What session you can overlay your voice with affirmations?
- Дмитрий В.
- Been thanked: 2 times
Know what again to find via search and have not poluchilos.
Want affirmations for yourself to record your voice and scroll along with the alpha session MM PRO100.
Is it correct to use with the programs:
MEDITATION - 4. Body asleep, mind awake
MEDITATION - 10. Deep meditation
thank you!
thank you!
Dmitry V.may be more suitable session L03 - "Increased susceptibility to suggestion"?
According to the description: "This session gives a hypnagogic state in the alpha/theta range, on the verge of sleep, the state of relaxed receptivity. Of suggestion will be most effective after the first 12 minutes. Use in conjunction with your favorite wording suggestion (on tape for example, or self-hypnosis )"
Mention of this session is still here http://www.mindmachine.ru/viewtopic.php ... highlight=
- Дмитрий В.
- Дмитрий В.
Tried last night, well, effect!
It's really a training session with the effect vdalblivanie material in the head physical way
That after that glass of water you want, but get his ears, nose and eyes ))
Seriously,
there is a thread that is softer, similar to the Explorer that I had before going to sleep or during it? And then yesterday I up to 2 nights could not sleep.
Seriously,
Идущая вперед
- Been thanked: 6 times
- Дмитрий В.
Thank you!Идущая вперед wrote:disks hypnotic trance music for hypnosis and self-hypnosis.... there impose affirmations... the effect is at times... still drives Andrei Patrushev more effective...than session built into the mm....
I mean they thought they complicated, it is necessary to mix once 2 source
or next column bet (which I hate) or the 2nd player, or the cable from the computer or laptop.
By the way, the novapro 100 into a MIC input push line out, not Pohorje?
favorites from this http://www.mindmachine.ru/articles/afformations.htmИдущая вперед wrote:and you can put text there that you yourself inspire?
the best 10 minutes
Not worth feeding line signal into the microphone input. In the best case will receive the distorted signal (the sensitivity of the MIC input several times higher than linear) in the worst - anything will burn.Дмитрий В. wrote: By the way, the novapro 100 into a MIC input push line out, not Pohorje?
- Has thanked: 134 times
- Been thanked: 556 times
- Дмитрий В.
