A mind machine and method Jose Silva
Post Reply
Завоеватель
Post by Завоеватель » Mon Jun 16, 2008 12:06
Acquired INNER PULSE used for 3 months
But as I understand it, the mind machine designed to help achieve altered States of consciousness
I have a problem I already reached the state of trance or not
as I don't know the criteria of occurrence of this state
in addition, the best in trance serves as a method of reducing stress but I would like to use it to correct negative psychological programs
your website says
"A psycho by the method of Jose Silva" already know how and why they want to use their mind machine. And for the uninitiated explained that any condition that You have ever experienced (not just fatigue and illness), you can learn to find in any chosen only in Your moment of life, using very simple and accessible to everyone methods of "anchoring", designed in the modern practical psychology.
The mind-machine can help You to reduce the time needed for training on this method and to obtain significant results from the first practice.
Please tell us how to combine mind and machine the training method Jose Silva
User avatar
Been thanked: 6 times
Post by Dimas » Mon Jun 16, 2008 15:11
the Conqueror
After some time of training on MM (what a time individually),You will be able to understand that I have reached certain States of consciousness...Being in alpha is quite noticeable...It's like You're very calm,but You feel fine,you know...Vneshnesecretornuu TRANS so to speak (if you made a mistake in the term A. Patrushev even better)..I Personally hard to describe this state in words, unfortunately...
Завоеватель
Post by Завоеватель » Fri Jun 20, 2008 13:32
Dimas thanks for the reply
Most likely the alpha state I was the place to be
just was not sure in the correctness of their actions
Please clarify one more question
As stated in the sources on various psycho by itself the state of trance is very useful and has a value in itself but to use it for psychotherapy it is necessary
to practicing or details in the images represented the process of positive personal change, or was accompanied by a state of relaxation precise verbal formulas
Vneshnesecretornuu TRANS (uptime in terms of NLP) concentration on an external object
Vnutrikletochnyi TRANS (downtime in terms of NLP) focus on internal oshushenia (breath, muscle groups, blood circulation)
It turns out that the status of the called a mind-machine is in the nature of vneshnepoliticheskogo hyperstimulation trance
Autogenic training a method and Jose Silva's assume concentration on different muscle groups and speaking or proslushivanie related verbal formulations and it is an example vnutrikletochnogo lipostimulation trance
Can coexist the two types of TRANS in the lesson with a mind machine and proslushivanie verbal suggestions at the same time
Has anyone tried one that turned out
Guest
Post by Guest » Fri Jul 04, 2008 23:01
:o :o :o 8) az :wiz :ay :wink:
Дима.
Post by Дима. » Sun Jan 25, 2009 17:48
I think mindmachine still gives vnutrikletochnyi TRANS, except for sessions with high Beta waves.
The alpha state is, even so, a shallow trance.
If you take the state of wakefulness in the middle, the TRANS and uptime are on different sides. (this table is reproduced in the literature on NLP)
Uptime.
Action.
Wake.
Relaxation.
TRANS.
Sleep.
(Coma :shock: )
Has thanked: 134 times
Been thanked: 556 times
Post by Андрей Патрушев » Sun Jan 25, 2009 19:06
Завоеватель wrote:Dimas thanks for the reply
Uptime, among other things, is characterized by the absence of value judgments (internal dialogue). This is the same alpha state as downtime with the only difference is in the focus of attention.
тариел
Post by тариел » Sun Jan 30, 2011 14:48
It all depends on each individual.
к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439
к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439
к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439к439EN-us">к439к439к439к439к439к439к439к439
laser vision correctionastigmatism52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o
52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52oEN-us">52o52o52o52o52o52o52o52o52o
52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o52o<
Вал
Post by Вал » Sun Feb 27, 2011 12:10
so much easier to wear rose-colored glasses and dive in happily-manic state... also individually...
User avatar
пирожок
Post by пирожок » Sun Feb 27, 2011 17:38
interesting! and I'm still looking for ways to plug this dialogue during meditation )) and what is a session? and what more suitable uptime?
Post Reply
