Hello,
Have MM (Inner Pulse) is relatively long. While working on the alpha rhythms. Then I guess I'll work/visualization.
But my question is the following. It is known that there are a number of medical drugs, which enhance brain activity (memory, mental activity, learning, etc.) such as various nootropics (nootropil, piracetam). I remember when I was a student, people knew that the exams were prepared on Neotropin starting to take it for a month before the session. Yes, I took him to the emergency order, but haphazardly, not long before the exam. It seems to help the brain gather in a heap for a while. Also took Ginkgo Biloba, but I have to take it for a long time, that was more or less stoicity effect.
In connection with all above stated I want to ask.
Is it possible to combine a Mind Machine with the intake of Ginkgo Biloba or nootropics as well as vitamins, lecithin and other drugs and nutritional supplements, contributing to elevated brain activity?
On the one hand, it looks like this combination should be effective in the development of intelligence.. but who knows. With drugs use MM is prohibited. Maybe here the same song..
Mind Machines and nootropics
- Has thanked: 134 times
- Been thanked: 556 times
Thank you very much for the reply.
Only wanted to clarify. Ginkgo Biloba is possible only with the alpha training? When the bat and Tate can damage?
Alpha training I have done, I think perehoditi creativity and wanted to start taking medications for the brain
So I think whether it is possible to combine.
And I have one question for You Andrew, about the combination of Mind Machines with Yoga Nidrei. Right now it is possible to find quite a lot of mp3 files with instrukcia for Yoga Nidra from different famous Russian Yogis. That is, verbal instructions to navigate through the body of vitalitatii in the process of total relaxation.
This practice is most effective under the condition of good physical relaxation.
But can Yoga Nidra combined with a Mind Machine? There certainly is present the need to follow the instructions from the outside, and not to completely surrender in the embrace of light and sound, only passive watching the yield stress. I mean that the time of the session, all is accepted "as it comes". But it's with an alpha trendiga
It can, for example with sessions of group work/vizualizacia (since in addition to navigacii the body, is and visualization) must be effectively parallel to listen to the instructions of Yoga Nidra?
Thank you.
Thank you.
