Page 1 of 1
transcranial stimulation and mind machines
Posted: Wed Mar 14, 2012 15:59
by Фонтан
Good day! I would like to ask a question to Andrey Patrushev!
a couple of years are the owner of "Alfaria" (not advertising), I guess people in the know know what this apparatus electrocentrale stimulation, the question is: this unit contributes to the alpha rhythms of the brain and mind machine I understand it, too. I just want to buy a mind-machine, well, for example "Navigator", but knowing that I have a "Alfaria" begin to doubt whether it is necessary? after all, he and the other device will help you to relax, the emergence of alpha rhythms, stress resilience, improved sleep.
Please explain is there a fundamental contrast is the difference!?
why the need for the device and the other to me?:
-elimination of stress
relax
-elimination of chronic fatigue weakness!!!
-improve attention memory mental clarity and other cognitive functions !!!
Re: transcranial stimulation and mind machines
Posted: Wed Mar 14, 2012 16:11
by ЗОМБИ
Fountain
Alfaria not flexible
plan to use it while relaxing from MM
Posted: Wed Mar 14, 2012 16:23
by Igor
ALTARIA uses cerebral electrical stimulation with bipolar current at a frequency of 77.7 Hz.
For transcranial stimulation, electrodes must be on the forehead and nape.
z.s. MM is much more flexible IMHO...
Posted: Sun Apr 08, 2012 11:02
Fountain
If You are only interested in relaxation and stress relief, it makes little sense in purchasing machine, in the presence of Alfaria there (in addition to the diversity of experiences).
Improve your memory and focus will also take place as a result of the stay and increase the power of the alpha waves. A more profound elaboration of the problems with memory and attention and the removal of the depressive effects (chronic fatigue) is possible only with the help of machin.
Posted: Wed Apr 11, 2012 0:19
by Владимир Никонов 2
Use Alfario and Navigator.
ALTARIA helps to lift your mood before sleep include, the next day I feel fine. And Navigator in order to cheer up and freshen up.
Posted: Wed Apr 11, 2012 23:47
by Димас
Vladimir Nikonov
And why to share, just have both devices? Have you tried tandem ALTARIA + Navigator? It makes no sense to combine energy programs, but in the alpha relax it, "what the doctor ordered", the more I suspect there is a synergistic effect.
Posted: Thu Apr 12, 2012 0:41
by МерКаБа
demAs ie and with headphones too, or just sunglasses + ALTARIA?
My headphones don't allow to attach clips from Alfaria.
Posted: Thu Apr 12, 2012 1:20
by Димас
Merkaba
Exactly, and with headphones too, without them the meaning is lost. If the headphones much in the way, alternatively you can pick up a "bung" with silicone inserts, they are soft and do not irritate the inside the ear. Or you can do a little less size, then the headphones will be above the level of the ear lobes, though it is not as convenient as soft earplugs. For the sessions of their audio quality enough above the roof, especially now they are made with fancy quality, will fit and work with the drives (here you can explore http://www.sennheiser.ru/cat/sennheiser ... eadphones/)
