole problem is that and which library to pull...And what You're downloading,if not a secret?Session Patrushev?
Posted: Tue Apr 24, 2007 17:45
by вероника
Dimas wrote:the typewriter isn't the case...I have the same garbage was...the whole problem is that and which library to pull...And what You're downloading,if not a secret?Session Patrushev?
Yes. Tried to download session Patrushev. The fact is that is not working and the other files were not significant. I was contacted by A. Kubankova and he offered to replace the machine, so when the event will give machine, and they already see, am I confusing or should be changed. I think the latter. I just don't know how else to try to download. Tried in different ways.
Posted: Tue May 29, 2007 13:03
by Андрей Кабанков
Today tested Verenikina the machine - all fine.
Threw in session Patrushev.Use
Posted: Tue May 29, 2007 13:05
by Dimas
вероника wrote:Dimas wrote:the typewriter isn't the case...I have the same garbage was...the whole problem is that and which library to pull...And what You're downloading,if not a secret?Session Patrushev?
Don't forget pomenyat batteries!!!
Posted: Tue May 29, 2007 13:34
by Pavel
Here searched this topic, but about the power supply not found.
Here gain extra points and need a separator for innerpulse to the two listening session.
My power supply (6 volts, 300 mA) can survive in this mode?
Is there any instruction how to apply/to use this mode for two?
My innerpulse will not die from this depravity?
Posted: Tue May 29, 2007 13:44
by Dimas
separator buy no problem,in any radiolarite not more than 1& is..Stick a divider in it to stick 2 points,and enjoy,leaving the power supply 6 volts..no problem.
Posted: Tue May 29, 2007 16:13
by вероника
Andrew, thank you!:D Waiting for the machine eagerly. If I again won't be downloaded other sessions will torture You. Dimas, the batteries will change, but the cause could not be a battery. Probably, I something not so did.
Posted: Tue May 29, 2007 16:19
by Dimas
The reason was that by default there is COM1,settings, it will need to put it on COM2,plus had dead batteries...and everything works great.I,Veronica,set 3 session Patrushev.U-1-alpha morning,a U-2 alpha training,U-3 alpha night...Enjoy!!!
Posted: Tue May 29, 2007 17:08
by Pavel
Dimas wrote:the Reason was that by default there is COM1,in the settings you need to put on COB2,plus was a faulty battery...
Little opus:
The first rule of DIY repair: always check the wires
The second rule of DIY repair: always check connections
Third rule of DIY repair: always check the nutrition
The fourth rule of DIY repair: always check the user manual
The fifth rule of DIY repair: check the first four rules a few times.
If the fifth rule will not help, then you should call an expert.
In my experience that almost all people the solution to the problem fix new device lies within the first four rules.
Posted: Thu May 31, 2007 16:10
There is one Golden (on their skin checked) rule: "Before you disassemble the installation cost $ 65,000, check the fuses!"
Posted: Tue Jun 12, 2007 13:59
by вероника
Dimas wrote:I to You,Veronica,set 3 session Patrushev.U-1-alpha morning,a U-2 alpha training,U-3 alpha night...Enjoy!!!
Enjoy!!!
Posted: Sat Jun 30, 2007 22:42
by Селя
I do not understand, the bug that you have a forum? Wrote a post, try to view it or send me again requests a username and password.
So I don't know, there was a message or need more time to write.
When buying Innerpulse was Russian instruction at Novapro, and on the very inner English. With Spectacles Colortrak - English instruction. This is everyone or just my luck?
Posted: Sat Jun 30, 2007 23:41
by Андрей Кабанков
It's not at all.Just made a mistake by putting the wrong.On Monday You will receive instructions on the mail.
Posted: Tue Jul 03, 2007 9:47
by Сперанца
I'll ask here.
I have not approached the wire from the machine to the laptop.
The one with the side prong for the machine and a large thing with holes.
And really want me to join your favorite music and session machines, you want skachaite session A. Patrushev.
What do I do???
There are still complete transactions with two pins:)
Maybe you can use it. But where to put the pin in the laptop???
PS Apologies for the erotic question. But waiting for an answer.
