washed the front room :)
Posted: Mon Mar 01, 2010 14:56
The room washed in the washing machine. (accidentally of course) it's the end of it?
To the card Good is true? After washing one side (where room) fully became white, without lamination, all lettering and illustration faded. The other side unchanged.Dimas wrote:Дмитрий000
if it is not broke,not the end. I also washed
The loss pattern on the outer surface of the card does not affect its performance, if not stratified internal layers. However, if not preserved (not recorded previously), it is difficult to activate the keys. But also possible. If you need to buy the keys to this map, it will be necessary to consider a room with an RFID element that is inside the card. And activate the key on this number.Л@на wrote:To the card Good is true? After washing one side (where room) fully became white, without lamination, all lettering and illustration faded. The other side unchanged.Dimas wrote:Дмитрий000
Room Chamber Benefits 9 digits....АСД wrote:due To the fact that there is an interest in keys, I want to clarify some points.
1. You should adjust the title of this topic. The Good word is plural. Therefore, the inducement to Good wrong. Have to call the subject: the keys to a Good Parlor or the keys to the Benefits.
2. As Svetlitsa - Blaga has three different scales, and keys, respectively, three different denominations. The keys provide the capacity fractal coherence with the structure of the Svetlitsa - Blaga gradually in smaller steps compared to the cards Svetlitsa - Blaga.
3. Explain the activation key. Each key has a number. A user who purchased the key at this site sends number +79161647474 SMS message: register the key number (key number) in the card number (card number). In response it needs to obtain SMS with the text: the card number is activated.
The user then applies the key to the map for 30 minutes. Continue to carry the key with them is not required. Although it can be used for structuring water, food and money (removing structural distortions).
4. The assumption that the key exchange is incorrect. Getting the key had been in the hands of others (proteinopathies with another card) do not add. The keys help to increase the flow of goods at the output (as part of the total flow).
5. Acquiring keys is not a compulsory procedure. If the person who bought the card of the Svetlitsa - Blaga, make sure it is working (got the increase in the flow of goods), it can be part of the received flow feedback direct to dispersal of the total flow of private wealth. Receiving a further increment, it can acquire the next key, etc. The frequency can be any. We recommend you to buy a key every 2-3 months. But everyone decides for himself, whether to buy him the keys and with some period.
Маг.нет wrote:.
Activation keys:
5. Acquiring keys is not a compulsory procedure. If the person who bought the card of the Svetlitsa - Blaga, make sure it is working (got the increase in the flow of goods), it can be part of the received flow feedback direct to dispersal of the total flow of private wealth. Receiving a further increment, it can acquire the next key, etc. the Frequency can be any. We recommend you to buy a key every 2-3 months. But everyone decides for himself, whether to buy him the keys and with some period.
Sincerely, MAG.no
Perhaps Your card number available from the seller. Therefore, they identified Your key with Your card number.Л@на wrote:MAG.no thanksI just sent SMS sans room key, without specifying card number, that I somehow missed.
Yes, now I remember that the first SMS was sent strictly according to instructions, ie, with the room key in the card number. And all subsequent ones, every 2-3 months already without a number card. Because the SMS from the same numbers, I think the seller is identified with my card.АСД wrote:Perhaps Your card number available from the seller. Therefore, they identified Your key with Your card number.Л@на wrote:MAG.no thanksI just sent SMS sans room key, without specifying card number, that I somehow missed.
It would be nice to warn buyers that the card has a RFID chip. If I knew that, it just would Good bought.АСД wrote: it will be necessary to consider a room with an RFID element that is inside the card
