A question about Mirror of ISIS
- Малика
- Has thanked: 251 times
- Been thanked: 110 times
Re: a Question about Mirror of ISIS
Lily, thank you ! So much time used the mirror and never looked back there, and when there was a new card, the question arose where and how to glue . So, thanks again for the reply
Well that opened this subject, when the room shifted under the other mirrors in the country prikrila not correct. I was surprised that there is no effect....
has anyone done a mirror of the 4th generation? different than before? the effects? feeling?
Thank you.
Thank you.
- Ростислав
- Has thanked: 35 times
- Been thanked: 28 times
- Contact:
It's hard to say but I bought a mirror recently, most likely 4th generation but there is no other to compare with
How about sleeping in a room with a mirror glued to it card?
- Малика
I have two card ISIS 4th generation glued on mirror 2 paintings in the hallway (wardrobe 3 doors) Before, in the dark, I tried to quickly slip past those doors, it was very uncomfortable to be around them, especially in the dark. Now, I calmly walk around those doors at any time, but in my mind is to buy another card and stick on the third door
Card of ISIS the previous one, bought in early 2010. pasted on my vanity mirror, I work with him constantly, daily
As for the difference, then maybe I don't really feel it as a wardrobe in the hallway, I about his short time there, got dressed and forward
what rasstojanii from the eyes necessary to keep the mirror?the picture on the card that visulaise between the mirror and cardboard dolgen to be directed at yourself etim risunkom or drawing from yourself?
- Has thanked: 1 time
- Been thanked: 182 times
- Contact:
On comfortable.
Card is applied to the reverse side of the mirror with the white side.
ie drawing on time in this match. will not me somtret and from me when I look in the mirror ?
Русалка wrote:information about the size stickers on the mirror
, here.appearance - a plastic card the size of 85х54 mm (type credit) with two embedded devices-class parlor.
It's not a sticker card the size of the Bank. What's the point nasit with him, the effect occurs only when a person looks in the mirror. I don't know, what is the use to stare at "the palm"?Русалка wrote:I can't find information about the size stickers on the mirror. Asking because I want to buy a small mirror, constantly to carry.
But in General, I advise to get, I like it!
- Ростислав
- Contact:
There is in fact a mirror already fused elements of type powder
- Разработчик
- Has thanked: 4 times
- Been thanked: 147 times
- Contact:
It was a trial experiment that did not go as well as mirrors in the compacts do not have the required quality. Too thin. Need 4-5mm.Ростислав wrote:Is because the mirror already fused elements of type powder
Is there a way to test objectively the validity of the mirrors, bandages,parlor ?
- Ростислав
- Contact:
and how you checked it? my wife still such putannitsa ((((АСД wrote:trial experiment that did not go as well as mirrors in the compacts do not have the required quality. Too thin. Need 4-5mm.
- Contact:
http://www.mindmachine.ru/infokonstruktor/lik.htmВинсент wrote:is There a way to test objectively the validity of the mirrors, bandages,parlor ?
I may be repeating myself, but all the same I ask, because it is not found information. What would be the minimum size of the mirror for normal operation of the device?
- Ростислав
- Contact:
the minimum card size
Important is the thickness of the mirror ? Do I understand correctly?
- Ростислав
- Contact:
Yes, at least 4-5 mm
OK , Rostislav, thank you!!!
