How to find optimalnoe the combination of: MM+player
User avatar
Has thanked: 478 times
Been thanked: 264 times
Re: How to find optimalnoe the combination of: MM+player
Post by ЛИЛИЯ-Р » Mon Feb 06, 2017 17:24
I am In the instructions to the Navigator page 6 ,Paragraph 1.2-equipment and accessories -description nested components in the device. Depending on the time of picking and to the presence of cords ..can be attached to the gray cord or black. Look in the last pocket of the bag(backpack).
Я Есть
Has thanked: 10 times
Post by Я Есть » Mon Feb 13, 2017 11:46
LILY-P Everything all hooked up :D thank you! But, for some reason, the glasses do not work :?
User avatar
Post by ЛИЛИЯ-Р » Tue Feb 14, 2017 14:24
Я Есть wrote:LILY-P Everything all hooked up :D thank you! But, for some reason, the glasses do not work :?
Points can not work, if the device volume is small, do the volume on bribie more on the player and adjust by itself. And brightness view on the instrument. Maybe not enough? When you described that and how to connect, did it on the device itself , everything worked.
There is one problem , the sessions can base the color change on the device button , the right bottom box. Playing at the gate-entry and other this button is why it dampens glasses. Then you need to adjust the color before you run the session in the setting color selection.
Can call the office and let's do it together.
Post Reply
