[html]<font size="-1">Michael Stevens<br> translation into the Russian language: Nikonov Vladimir </font></p><p>Peripheral TRANS - tech, allowing you to enter a state of "relaxed vitality".</p><p><font size="-1">TRANS (from FR. transir — numb) — the functional state of the psyche, which varies the degree of mind control over the processing of information.</font><font size="-1"> TRANS accompanied by certain changes in brain activity, especially beta waves. </font></p><p><font size="-1">Medicine TRANS admits a healing state of consciousness in which a person receives about two times more rest than during sleep. When a person enters a trance state deliberately, such a trance is usually called meditation. Source: <a href="http://ru.wikipedia.org/wiki/%D0%A2%D1% ... /p><p>Тема this article is so simple that many people do ignore such things, as unworthy of any serious attention. Please experiment with this technique! Although it is simple, but it is one of the most POWERFUL methods of all of them that I know... use it!</p><p><font size="+1">first, let's discuss why you should want to learn this technique.</font></p><p> How about to master easy to learn and perform, simple, rapid technique that you can apply at any time, anywhere, which is safe, effective, funny, stable and reliable? </p><p>This is a technique that allows you to enter a state of "relaxed vitality", which you can use for instant termination of the negative thoughts, which will help you to quickly focus and, at least twice as fast to absorb or recover information! </p><p>We will also discuss how to integrate this technique with light and sound session so that these sessions become more effective and deliver more pleasure for you.</p><p>You will also learn how to use this technique to better prepare for the session light and sound stimulation (namely, how quickly "disable" any unwanted external interference and thoughts).</p><p>what is it?</p><p> <font size="+1">Peripheral TRANS, in simple terms, focuses your attention on peripheral vision. </font><br></p><p>This is a small, simple action extends the field of vision and perception. Usually when this occurs a mild state of trance, and that's good. Peripheral trance is often described by my clients as a feeling of "relaxed vitality".</p><p>Now about the amazing possibilities of this condition. Once you reach the state of the peripheral trance, you gain the ability to concentrate the energy (including attention) PLUS a pleasant state of consciousness. Let me explain. </p><p>in This state of consciousness you must receive new information. Alfred Korzybski (Alfred Korzybski) said in his book "Science and sanity" (<em>Science </em><em>and </em><em>Sanity</em>) that "any knowledge depends on the state". This means that the easier you restore the information you have, the closer your state of consciousness at the moment to that in which the information is perceived.</p><p> If you know how to enter in a stable, reliable state of consciousness whenever you get new information And you need this information later to restore, you would certainly be able much more efficient and easy to operate with this information (and have more fun) than if you dominate the unstable, unreliable States of consciousness.</p><p>Maybe someone of you understands what I mean by unstable, unreliable States of consciousness. So, for example, you are preparing for written exam. When you study the training materials in the comfort and privacy of your own home, you feel relaxed; but when you enter into the daunting classroom, most of you suddenly feels that his head is completely empty and can't remember anything because of the surging of the examination fever. OH! </p><p>This situation is an example of what often happens when you are in the wrong state of mind. The state in which the information was obtained (home, in a relaxed state) is fundamentally different from the state in which this information is required to remember (in anxiety, nervous atmosphere of the classroom). This happens as a result is unstable (which means inappropriate mental state) and unreliable (i.e. you cannot arbitrarily reproduce a state in which the material has been studied) States of consciousness.</p><p>That's how it's done!</p> <li>define any point to focus. I often recommend to focus on a spot on the wall (if wall exists). For beginners the easiest way to do this is to draw a "point" (usually a thick black circle of 5 cm. in diameter) on a card and hang it on the wall so that the card is located under an angle of 45 degrees to eye level.<br> <br> </li> <li>just concentrate on the spot on the wall. Let this point be the center of the Universe. Direct all your attention to this point.<br> <br> </li> <li>when all your attention and energy is directed at this point we the wall, start slowly and gradually to realize what is happening around you. Move your awareness to the boundaries of your peripheral vision. Then mentally shifted around his body, behind you and on to as long as your mental awareness will spread in all directions, including up and down.<br> <br> </li> <li>when you have completely covered mentally all the space around you in all directions, recall a sound which produces a sealed container at the opening, and secure in the consciousness of this feeling is a comprehensive awareness of what is happening.</li><p>Great!</p><p>This technique has been used successfully in eliminating attention deficit disorder (ADD), attention deficit with hyperactivity disorder (ADHD), anxiety, just negative emotions, and many other troubles! Using this technique in the classroom, student usually improves his performance by 1.5 points.</p><p>To extend the capabilities of the equipment apply it during the sessions, light and sound stimulation. A good reason to use equipment, peripheral trance mind machine – this is the case when you are having difficulty "joining in session". You may be trying to start a session without releasing your mind from thoughts and problems accumulated during the day.</p><p> <font size="+1">In this case, simply select the "point" of the myriad visual images reproduced your light goggles, and apply the technique of peripheral trance.</font></p><p>This technique is also useful to control the negative emotions associated with unresolved issues that pop up suddenly during a session. If this happens, peripheral TRANS will quickly return you to a calm, focused, productive state.</p><p>If you want during your session to experience a sort of "blow to the head", just quickly move from peripheral TRANS to the direct vision and back. It turned out, follow the guidance on the extension of the field of perception of what is happening, then bring your focus to a point located directly in front of your eyes (at this point you should be completely disconnected from what's happening in your field of peripheral vision), then again will quickly cover all that is happening around you.</p><p>Use the technique of peripheral TRANS when you want. She has no restrictions on the duration and frequency of use. </p><p><br> <font face="Geneva, Arial, Helvetica, sans-serif">About the author:</font><br> Michael Stevens is a certified practitioner in the field of neuro-linguistic programming (NLP), a specialist in hypnosis and practitioner of Time line therapy ("therapy by the time line").</p>
[/html]<
Peripheral TRANS (article)
- Владимир Никонов 2
- Has thanked: 20 times
- Been thanked: 28 times
- Contact:
