Replacing the battery in photosonix nova pro 100
Post Reply
User avatar
Брахман
Post by Брахман » Thu Aug 04, 2016 10:52
Hello!
Mind machine only works from the network, I guess dead battery.
What's the battery life? Is it possible to replace it manually? Where is the best to take?
Please tell me, Thank you.
Has thanked: 134 times
Been thanked: 556 times
Contact:
Re: battery Replacement in the photosonix nova pro 100
Post by Андрей Патрушев » Thu Aug 04, 2016 11:27
Brahman
When the battery dies, the Nova Pro 100 and the network does not work, at least until until you from machine picks.
The standard battery (acid). Unscrew the bolts on the housing, remove the battery ( I have the polarity on the wires were not labeled, so just in case, stock up on a piece of masking tape below the minus mark before removal), go with him to the store batteries and show the seller as he picks up what you need.
User avatar
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Thu Aug 04, 2016 14:23
Brahman Is in the office , the cost of 700r. If in Moscow , can come with MM. If not, and you have somewhere to buy. See parameters for battery Nova Pro.
User avatar
Брахман
Post by Брахман » Sun Aug 07, 2016 10:18
Thank you for your answers,
Андрей Патрушев wrote:Brahman
hmm, that's weird.
The fact that he bought a mind machine with it. Didn't know before purchase that there is still a built-in battery is. Works like adequately from non-native Robiton adapter 9V, 500 mA. But without it does not want. And I would like nature to paszamant :wiz
Contact:
Post by Андрей Патрушев » Sun Aug 07, 2016 10:21
Brahman
It seems that there is simply no battery (or disconnected) - spin and look - it's not scary. :)
User avatar
Брахман
Post by Брахман » Mon Aug 08, 2016 14:15
Hmm,is the battery was connected. Checked the tester, produces 0.6 volts.
Post Reply
