I would like to hear the feelings/opinions/impressions/comments/assumptions about the impact of the Parlor and meditation.
Use of the Svetlitsa-With less than a month. There is a feeling that the presence of the Chamber does not take on the usual depth. Source it felt like some itching in my body... he's gone now, but there is a feeling that something does not allow you to take... Strictly speaking, I can't say that it is connected with the Parlor. There is a coincidence in time of the beginning of use, but maybe it's just a coincidence. Plan to keep the Room at meditatii, and see what happens.
Anyway, I see that some people wrote about similar feelings from a Chamber at the first time of use, when talking about sleep. With sleep I, by the way, no problem.
Of course it would be very interesting to measure the distribution of brainwave frequencies with the Room and no... to see if there was some influence.
Anyone have similar experience or any thoughts on this?
Svetlitsy and Meditation
Guest
You need to remove the Window. Because it will block everything that is not the norm. For example, the opening of the third eye is not the norm. With the Parlor will not work.
But if we imagine the inept practices will make the imbalance of energy - the parlor quickly restore everything - will lead to normal.
Wrong. The effect of normalizing the Chamber appears as a consequence restore the connectivity and integrity of the person. The opening of the third eye - the process of increasing and manifestations of the quantity and quality of links. Therefore, the chamber will facilitate the opening of the third eye.Гость wrote:you need to Remove the Window. Because it will block everything that is not the norm. For example, the opening of the third eye is not the norm. With the Parlor will not work.
I have one friend hold the Window in the hands of a few minutes, began to see the aura of people. It is clear that the quality of the vision she had, but manifested this quality when using a Chamber recovered some connections.
This thesis is correct. Put another way: the chamber will contribute to practices became a skilful and correct.Гость wrote:But if we imagine the inept practices will make the imbalance of energy - the parlor quickly restore everything - will lead to normal.
Александр79
АСД wrote:Wrong. The effect of normalizing the Chamber appears as a consequence restore the connectivity and integrity of the person. The opening of the third eye - the process of increasing and manifestations of the quantity and quality of links. Therefore, the chamber will facilitate the opening of the third eye.Гость wrote:you need to Remove the Window. Because it will block everything that is not the norm. For example, the opening of the third eye is not the norm. With the Parlor will not work.
I Have one friend hold the Window in the hands of a few minutes, began to see the aura of people. It is clear that the quality of the vision she had, but manifested this quality when using a Chamber recovered some connections.This thesis is correct. Put another way: the chamber will contribute to practices became a skilful and correct.Гость wrote:But if we imagine the inept practices will make the imbalance of energy - the parlor quickly restore everything - will lead to normal.
Quite confused. So it creates a process of normalizing or increasing?
Svetlitsy and other products lik increase the connectivity of the system - improve the quality of structural bonds, resulting in implementing a normalization process (movement to normal). Due to the improvement of the relations reduces the influence poliobraces factors on certain systems and those systems being established (normalized). That is, if the parameters of the system were below normal, they will grow, if overweight, decrease. The farther from the norm, the brighter effects. If everything was normal, the effect is not noticeable.Александр79 wrote:quite Confused. So it creates a process of normalizing or increasing?
Not only in the East. Any gift can show the person alone with his labor. Svetlitsy only help him in this not easy work to become more efficient, spend less time fighting with various interference. And it happens that the person lacks only a trifle, to get the result. Then using the front Room seems a miracle, although the main result has been prepared by the human activities.Александр79 wrote: In the East, even in ideal conditions, not everyone is given this gift from above, and then... Magic.
Guest
