Breathing techniques to facilitate entry into the TRANS
Hello! And again the question to seasoned, Andrew demAs, Alexander Malinovsky and all who may share information about breathing techniques helping and contributing to entry into the TRANS, improves circulation of the brain, stopping the internal dialogue and increase efektivnosti operate the machines. All possible links, yogic techniques, etc. didn't have a lot already on the forum a little in different topics but I think it will be interesting to read it all in one topic.
Thank you
Thank you
Re: Breathing techniques to facilitate entry into the TRANS
You slightly contradict yourself: improve blood circulation of the brain do not condone promotes entry into the TRANS and stop the inner dialogue!Вик_ wrote:Hello! And again the question to seasoned, Andrew demAs, Alexander Malinovsky and all who may share information about breathing techniques help and promote entry into the TRANS, improves circulation of the brain, stopping the internal dialogue and increasing efektivnosti operate the machines. All possible links, yogic techniques, etc. didn't have a lot already on the forum a little in different topics but I think it will be interesting to read it all in one topic.
Thank you
Deep breathing leads to depletion of oxygen to the brain. Science has proven that frequent deep breathing the vessels in the brain constrict. Thus the brain receives much less oxygen than usual, and occurs when the brain is no longer able to operate the amount of external experiences that usually accompany it. This is the entrance into a trance. Deprivation occurs – turn off the brain from external information sources.
Well, first I might not exactly put it rather than "and" and "or" ,but secondly, no one talked about deep breathing and the only leash on methods and ways. And the output in a trance. you're not confused with holotropnoe? TRANS you know are pretty slim veschСаин wrote:You slightly contradict yourself: improve blood circulation of the brain do not condone promotes entry into the TRANS and stop the inner dialogue!Вик_ wrote:Hello! And again the question to seasoned, Andrew demAs, Alexander Malinovsky and all who may share information about breathing techniques help and promote entry into the TRANS, improves circulation of the brain, stopping the internal dialogue and increasing efektivnosti operate the machines. All possible links, yogic techniques, etc. didn't have a lot already on the forum a little in different topics but I think it will be interesting to read it all in one topic.
Thank you
Dimas wrote:Vic
Very simple!Carefully observe your breath,without any distractions...and all...
Well, I thought I would get a response on the respiratory session, enzogenol about the breath, alignment of the simulator Frolov and cars (if any sessions and what kind of impression). Again, probably all confused and inaccurate asked
Евгений Кош
- Has thanked: 2 times
- Been thanked: 2 times
Very effective for me was the following method-
rhythmic breathing ( from Ramacharaka "beyond life and death" it is well documented")
In addition to maintaining the rhythm necessary to represent the flow of energy in the moment of a breath and vidhana waste of energy.
When you use this method, I have sensations increase blood supply to the brain ( fosamine this energy content) ... that feeling is the point of verification of the correct starting meditation(for me).
Then this feeling begins to transform and then cease to pay attention.
The easiest way to go into a trance when breathing assistance is a connected breathing (no pause between inhalation and exhalation). Change brain rhythms when it comes from a mentally healthy person in 10-15 minutes. The deeper the breath, the deeper the trance state.
Coherent breathing is used in all the "famous" respiratory psycho: rebirthing, Vivan, holotropic breathing.
If breathing is intense, with forced inhalation and exhalation, get a holotropic trance - deep and in many cases with pronounced physical symptoms. They need to be able to work, and need to be next to a trained instructor, so you have to experiment so not very green compared to yourself.
If breathing is also coherently, but in a relaxed exhale, get breath in the style of "Vivas". TRANS is lighter, without distinct bodily effects. But this breathing technique still need to master.
n
But in the old time-tested techniques"Coherent breathing is used in all the "famous" respiratory psycho"
it says that the key to managing prana
is in the breath
The delay is easier to control prana
Cm for example
"Andre van Lisbeth. Pranayama - the Path to the secrets of yoga"
Though the TRANS probably is not associated with the subtle body of prana
and with the subtle body of the mind
so maybe this technique - Coherent breathing -focused on it
But we should remember that from the point of view of security
better to deal first with the physical body
then with prana and then with the subtle body of the mind
further
1) as "test of time" - in pranayama, there are around 10 respiratory patterns with the structure of coherent breathing. Connected breathing is based huge number of traditional techniques: Sufi dhikr, the Jesus prayer in the Hesychast, embryonic breathing from the Taoist, the prayer chants in different cultures...
2) as for the sequence of development - I totally agree with You - breathing techniques in the transformational tradition have given and given in the higher levels, already prepared people
That is why I am personally taking on trainings not all, even standard filled with honey.the questionnaire may not be sufficient to enter in the composition of the group.
Нетрезвый Сурдопереводчик
- Been thanked: 1 time
Shaw for the highest stepeni?
the method of entering the trance...for the most diligent
:sit in a comfortable position where you will not be blah-blah-blah...eyes closed for some time "listening" your breathing,then gradually bring the rhythm of breathing to the proportion 1:2(to start).all the time,quietly stretch the exhale,and as soon as it ends start--unobtrusive breath...after some time everything will work out
the method is tedious and fraught with the destruction of respiratory stereotypes.and this is not a joke.....
do not belong to the aforementioned luminaries,but the tasks that you put,enough for 12 to 20 years of tedious and hard work,say,Hatha-yoga in non-pop version.TRANS because the TRANS is not worth such a loss of time.I have the right since I have over 20 years of dubious movements.Вик_ wrote:Hello! And again the question to seasoned, Andrew demAs, Alexander Malinovsky and all who may share information about breathing techniques helping and contributing to entry into the TRANS, improves circulation of the brain, stopping the internal dialogue and increase efektivnosti operate the machines. All possible links, yogic techniques, etc. didn't have a lot already on the forum a little in different topics but I think it will be interesting to read it all in one topic.
Thank you
practitioner,hypnotic mass.banal LOTOS(kamalasan) with proper execution(and the ability to remain in it without samoletostroitel about 3 hours)automatically drives the person in a trance ...and on.these poses weight.Siddhasana(to organismus changed for the correct fonzylane in this asana takes 10-12 years anyway.)halasana.sirsasana, with emphasis on the head(if you die from this exercise--then I have no complaints
