[newsletter]Problem children.
Post Reply
User avatar
Has thanked: 31 times
Been thanked: 129 times
Contact:
Post by к-13 » Mon Apr 01, 2013 0:44
Greetings to all subscribers to mailing the website of the mind-machine.ru.
Please read the small text below, this can be very important.
After the release of the sound files that stimulate alpha waves and are designed to smooth the manifestations of syndrome of attention deficit and hyperactivity disorder in children, the questions about children that are a little behind in development or have no interest at all to anything.
Today's edition is devoted to the way that will help Your children be more attentive, improve performance, become more balanced and harmonious. Even if You have no problems with children, I'm sure you'll definitely find the family or friends with a whimsical, disobedient, hyperactive, inattentive or a little developmentally delayed children. Encourage them to try the technique fairly quickly produce positive results (even after one ten-minute listening they are visible), and contraindications and side effects almost there - only the age of five years and no more than an hour at a time (used only the sound, but most of the contraindications for mind-machines - viewtopic.php?f=22&t=878 associated with flashes of light).
To begin with, that the brain of adults works mainly on beta waves (we are scurrying around, nervous, quick uptake, planning, late...), whereas children usually predominate wave alpha range (and even theta for young children). Most deviations in the direction of hyperactivity, and in the direction of hypoactivity (as well as all sorts of "little problems" like sudden mood swings, stuttering, tics, enuresis, etc.), usually associated with a deviation of the picture frequency activity of the hemispheres from the norm, and in most cases there has been a failure in the field of alpha-band - in these cases, helps the stimulation frequency of 9-12 Hz , which I wrote in the release about ADHD - viewtopic.php?p=98725#p98725. These files can help in most cases. Don't instantly fix everything, and slowly but surely lead the situation towards improvement (sometimes problems are rooted in physical causes for frequency of harmony or traumatic memories, and to eliminate their influence the body takes time, often considerable, so have patience). Better to use once a day for 25-30 minutes.
Stimulate alpha right also you can use many things for example: an adjustment mode of the day (especially sleep), limiting the use of means of stimulating excessive frequency, proper breathing, making music or drawing, a hobby, reading a book, just closing his eyes for a few seconds, deep breath and exhaling, still dozens of other methods and techniques.
If someone has a desire to have other songs in the same format (e.g., a favorite song of Your kid), send it to me at the address krupa13@mail.ru I'll process it and post it in this thread.
PS: The mode of action of alpha rhythms on the personality characteristics of 40-ies of the last century studied Jose Silva (in the 60's he was already teaching his method based on the use of alpha-level in the processes of healing and personal development), and stimulation of brain waves through binaural beats and modulated sounds are studied first by a group of researchers, and then Institute Robert Allen Monroe from 1956 (the Institute was founded in 1974 and works primarily with Hemi-Sync). During this time, no adverse effects or risk to life and health no alpha rhythms or of the stimulation of their sound have been identified (on the contrary, a great number of cases of healing, life improvement, normalization of nature, etc.).
Just don't leave the baby alone with headphones.<
User avatar
Contact:
Re: [mailing]Problem children.
Post by к-13 » Mon Apr 01, 2013 0:53
Repost of previous issue just in case.
has Prepared for his son a few nursery rhymes and fairy tales as sessions to work with hyperactivity and attention deficit, at the same time gave several parents from our group in the kindergarten, explaining how to use. Children (4 boy and one girl, all around 6 years old) listened to the files with headphones 2 weeks for 10-15 minutes once a day, in the evening after returning home. In my opinion, the results of the face:
teachers drew attention to the fact that they have fewer problems - less distracted during class, the drawings became more accurate and intense game choose is not so noisy, less forgetting to remove the toys and markers.
- the house the children became more calm, reaction to events and others became more balanced and positive, almost disappeared sleep problems, including day.
Anyone can check and tell about their findings, it is not more dangerous than watching TV.
Here is a list of files to download from Yandex-disk:
http://yadi.sk/d/zJIcosRu3EaNS
http://yadi.sk/d/2msKWlQb3EaN0
http://yadi.sk/d/IoiAKx2A3EaMO
http://yadi.sk/d/Grcdyzq03EaMg
http://yadi.sk/d/xatsMD5r3EaLs
http://yadi.sk/d/wSEv2pvm3EaKQ
http://yadi.sk/d/P3Pf0iKy3EaK4
http://yadi.sk/d/3qckOhRV3EaJa
http://yadi.sk/d/Vxar_XTM3EaJ4
http://yadi.sk/d/MPQK3zqU3EaIO
http://yadi.sk/d/vVXe2Lyg3EaHo
http://yadi.sk/d/7wlg60sh3EACa
http://yadi.sk/d/4hg_uMz63EAD0
http://yadi.sk/d/McZiLBeC3EAIQ
http://yadi.sk/d/ROC57fSd3EADq
http://yadi.sk/d/PrXtwiAs3EAEe
http://yadi.sk/d/TAdqAf2J3TM6S
http://yadi.sk/d/qaLH1qac3EAFO
http://yadi.sk/d/iR0vH57G3EAGq
http://yadi.sk/d/gb9xph3F3EAJG
http://yadi.sk/d/uASqr4lw3ECpI
According to researchers in the field of audio and sound stimulation, these files can be given to listen only to children aged over five years, it is recommended not to exceed a twenty-minute time interval for one lesson, a child needs to sleep at least two hours between auditions (a pause of at least 5 hours - it is better to stick to one lesson a day) and use a small volume.
Sit with your child until he listens to the melody or a story, look at his emotions - perhaps something bothering him - after listening You will be easier with him to talk about it.
And another little tip - add in a player other nursery rhymes if a child asks a little bit more to listen to)))
ААААА
Post by ААААА » Mon Apr 01, 2013 1:28
Novel! Thank you for your efforts! I've found good that would be a bit longer and then they would have to recruit several total time 15 minutes)
What kind of music is best for children 11-14 years old? Maybe audio books?
User avatar
Contact:
Post by к-13 » Mon Apr 01, 2013 10:28
ААААА wrote:I've found a good that would be a bit longer and then they would have to recruit several total time 15 minutes)
I tried it, no difference. Still play songs from the folder, it is possible to adjust duration of any playlist. "Masha and the bear" recruited long and tales fit for the duration...
ААААА wrote:What kind of music is best for children 11-14 years old?
One that they like :? You can use the mixer in MM with the alpha session suitable duration without glasses - the ratio of the volume of the melody/session=3/1
ААААА wrote:Can audiobooks?
Disposable to do? Or pick one so that something useful was repeated to the child.
User avatar
Contact:
Post by к-13 » Tue Apr 02, 2013 0:59
please Explain to me again how you will handle your favorite song, baby?
To the tune of just will be imposed in the alpha range audio editor - the left channel is offset relative to the right 9-10 Hertz and added to the runout amplitude.
User avatar
Contact:
Post by к-13 » Wed Apr 10, 2013 0:11
Feedback email (the boy was five years slept very bad and didn't want to get in det.the garden in the morning), in the condition it was told that recently watched the movie about Pinocchio and liked:
Hello, Roman.
Thank you for your tunes! The son listens to them in a week for 15-20 minutes before bed - felt good to sleep, stopped up at night, but wakes up in the morning myself. Yesterday he solved the puzzle with his favorite Makvinom of almost 2 hours spent, although in the past five minutes, completely lost interest in this lesson. Became more docile and less nervous.
Here is the file itself - http://yadi.sk/d/Zgtgyh4w3vvUW he's almost 37 minutes (21 piece of film with the works of Alexey Rybnikov), almost a short film, but the modulation is soft, so there is nothing wrong in listening to the entire file at once.
And a few "tunes order":
http://yadi.sk/d/hdd1pN6q3v4PY Moonlight Sonata
http://yadi.sk/d/p4s_oPtu3uuC4 Dawn
http://yadi.sk/d/vqnmgZY03vQFg Rachmaninoff
If anyone is interested, tales of execution in MS Vspyshkin to prepare my hands on three of its drive fell - need to listen and select the appropriate)))
ААААА
Post by ААААА » Wed Apr 10, 2013 1:11
Novel ! Waiting for the fairy tale look!!!! And then those that were on last week, we've eaten and we can't wait the new.... (C)
By the way, you old Fedorino good grief ,sink, etc ... Although conductive children have more use and even do not know what to please in 11 years ! )
But fairy tales are a great success compared to the songs)
User avatar
Contact:
Post by к-13 » Wed Apr 10, 2013 1:44
ААААА wrote:by the Way, you old Fedorino good grief ,sink and so on
Korney Chukovsky I also have in audio format will make the day 2-3.
User avatar
Contact:
Post by к-13 » Fri Apr 12, 2013 21:23
User avatar
Contact:
Post by к-13 » Fri Apr 12, 2013 21:26
One of these tales is performed by Caste (too processed) - http://yadi.sk/d/7LKiyv9v4-jtM
Plus fortieth Symphony by Mozart - http://yadi.sk/d/bdgAOSkl4-jzm
And Concerto No. 2 for piano and orchestra Rachmaninoff - http://yadi.sk/d/tPgp5Lzz4-k3y
I remind you that you can send your proposals - I will gladly handle any tune, if necessary.
User avatar
Contact:
Post by к-13 » Fri Apr 12, 2013 22:50
By the way, Yaroslav Golub advised me when working with children to use the following method - before the audition you can put child's hands on the shoulders and neck on the sides (like a Fox collar in the cold winter :) ) and ask him to paypalat muscles under Your palms for a few minutes (5-10) so they felt movement. Very good. Just do not push yourself on the baby (contact should be as light as possible) and don't make a face like a bent one last time over Desdemona Othello)))
Виктор...
Has thanked: 1 time
Been thanked: 1 time
Post by Виктор... » Sat May 03, 2014 16:38
Good afternoon.
I use the Pathfinder(also bought neuroprogrammer). They help me, but just want to help my son, he is 10 years old. I want to try to impose on the stories and music for your child, the alpha(he could not long the same listening). But I don't know how. I'm afraid to do something wrong. Here You write
Please tell me somewhere there is a guide or at least description how to do it?
User avatar
Contact:
Post by к-13 » Sat May 03, 2014 22:42
Виктор... wrote:please Tell me somewhere there is a guide or at least description how to do it?
I have not seen such manuals, but without a good knowledge of the subject it is better not to experiment.
Ideally, you need to remove the baby detailed EEG at rest and to look dominant in the alpha range. And then work from that.
In my files, the average frequency, for example, 9.8 Hz, bred with small deviations as the General dominant for 80% of children 6-14 years by the British 15 years ago.
Виктор...
Has thanked: 1 time
Post by Виктор... » Sun May 04, 2014 9:42
I haven't seen those guidelines, and without a good knowledge of the issue is better not to experiment.
Can direct where and what to look for to study the information needed?
User avatar
Contact:
Post by к-13 » Sun May 04, 2014 12:08
Little by little a lot of information where, especially in English. A large number of interesting material given on this website under articles.
Виктор...
Has thanked: 1 time
Post by Виктор... » Sun May 04, 2014 12:48
User avatar
Contact:
Post by к-13 » Sun May 04, 2014 23:03
Yes. Suggest to start with two books that Vladimir Nikonov translated.
yrii
Post by yrii » Thu Feb 22, 2018 13:55
Tell me, is it possible to listen to these tales of the child 3.5 years. No it is not possible to persuade him to leave from the older 6-years old at the time of listening...
User avatar
Contact:
Post by к-13 » Thu Feb 22, 2018 22:20
yrii wrote:Tell me, is it possible to listen to these tales of the child 3.5 years. No it is not possible to persuade him to leave from the older 6-years old at the time of listening...
And headphones large not easier to use? Little data on this topic. I wouldn't risk it, but most likely that there is nothing can not happen is a surge of sound are the same as that of the engine of the vehicle, for example. No real danger for the psyche and health of the sounds in these files can not imagine (at a reasonable volume, of course). The maximum that threatens - will it work drowsiness until the end of the day or fidgety in the night, but in this case you have You will understand that it is not worth it.
Иностранец
Post by Иностранец » Mon Mar 11, 2019 10:58
Data just a few. Research is conducted for a long time and collected a lot of materials. Some researchers believe that hyperactivity is caused by a lack of beta waves. It is clear that beta waves predominate in the spectrum of the child, but they are still there, just less pronounced. I'm no expert, something to say, but it may happen that the stimulation of alpha, especially up to 10 Hz, to suppress beta-rhythms that give the opposite result: more hyperactivity and self-stimulation.
Materials (sorry, English only):
http://mindalive.com/index.cfm/research ... ve-siever/ (The use of audio-visual stimulation for the correction of behavioral problems in the school environment)
http://mindalive.com/index.cfm/research ... ael-joyce/ (The project for introduction of Neurotechnology at the school "New perspectives")
http://mindalive.com/default/assets/Fil ... arn(1).pdf (Use of ABC technologies to improve focus and academic performance)
http://mindalive.com/index.cfm/research ... nuernberg/ The study of memory and concentration
It is clear that the articles can be selected and the results of studies in principle it is possible to fit the desired conclusions, but the material is read. It is interesting to note that the use of AVS was conducted in private schools (paid), while for the control group was used students of the public free schools. That is to say, the class approach in action.<
User avatar
Contact:
Post by к-13 » Mon Mar 11, 2019 18:56
Actually, I was talking about the age of 3.5 years, there's really little data. So it is safe to sound to stimulate the alpha can (assuming constant adult supervision) in children of school age, and the light is generally not before the age of 14. And again there is no data on how this may then impact.
Post Reply
