Aura and elements
Posted: Sun Jun 03, 2012 16:29
Here on this interesting information the Internet came
As the first stage is to try to understand the net flow of the elements. To do this, recall the properties of the elements. If we talk about General properties – heat, cold, dryness and humidity, they are as follows. Fire - hot and dry Air - hot and moist Water - cold and moist, Earth cold and dry.
So, the first step. First, you need to use any physical media, the elements that you want to do. For Flame – candle Water – a bowl of water (if you have an altar – the altar of accessories work the most beautiful way!), for Air – fuming wand, for the Earth – stone, or a bowl of salt or earth. Sit back, not to be distracted by physiological sensations and to relax. Now try to feel the essence of the elements that you configure. As soon as I can catch the feeling, try, first, to "expand and deepen" it, may it be bright, full, second, to associate with the media. If all done successfully, you will feel around the object appeared aura, with (if successful) the color and qualities of the desired element. Not necessarily the colors (as sensations) must clearly be identical with those specified traditionally at the tables of correspondences, in the first stage, individual variations may occur.
The second stage of the meditation starts with the aura stronger element. Is to make it as strong as you can. When you do this, keep the thread, it should have the same characteristics as at the end of the first stage. Now – a qualitative transition. Transform the aura in direct channel up. Up to perfect, clean condition this natural disaster. To do this, logging in with an existing aura (or extending it to that one and the same), stretch up, trying to clean, high as the elements. Themselves up do not need to go. You want the aura stretched up, turning in a tight vertical flow with non-uniform vertical structure. For this achievement, perhaps, is to finish the second stage.
The third step natural meditation can be considered possible, when you have a good natural channel extending from material source up to the ideal state of the elements. The task in this step is as close to the ideal existing, that is you have created a natural flow. In my opinion, it is best that stage to perform under the guidance of a teacher. However, if you are strongly confident in their ability to comprehend the essence of the elements, can do for yourself. Gather all your feelings together and try to move the post element up. On successful promotion you will feel how energy, colors are brighter, feelings are sharper and richer. It is not necessary to climb at this stage, at the slightest feeling of discomfort down below. Finding for yourself the most comfortable area, stay there, achieving stabilization of sensations. Typically, this step requires some training. It should be emphasized that it is necessary to train with all four elements, preventing imbalance.
Rising in familiar and comfortable for you to natural flow, look around. You are surrounded by the dark, glitter, flowers, streams. They are, in a good case, have a uniform, more or less homogeneous in nature. Now listen to yourself. Try to see echoes of the same threads within. Listen to what your part will respond resonating flows? That you are flashing the same colors? Search for resonance in one word. Until you find it.
Found by you – part of this element in you, your body and your life – depending on the settings. It's part of you, recognize it as belonging to that element in the stream where you are. Try to keep the sound of your threads have been harmoniously attuned with those around you externally. Achieve harmony. Not worth it at first to be too persistent, don't try to change yourself. Moreover, regular meditation even thirds of the stage will lead to the automatic, albeit slow, adjust your personal natural flows to the pure natural.<
