Page 1 of 1
Bought today innerpulse
Posted: Tue Jun 17, 2008 18:39
by Миссенка
Tried the program, has passed the current minute... how scary.... I have the feeling that might explode
what to do?
Re: bought today innerpulse
Posted: Tue Jun 17, 2008 19:09
Миссенка wrote:Tried the program, has passed the current minute... how scary.... I have the feeling that might explode
what to do?
The volume and brightness removed to a comfortable level.
Posted: Tue Jun 17, 2008 19:55
by Guest
the Volume and to remove brightness to a comfortable level. Confused
and so I have put everything on low, but still somehow scary... though ago returns
Posted: Tue Jun 17, 2008 20:16
by Миссенка
And where is the guarantee that I will not fall into a lethargic sleep for example? ugh ugh ugh kanesh...
By the way here in instrukcii says that you can not use under the influence of psychotropic substances, including alcohol. M.. and how much not to drink before using?
Posted: Tue Jun 17, 2008 23:42
by Миссенка
Hm.. searched the whole forum, I'm actually trying a beta program to use, and it is necessary with alpha to start, so this fear... I somehow believed that the less time, the easier it is to start, well let's try with the alpha version.
PS she talked with him and good
Posted: Tue Jun 17, 2008 23:56
by Карил
What are you on beta suffered? Andrei Patrushev probably more than a dozen times on the forum wrote that alpha should start...
Posted: Wed Jun 18, 2008 0:08
by Миссенка
Карил wrote:what are you on beta suffered? Andrei Patrushev probably more than a dozen times on the forum wrote that alpha should start... Confused
I would like the form not read, chose just the minimum on time "rotation of the brain" .... for the first time - the less the better (female logic)
Posted: Wed Jun 18, 2008 1:20
by Миссенка
alpha was a relaxing game ever!!!!!!!!!!!!!!!!!
Posted: Wed Jun 18, 2008 6:50
by Евпатий
Миссенка wrote:Карил wrote:what are you on beta suffered? Andrei Patrushev probably more than a dozen times on the forum wrote that alpha should start... Confused
Yeah, there was already an enthusiast, who started sessions with the same session. Keep reading the forum.
Posted: Wed Jun 18, 2008 12:45
by Dimas
Missence
Yeah,and write about feelings
Posted: Fri Jul 11, 2008 13:49
by Я
How to put a manual in Russian to the sessions of the inner pulse, the one that was given while I was left far-vato from home, but the one that is on the forum does not allow to use it in conjunction with a machine (or rather the brain must strain when comparing English instructions available on the website).
Posted: Fri Jul 11, 2008 13:51
by Я
http://mindmachine.ru/photosonix/innerpulse.htm
It is not clear which letter MM on the screen corresponds to which mode, that's what I meant.
Posted: Fri Jul 18, 2008 20:01
by Алекса
Hello!
Today I bought this wonderful thing called the inner pulse.
Delivered exactly on time.
Impressions about the appearance and ease of use just pull on a three point scale. Too many wires, the wires from the headphones, from the points from the power supply, and even for situsnya
The typewriter thinnest and lightest, not the impression of things for 6700р. Glasses also I krupchenko at first glance, though, and ColorTrack. Well, maybe I'm wrong about the quality and durability, I wonder if you drop it accidentally.... Just a cloud of wires, can only be used at home to you "alien" no one saw, and easy to use just lying.
Included a session entitled "wave of peace" Choate effect is not understood yet, but maybe there is still everything. You need to read the forum, then there is still need to do. Crazy like while not gone, and the feeling was not like this. Although when the husband wore glasses and also tried this session that asked not if he gets to the nuthouse
Yes, even when listening to the session, I had the feeling that eyes are open, this is the only neobichnoe that I felt.
I wonder at all the feeling of zero for the first time? Or maybe I do wrong???
Posted: Fri Jul 18, 2008 23:46
by Димитрий
Алекса wrote:about the quality and durability
You can be sure is tenacious
Алекса wrote:a lot of wires, the wires from the headphones, from the points from the power supply, and even for situsnya
In-in!!!
Алекса wrote:Although when the husband wore glasses and also tried this session that asked not if he gets to the nuthouse
Definitely not
Алекса wrote:you Need to read the forum, then there is still need to do.
But is it true of the purest water
Posted: Sat Jul 19, 2008 12:58
by ме-ди
Алекса wrote:the typewriter thinnest and lightest, not the impression of things for 6700р.
That's very interesting,6700р the typewriter or with glasses??
Posted: Sun Jul 20, 2008 14:12
by Алекса
ме-ди wrote:That's very interesting,6700р the typewriter or with glasses??
6700 premium this with glasses, I lied to you.
I bought with ColorTrack for 10500.
Posted: Fri Aug 01, 2008 16:45
by кислый лимон
the child also begins to walk immediately, opereaza on the wall...etc.
but in a way he is gaining the skills to hook them and soon begins moves independently.
