Mat - "Grace"
Re: Mat-Grace
Now here we are companions on the edge of a fucking high cliff, and
around the same high cliffs, like needles into the sky.
Look down - depth is a knockout, I think if you fall, then a couple of moments to fly accurately.
More curious than afraid. And yet, I can see everything fine, better than in real life.
Near the top of the cliff at the same height, you can run and jump. took some sliding wire bridge,
he parted and let him run up and back over the precipice.
Then the bridge began to move apart until the end, one step, had to jump from the edge of the rock..
It was already worse. It was very cool.
The first night on the rug was a dream.
Re: Mat-Grace
where is the front of the Mat, where in addition to stitched ribbons with one side explaining the other symbols to distinguish between failed?
Re: Mat-Grace
On the inside of the Mat on one side should be a label side, which is to person.арте:м wrote:and where is the front of the Mat, where in addition to stitched ribbons with one side explaining the other symbols to distinguish between failed?
Re: Mat-Grace
removed the inner part of the pad (that Velcro) entirely outside. a detailed inspection is nothing like the label is not revealed. can we at least Velcro to understand on which side they are sewn: on the front or Vice versa?
Re: Mat-Grace
Velcro on the inner part are on the side of that person.арте:м wrote:removed the inner part of the pad (that Velcro) entirely outside. a detailed inspection is nothing like the label is not revealed. can we at least Velcro to understand on which side they are sewn: on the front or Vice versa?
Re: Mat-Grace
Had to wash the rug completely, now care about preserving its properties. Sergei Dinowitz wrote so better not to do
Recent insomnia, I Wake up three o'clock in the night and all of anything to do, and fall asleep six to "Good morning, mother" with such a regime Yes, subject to certain circumstances I think it would be very hard, but get up in the morning and like normal, I think it is just a matter in the carpet
Re: Mat-Grace
Yesterday I bought a Mat and obvious. Use alternately with his wife. In the test and the subsequent use of the wife warms the back and neck while in the head.
I at first was like the rays penetrate from the spine to the head. The second use has given the same feeling, but at the end of the session I found myself in a highly altered state of consciousness.( Quietly, slowly, well)
the third use was in the morning after sleep. The most vivid sensations. As if from behind me Shine through the strong flow of energy, and nice and almost tickled. The fourth use after work, or even sleep. But a quick rest and woke up an hour and a half. The effects and results of use until reviews naturally not.
Re: Mat-Grace
My friend is a massage therapist, the sensitivity of her good.
Gave her a Mat on the test, liked the long didn't.)
It it like a Cape on his head, and so sitting or standing blissed out, speaks well of him recovering.
Re: Mat-Grace
Apparently the rug is constantly being improved, because on my no labels no stickers present. How to determine the working side when the liner was yellow, through white looked through the rows of squares, and the straps on the side yellow?
Re: Mat-Grace
***** All the mats in the case are the yellow side to the straps, then to himself.
There is no Velcro in the last mats, Yes, there are inconveniences. The inner part of the pad when dressing on the shoulders, if you use it standing up-sitting down without fixing it on the Velcro. Possible if the manufacturer forgot to sew the Velcro may have decided that it is not necessary.
Although sticky Mat does not change the case into a ball.
Re: Mat-Grace
Thanks for the clarification!
And most prisobachit Velcro, and if you can then on the perimeter or in the corners?
Re: Mat-Grace
***** Can on 4 corners . In the previous it was like.
With Velcro to stray into a ball will not.
Re: Mat-Grace
https://youtu.be/C-0Kq33NDxk here it isММ wrote:Someone put the photo of the rug on the website.
Любознательная
Re: Mat-Grace
I bought a Mat,sorry that not brought было108 series,although the site wrote that the mats have already been announced.is there a big difference between the Mat which is inside the boxes (my boxes) and the Mat which is inside all printed on fabric? Although I don't quite understand the effect,I did not would prove not heated and not moving:-):-):-)is not working or I have it all started?
Re: Mat-Grace
Usually those who have "started", there are strong feelings. The better and cleaner the body is, the thinner the setting the Mat and the less the feeling of it.Любознательная wrote:I don't quite understand the effect,I did not would prove not heated and not moving:-):-):-)is not working or I have it all started?
Try to take a closer listen to your body. You can increase the effects of Mat various models (meditations, affirmations, etc.).
Re: Mat-Grace
Actually my first time on the Mat was that it doesn't work )
but then after a while I became so sleep much ))) although saying that on the contrary it should be - now him, I just burst of energy
in General, a very interesting and powerful device.
Любознательная
Re: Mat-Grace
Rostislav I watched the video on YouTube and wanted (Mat) from buy,very useful video and the demonstration,and I would use the Mat to observe and accomplish your goal what changes felt
Re: Mat-Grace
There is a Mat well. Legs tingling and burning in the skin, but this I shield positive effect. The skin of the feet affected with all sorts of parasitism, therefore, and probably burning. Yes restore after the working day the energy of the body. At night cover with a rug, a pillow and a greatly increased information dreams, like shastania on technocratic, mostly dreams. Effects are probably reinforced by the almost complete Assembly of the work of Mikhail, which are actively working. Room feel too bright. Happy to use the Mat.
Re: Mat-Grace
One question how to wash a rug without loss of efficiency?
Re: Mat-Grace
The Mat is the Grace of two parts. Internal structures inside and outside the case. It is necessary to remove the interior and wash the exterior. If necessary, can be washed and domestic warm water by hands. However, it is not recommended to iron. Before the structure was plastic and vivalis vnur. You can feel them to the touch. Now they are printed on the fabric, therefore, not be felt. Printed structures can withstand multiple washings without loss of efficiency.Рома З wrote:One question how to wash a rug without loss of efficiency?
Re: Mat-Grace
Understood. Thank you for your answer.
