Page 1 of 3
Svetlitsa Windows
Posted: Fri Oct 09, 2009 13:36
by Жека3000
For some reason the forum is not yet established the theme of the front Room Window!
What is the reason? No one uses them? Or are they not effective?
I have had questions on this topic.
1. What tangible effects creates the parlor Window? For insensitive to subtle energies.
2. They need to be glued directly to window glass or frame? (in the description read it, but someone even the wall pasted...)
3. If the parlor Window structures the space in the room, for what else and the WAY to glue on the devices?
4. Users front Room Window, describe Your feelings about usage.
5. The description says that converted light, and if the window shuttered always, the front room window does not operate or operates less efficiently?
6. How long does the effect after you exit the room with the Parlor Windows? And keeps any effect at all?
7. Why the claimed range of the front Room Window more than the front Room is Super and the price at the front Room Window below?
Even the description says that the kit is designed for 20kV.m. of the room. Ie one set is enough for the unconditional structuring of space on the square 20 sq.m? And the ceiling height is affected by something like(there are apartments where the ceiling height of 270cm, and where there is 400cm)? In other words, the cubic volume has the value, or the calculations need only be carried out by m?
Think about the Parlor window because leaves the idea that I slept in the new apartment, no, not rest and want to sleep all the time, even if the fact that since the appearance of my Room I break up with her for more than an hour or two a day (at least 22 hours a day of SS with me).
So the main question is do fix the parlor Window position?
In the description read it! And just stated effect works for me! Here only will I feel it, or I will again tell you that I am not sensitive to subtle energies and though I'm not feeling the parlor Windows it works and does the job!
Whether the effect is TANGIBLE! Ie without a Chamber Window, slept badly, had navyseals, etc. Glued the front Room Window and everything was GREAT.<
Posted: Fri Oct 09, 2009 22:25
by Жека3000
Hmm! Weird! T that today, no activity on the forum... And about the Windows one does not want to write... ASD was not answered! Very sorry! Waiting for answers competent. Really looking forward to!
Posted: Sat Oct 10, 2009 3:26
by МерКаБа
Жека3000
In some parts of the seminar ASD says Svetlitsa - Windows does not eliminate geopathic impacts, and negotiates their structure and harm to human disappears.
Posted: Sat Oct 10, 2009 12:40
by МерКаБа
Day after tomorrow, I hope I'll be Stelica Windows and Good. Window, glued to their parents in the bedroom and will conduct surveys. :) Will definitely report on the results in this thread.
Posted: Sat Oct 10, 2009 14:05
by ИВ
I have with the Svetlitsa-Windows is such a story: in the room on the wall hung a clock, watch good Japanese, but for some reason they refused to go (battery change, repair worn - all to no avail). The idea is that we had to throw them away, but somehow hands did not reach. One summer evening I stuck to the window of the Parlor Windows, and the next day discovered that the watch went! :shock: Since then, it took more than three months, with hours everything is fine. Personally, I Svetlitsa-Windows do not feel in any way, but it seems to really affect the space.
Posted: Sun Oct 11, 2009 20:35
by Жека3000
МерКаБа wrote:will report on the results in this thread.
I'll be waiting! :)
Posted: Sun Oct 11, 2009 20:37
by Жека3000
ИВ wrote:Personally, I Svetlitsa-Windows do not feel in any way, but it seems to really affect the space.
With the clock example is interesting!:) I would still physically feel something
Posted: Mon Oct 19, 2009 23:41
by Солнышко :-)
ASD I somehow missed on the forum may have been written. Svetlitsa-Windows is mounted on the outer side of the window, with internal or no difference? az
Posted: Mon Oct 19, 2009 23:44
by АСД
Солнышко :-) wrote:ASD I somehow missed on the forum may have been written. Svetlitsa-Windows is mounted on the outer side of the window, with internal or no difference? az
Internal.
Posted: Thu Oct 22, 2009 17:13
by Жека3000
That is not FAQа not see any answers...
Posted: Thu Oct 22, 2009 22:38
by Берт
ASD
Is it permissible to consolidate the Parlor-Window a short distance from the glass (a few mm adjacent to the window curtain) or definitely gluing?
Posted: Fri Oct 23, 2009 13:28
by Жека3000
МерКаБа wrote:day after tomorrow, I hope I'll be Stelica Windows and Good. Window, glued to their parents in the bedroom and will conduct surveys. Will definitely report on the results in this thread.
The parcel came with a Parlor?
Results what something is?
Posted: Sat Jan 16, 2010 6:38
by Guest
...The first is a flexible rectangular large frame glued to the bottom of the window, the second (square, small) – glued on the top piece of glass diagonally from the first.
So on the frame or on the glass. If on the frame, should the plane labels match, or be perpendicular to each other? If they do not adhere, and attach with tape for example, using a slightly larger piece of paper, so that when moving gently, without damaging, to detach?
Posted: Mon Jan 18, 2010 1:34
by Guest
Anonymous wrote:...the First is a flexible rectangular large frame glued to the bottom of the window, the second (square, small) – glued on the top piece of glass diagonally from the first.
One on the frame, the other on the glass. The plane must be parallel. You can secure with tape.
Posted: Mon Jan 18, 2010 3:34
by Guest
Гость wrote:the Plane must be parallel. You can secure with tape.
That is, a plane parallel to, but between them there should be a distance ( from the glass to the outer surface of the frame on which is glued a large part )?
Posted: Wed Jan 20, 2010 15:45
by АСД
The easiest way to determine the location of the labels: mentally draw a square window with sides of 1 meter to one of the corners was on the frame and at least one corner on the glass. On any diagonal of the square place the stickers, but that one fell on the frame, and the other on the glass.
Posted: Fri Jan 22, 2010 17:24
by Ванес
Question. When gluing the white rectangular part somehow managed to detach part of the adhesive layer (painfully, he easily went). Under it there film brilliant some, I understand the working surface. Part of the glitter is left on the delaminated piece of... Work will it?
Posted: Sun Jan 24, 2010 8:20
by АСД
Ванес wrote:Question. When gluing the white rectangular part somehow managed to detach part of the adhesive layer (painfully, he easily went). Under it there film brilliant some, I understand the working surface. Part of the glitter is left on the delaminated piece of... Work will it?
A brilliant film, it's more of a laminate (judging by the description). So everything should work.
Posted: Sun Jan 24, 2010 13:35
by Ванес
Thanks for the reply, but perhaps I inaccurately described. This is where the laminate pattern, and there is something like a foil was actually in the middle of the product-side layer of glue.
Me here one more moment interested. And if the room has multiple Windows? One window in the room faces the road, the second - in the yard. The idea of the flow of information from the road and more coming, and it is necessary to glue? Further. The description says the room is 20 square meters. And if the room is 6 square meters?
Posted: Sun Jan 24, 2010 17:07
by АСД
Ванес wrote: Me here one more moment interested. And if the room has multiple Windows? One window in the room faces the road, the second - in the yard. The idea of the flow of information from the road and more coming, and it is necessary to glue? Further. The description says the room is 20 square meters. And if the room is 6 square meters?
The idea is that I need to Clit on the window facing the road.
20 sq. m. is the maximum for effective work. If less, then all is well.
Posted: Tue Aug 17, 2010 8:17
by MVN
The question of sleep.
Can the Parlor-window to use as a mirror of ISIS? After all, both devices change the structure of the glass. Only glass Parlor window makes the outside incoming radiation is coherent, and the mirror returns the internal coherent light. Right?
Posted: Wed Aug 18, 2010 22:29
by АСД
Владимир Мокрушин wrote:Question from sleep.
At first glance, all right, but don't forget that these products differ in structure. The structure is formed under the task. And tasks of these products, different. Different in energy and in dimension. Harmonization of the structure of space with the structure of man and the restoration of the structure of human connections in time are completely different processes. As various, as different processes of education and enlightenment of man are based on light.
Your question is clear. It arises from the fact that the structure of most of the people do not perceive directly with their senses.
Some result from the use of a Chamber-Window in the mirror, You of course will receive, but not to the extent as from the use of the structure of the Mirror of ISIS.
Posted: Fri Sep 03, 2010 13:02
by Malvina
Stuck a front Room window, about three weeks ago.It seems at first glance nothing has changed.
I have been feeling that CROWDED, not enough space and I want to extend the living space.And then began to discuss the housing problem and I realized that the feeling of tightness is gone.I'm good and comfortable.I wonder why.Because the apartment was, and remained, and nothing in it has changed in that time.
Posted: Sat Sep 04, 2010 17:58
by АСД
Malvina wrote:Put the Parlor window, about three weeks ago.It seems at first glance nothing has changed.
You are right, noting that at first glance nothing has changed. Most users also did not notice. Some, however, add some observations that relate not to their States, and changes with the environment. For example, Alla from Minsk added, when hung in the kitchen, the children began to walk to the kitchen to learn the lessons, and when I hung them in the room, I no longer teach at home.
Or another example. One store owner from the city of Krasnodar hung two sets in the shop which is located inside a major shopping centre. For a long time said that I didn't notice. When after 3 months I went to the store, I saw that completely changed the image of the store (design, sign), the staff has changed and the product range. From a dull and dreary shop has become bright and bright. That is, changes in the structure of space is causing changes in the physical plan. After that, she purchased the Parlor-the Good and soon in a party with a friend won a trip to Italy. There she established contacts with Italian firms. Now it is quite a successful shop.
Nabludenie another person, who also didn't notice any changes in my daughter after the school year looked tired and exhausted as usual. I had the impression that she could study further. Better to learn. She initiated a transfer to another school with better teaching quality.
Posted: Wed Feb 02, 2011 8:33
by MVN
The Svetlitsa-Windows was installed in the office. Online activities, so the office only for their own, i.e. visiting nobody walks on our activities. But neighbors are kommivojazhera-the scribes, and to them constantly through advertisements you come to get a lot of people. Now only realized that very often to us to come with a question- "Here to work accept." And it turns out that you know the name of neighbors. And the sign does not like the neighborhood. Prior to the installation of a chamber-window, never noticed. I think the reason all of this. Maybe a valuable employee there?
Among other things, clean want to clean the room. All was neatly.
