Bought today innerpulse
Tried the program, has passed the current minute... how scary.... I have the feeling that might explode
what to do?
- Has thanked: 134 times
- Been thanked: 556 times
Re: bought today innerpulse
The volume and brightness removed to a comfortable level.Миссенка wrote:Tried the program, has passed the current minute... how scary.... I have the feeling that might explode((
what to do?
Guest
Yeah, there was already an enthusiast, who started sessions with the same session. Keep reading the forum.Миссенка wrote:I would like the form not read, chose just the minimum on time "rotation of the brain" .... for the first time - the less the better (female logic)Карил wrote:what are you on beta suffered? Andrei Patrushev probably more than a dozen times on the forum wrote that alpha should start... Confused
Я
How to put a manual in Russian to the sessions of the inner pulse, the one that was given while I was left far-vato from home, but the one that is on the forum does not allow to use it in conjunction with a machine (or rather the brain must strain when comparing English instructions available on the website).
Я
http://mindmachine.ru/photosonix/innerpulse.htm
It is not clear which letter MM on the screen corresponds to which mode, that's what I meant.
Hello!
Today I bought this wonderful thing called the inner pulse.
Delivered exactly on time.
Impressions about the appearance and ease of use just pull on a three point scale. Too many wires, the wires from the headphones, from the points from the power supply, and even for situsnya
The typewriter thinnest and lightest, not the impression of things for 6700р. Glasses also I krupchenko at first glance, though, and ColorTrack. Well, maybe I'm wrong about the quality and durability, I wonder if you drop it accidentally.... Just a cloud of wires, can only be used at home to you "alien" no one saw, and easy to use just lying.
Included a session entitled "wave of peace" Choate effect is not understood yet, but maybe there is still everything. You need to read the forum, then there is still need to do. Crazy like while not gone, and the feeling was not like this. Although when the husband wore glasses and also tried this session that asked not if he gets to the nuthouse
Yes, even when listening to the session, I had the feeling that eyes are open, this is the only neobichnoe that I felt.
I wonder at all the feeling of zero for the first time? Or maybe I do wrong???
You can be sure is tenaciousАлекса wrote:about the quality and durability
In-in!!!Алекса wrote:a lot of wires, the wires from the headphones, from the points from the power supply, and even for situsnya
Definitely notАлекса wrote:Although when the husband wore glasses and also tried this session that asked not if he gets to the nuthouse
But is it true of the purest waterАлекса wrote:you Need to read the forum, then there is still need to do.
ме-ди
кислый лимон
