Page 7 of 9
Re: Contraindications
Posted: Thu Mar 14, 2013 18:05
Siren The session should be carried out in the presence of the doctor as possible the following reactions: epileptic fit, spasm, or, conversely, fall tonics, blood vessels of the brain, delirium.
About Healing - the reaction is normal (at everyone). It is possible not more often two times a day with a break of at least 3 hours.
Posted: Thu Mar 14, 2013 19:39
by Сирена
If any of the symptoms (listed by you) will arise-the use of MM in any case no longer use?! Sorry of course if I buy this device, and he told me to be contraindicated. If only it was possible for an early first place to try , and if everything is in order, then we buy. Unfortunately, I don't know where we have here in Germany, you can try a session. Can you do something about it can tell, at least roughly. What do you think about the device, Alphamania", can I use it and get positive results despite my symptoms? Thanks again for your attention. Waiting for your reply.
Posted: Tue Aug 20, 2013 18:18
by Жомик
Good day to all! Been wanting to ask. People with intracranial pressure can listen to the program Patrushev and APK-program?
Thanks in advance for the answer!
Posted: Tue Aug 20, 2013 18:26
Iomic
Without light you can.
Posted: Wed Oct 09, 2013 20:30
by Дзын
Hello!
The observed M, the diagnosis of acute polymorphic psychotic disorder while taking a psychotropic drug, 2.5 months undergoing treatment (haloperidol, trihexyphenidyl, carbamazepine ). Now complaints about sleepy state prevailing debility, although it at least made the reception tisercinum.
NOTE THE QUESTION!
If this is the case the application Navigator, what session do you recommend?
Thank you for your attention
Posted: Wed Oct 09, 2013 20:32
Дзын wrote:note the QUESTION!If this is the case the application Navigator, what session do you recommend?
Absolutely contraindicated.
Posted: Thu Oct 10, 2013 2:47
by Дзын
Thank you, maybe after this course ?
Posted: Thu Oct 10, 2013 9:24
dzyn
Not earlier than three months.
Posted: Thu Oct 10, 2013 18:37
by Дзын
[quote][/quote]
Then to meetings, thank you very much
Posted: Fri Oct 18, 2013 15:41
by Я-Каторга
Can I apply if vnutricerepnae hypertension and the application of sedative
Posted: Fri Oct 18, 2013 18:39
I-hard labor
Better not to risk it. If you really want, you can only discs.
Posted: Thu Dec 26, 2013 21:17
by Алексан
Andrew, good evening!I am very interested in your car,but Your note to protivopokazaniya written,if there was a head injury then it is necessary to consult a doctor,the question - how? the one who put the diagnostician or you have a special, which could determine is necessary to try or not.there is a desire, there is a machine, but there is a note to protivopokazaniya.how to be in this case?
Posted: Thu Dec 26, 2013 21:25
Alexan
With Your doctor.
Posted: Wed May 14, 2014 22:26
by Валерий Пермь
Hello! I have a meningioma right frontal lobe if I could use a MM?
Posted: Wed May 14, 2014 22:29
Valery Perm
Hello.
I don't know exactly, but hardly... Perhaps even one sound impossible.
Posted: Sat May 17, 2014 21:03
by Валерий Пермь
Hi Andrew! Thanks for the reply. I last year a friend gave hypnotic audio programs for Health, thus I'm trying to get rid of this sore. Sens in the entry have an alpha, beta, Delta frequency (in his words I don't understand). Listen to them periodically, like normal. Wanted here and purchase MM, for bigger health effect. What do you think can help or is it still there?!
Posted: Sun May 18, 2014 1:36
Valery Perm
Still with the light in Your case it is better not to experiment.
Posted: Sun May 18, 2014 15:17
by Валерий Пермь
OK! Thanks for the reply!
Posted: Sun May 18, 2014 15:19
by Валерий Пермь
Another question, if you buy MM, then listen to I can, but in MM the main light or audio?!
Posted: Sun May 18, 2014 15:25
Valery Perm
Light.
Posted: Sun May 18, 2014 15:36
by Валерий Пермь
OK, thank you!
Posted: Sun Jun 29, 2014 19:37
by Гарет
Good day, Andrew!
Want to buy Navigator.
In his youth, had two concussions, are now engaged in a dogfight (without fanaticism), in the head no discomfort is felt, except when you need to bend over while standing upside down or doing push-UPS by putting your feet well supported.
A couple of months ago, did MRI, all normal.
Is it possible in my case to use a MM?
Posted: Sun Jun 29, 2014 20:11
Gareth
Hello.
Yes, you can.
Posted: Sun Jun 29, 2014 22:04
by Гарет
Thank you.
Posted: Tue Jul 08, 2014 14:25
by Алексц
Acquired Innerpulse, a week ago had surgery to correct the nasal septum under General anaesthesia, 4 times used, the last two times these headaches. Is it possible to use the machine?
