About the motives
Drain off all negative, but with the hope that something good will sprout...
Смелый
Has thanked: 2 times
Been thanked: 79 times
Re: About the motives
Post by Смелый » Mon Jul 06, 2015 4:04
кекс wrote:Conducts complete diagnosis of the organism on the basis of electromagnetic waves of low frequency,
кекс wrote: In the testing process we have with Dr. improved mental contact
Appliance lowered the frequency of the brain. The same thing happens when I conduct a full, high-quality meditation. For example, the Transcendental meditation technique. Yes, even if in a group. Go and full of energy and soul, lovely mood.
СтаниФилмТВ wrote:is Achieved by the ability of a person to experience a certain state, and used for presentations, seminars, lectures, personal consultations, sermons, etc. So if any person knows how to win, and conducts public events, it is likely to be, as You say brainwashing, and retraction, to any sect or organization.
The Work Of The Egregore. Disconnect the leader from the Egregor, and all the charm will go away. It makes it simple. Imagine that you have in hand a long rope. The type of rope. In fact, the energy harness. And get mentally adept at jumping, the rope rotating around the follower/leader. When energiegut repeatedly flies over the head of the follower/leader, he gradually cuts the connection between adept/leader and his Egregore. Chirping and charm pretty quickly eroding. Our attraction to the person, or what we value, like personal charm of the source, nothing like the infusion of additional energy. Got extra energy up. And it seems to us that the source of mental got. In fact, his egregore has joined us. And here technology, the type of techniques off from energofinprom, will not help. You don't pump out energy. On the contrary, frighten. You're nice, in a rush. The more you communicate, the stronger the binding. Like a drug.
кекс wrote:the person is introduced by the influence of the product in a certain area of comfort, neopredelennosti, acceptance, suggestibility and begin a banal brainwashing.
Of course, the person enters the alpha state and suggestibility increases.
кекс wrote:the same goes for products on this website.
Not the same. Through reading the forum pages, in alpha state will not slide.
кекс wrote:Take the same room - people wear their packs. All want to buy, poor guy
Everyone has their own way. Buying products is dictated by the internal needs of a person. And there, each of us, no one knows. By the way, front Room, as I understand it, was created not for internal alterations, and to reduce the external influence. Which, many of us simply underestimate.
кекс wrote:to warn the RAID of fanatics I must say that this is my subjective opinion.
I'm not disputing Your opinion. Just Express your vision for You expressed things..<
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Post by мимоходом » Mon Jul 06, 2015 9:51
The vertical channel is not an egregore. Perhaps this fear leads to a disconnect from that channel and de-energizing people.
Vertical channel to another person is not disable from the outside, but connected units, it is possible not to worry. But the person from external influences fully protected and influence through deception, manipulation, when he will agree with any statement (such as "iris, let's read your fortune?"). Here through this narrow back door just cracked brain, and then with man made anything
The alpha state is the normal regular rhythm of the person. He was rolled by anyone, anytime, enough excitement to calm a little and meditate a bit. It is not the theta rhythm, where to go difficult and which is associated with enhanced perception.
The alpha condition is not related to suggestibility directly. Serotonin reinforcements of course the body perceives as a carrot, but after a while begins to understand the varieties. Suggestibility is associated with not very developed frontal lobes, which are responsible for the will of man. Lobotomy, both physiological and chemical (brainwashing) just the will of a person takes away from the ends.
Смелый
Post by Смелый » Mon Jul 06, 2015 10:47
мимоходом wrote:a Vertical channel is not aggregor
Just Egregor is! Otherwise, how will these Egregors to control us? Climb into the head and connect to various programs. That would give energy to the programs for their implementation.Or to deprive us of something or to give something or to close something and so on. As play the piano.
мимоходом wrote:Perhaps this fear leads to a disconnect from that channel and de-energizing people.
Disconnect from what? And what blackout? Specialists in brainwashing a lot. Yes, the problem is that the washers themselves have brains not very fine.
There Is A Flow Of Energy Downward. And there is an Upward. In an ideal scenario, the flows should be easy to flow along the spine. Man was created, the type of carrots from the garden, for the Parent. As food. The energy of the Earth received them, should be easy to follow the Higher energy and information entities. When a person ages and energy through it almost breaks up, give it to be devoured by entities of a different order.
The downward flow of energy cleanses. He good functioning of the lower chakras. Joyful emotions, and so forth, along with the Ascending energy flow go up.
Then we guzzle horrible, disturbed metabolism, internal sediment, by displacement of the internal organs and so on. As a consequence, the internal energy channels are displaced and cease to function normally.
For the functioning of the energy channels of the Subconscious mind. For material benefits we receive from Egregors, as a result of energy exchange. The subconscious mind has blocked Energocenter, less Energy went to the Egregore - less benefits received. Everything is solved on the Fine plane. It just seems that people are able to move mountains.
Capable, but not everyone.
Capable, but only with the help of Higher Forces.
мимоходом wrote:a Vertical channel to another person not to off side
Easy! However, for a short period of time, and at that moment, when you people associate your style.
мимоходом wrote:however it is connected among units, it is possible not to worry.
All connected. But in different ways. And different Forces.
мимоходом wrote:But the person from external influences fully protected
Yes? Who said that?
мимоходом wrote:to influence through deception, manipulation,
But what about protected? We are on the Deir when I got some practice, became staunch supporters of the opposite point of view.
мимоходом wrote:when he will agree with any statement
And when you do not agree, the same thing. Suggestion, proof.
мимоходом wrote:Serotonin reinforcements of course the body perceives as a carrot, but after a while begins to understand the varieties.
That the people of the sects millions of belching. He is started to understand what was happening!
мимоходом wrote:Suggestibility is associated with not very developed frontal lobes, which are responsible for the will of man. Lobotomy, both physiological and chemical (brainwashing) just the will of a person takes away from the ends.
Here is not special, and I will not argue. If you here knew how is the suggestion (Yes, even if the management of the person), then the confidence of many would be diminished.<
мимоходом
Post by мимоходом » Mon Jul 06, 2015 11:02
the Downward flow of energy cleanses. He good functioning of the lower chakras. Joyful emotions, and so forth, along with the Ascending energy flow go up.
Do not quite understand how it relates to the word, and the fact that people eat through these threads. Could you explain? You yourself write that the downward flow clears. It turns out it's some kind of energy comes from above? And going down. The energy that nourishes and cleanses the person goes from "egregor eating" it? Amusing things you have been taught...
You can learn what?
Is there an impact on other people without their consent-violence, I thought?
партос
Post by партос » Mon Jul 06, 2015 11:18
смелый wrote:are Not the same. Through reading the forum pages, in alpha state will not slide.
Are you sure about that?)) No forum sellers are a little tight would have :) But seriously, Yes, a slight difference is still there. Here you need to start to buy something. And the people who hang out here, definitely something to take a sample. Fortunately there are choices and forum ;)
Смелый
Post by Смелый » Mon Jul 06, 2015 13:35
мимоходом wrote:don't really understand how it relates to the word, and the fact that people eat through these threads
To be honest, he still did not understand. But in the available sources is the same all podzapytania. So, what exactly clear. The downward flow of energy is considered to be the flow of the Divine. Accordingly, passing through the energy channels of a man (actually, according to the energy channels of his Etheric Body), this flow of energy cleanses. With the right ratio of Essential and Physical bodies. the Etheric Body can be seen here. http://www.narkevich.ru/efir Not specified only the misalignment of telephone Which happens often.
You have here a remark.
So conceived. Complete protection exists for a good, strong Etheric Body. The etheric body of the human, all the same, that the atmosphere for the Earth. But many of us, the Etheric Body is not in order.
Initially, according to some intended next. The downward Flow passing through the person hits the Ground, giving/Cosmic Energy feeds the Earth. Not directly. Passing through organisms. Through people, animals, plants, trees. In this respect, from trees use more. Keep standing. The energy is flowing. People are twisted, hammered and so on.
The upward Flow from the Earth as well, through the above-mentioned structure. Colored, enriched with (who knows) and is used by someone upstairs.
Egregors were originally created as beings to meet human needs. At the same time, energy to ensure the benefits of the person - they took the persons. Now, the main thought forms, often play the role of redistributive mechanism. Their main task is to grow. In the human environment, they emit people, more fully, their qualities, their respective goals and objectives. Organizers for the nature and for their organizational activities, hitting on these leaders, the most complete volume of wealth. At the same time, plenty eat energy those people who little or nothing got. Energy experiences and suffering.
Thus, from receiving the benefits they are getting the Energy of Joy, pleasure, and from other sufferers.
How and where to connect? Yes, probably not very important. At least, it is considered used ajna, manipura. Vertical podlucky I added. Experimented. But my experiments are not proof and controversial. I will not insist. Alone.<
мимоходом
Post by мимоходом » Mon Jul 06, 2015 13:48
The egregore is merely a commonality of views. For example, this theme has its own egregor. When we pay attention to this issue - we have this egregore.
This website has egregor, as well as other sites. Have a chat with your egregor. Our country has its own egregore, and there are many smaller egregors territories. Those who collects stamps - vintage your egregor. I love Chihuahuas too, its egregore.
The egregore is merely a Bank of energy, where people themselves want to invest. Wants - football. Wants - in "biointernet". Wants to - in series. Just the mechanism for people, like ordinary banks. You're not afraid of the banks?
People always something pays attention to it. Where is attention - there is energy and it flows. Yes, the man feeds egregors. But not just feeds, but creates them. Man is a Creator, it's worthy? And or not get something, at least try for five minutes not to pay attention to anything.
And here is where the man is an endless sea of energy that takes? )))
Смелый
Post by Смелый » Mon Jul 06, 2015 13:55
мимоходом wrote:You know what?
No!
мимоходом wrote:is there an impact on other people without their consent, violence
Is!
мимоходом wrote:comes from the "egregor eating" it?
Some people, a small part, Egregors feed, from the greater part of people the energy take.
партос wrote:Without forum sellers are a little tight would have
Nobody knows! But what many forum users, no forum, it would be a little poskuchnee, there was nowhere to spread their ideas, some who would not have been possible with these thoughts to argue or bhati - an indisputable fact.
партос wrote:but seriously, Yes, a slight difference is still there. Here you need to start to buy something
Bopara buys nothing, is free versions, is the undisputed authority, a lot of knowledgeable and understanding, including on the part of the products.
партос wrote:have the Benefit of choice and the forum
In fact, a greater impact on the purchase of products, have Egregors.
There Egregors Primary. Money and so on. Universal.
There is secondary. Have Kabankova Andrew, and Michael, and ASD. No specially created. There is a thought. Then came the action. Meetings, organization of business, creation of products, production organization and so on. The thought fueled with energy. This creates a whole series of programs, managing large numbers of people. Created by themselves, in accordance with the ideas and intentions.
This is a normal process.
Not like someone - you can go to other areas. There is the same. Only the degree of impact is different. The number of people and therefore the number of energies.
You why do you come here?
And say thank you Andrew, for giving You the opportunity to get smart and poblistat intuition and insight. Where else can you find? Elsewhere, ban can.<
мимоходом
Post by мимоходом » Mon Jul 06, 2015 14:00
hmm... Bofara which Achim? He bought a bunch of products )))
Смелый
Post by Смелый » Mon Jul 06, 2015 14:11
мимоходом wrote:Egregore - it's just a common opinion.
Egregor - the entity created by man to produce wealth.
Can be represented in the form of a closed ring. Here you won't draw. Below, write concepts, extreme close.
By the way, picked up the record. Still, the thought forms feed off our CENTRAL ENERGY,
FRUSTRANA NEED (the human need for something)
ARCHETYPE (the subject, which satisfied an inner need of man)
a SATISFIED NEED
Thus, the body of the Egregore is satisfaction of the NEED!
EGREGORE IS a PSYCHIC-COMPLEX, self-DEVELOPING AND self-sustaining, SERVING CERTAIN INTERESTS.
There is a demand from people to devices, giving people extra energy - there are Andrey Kabanov who competently organized the manufacturing and delivery of products.
I mean, first there was the need for movement of products in large volumes. From there, things heated up. We are the cogs! Only one of us has built in mechanisms. Others do not. Either built - in but insignificant.
Смелый
Post by Смелый » Mon Jul 06, 2015 14:15
мимоходом wrote:hmm... Bofara which Achim? He bought a bunch of products )))
And even if so! I really do not know about. But the problem is what? Someone with a stick here beaten and forced to buy?
You do not buy?
Want other not to buy?
There are so naive people!
мимоходом
Post by мимоходом » Mon Jul 06, 2015 14:25
you Want other not to buy?
Yes, like I have no wishes were expressed. Generally, can you describe what the conversation is now? And then I find it hard to enter a state of podergivani thoughts )))
партос
Post by партос » Mon Jul 06, 2015 14:34
You do not buy?
Advertising is also not forced to buy )) But nevertheless. And this is not just advertising. Here literate (?) you chew and put in his mouth. And hamsters in the background will shout hymns of praise :evil:
Смелый
Post by Смелый » Mon Jul 06, 2015 14:35
мимоходом wrote:And here is where the man is an endless sea of energy that takes? )))
From the surrounding space. Which in itself is energy. Only some are able to do it. Others do not. Some do it - others are not or in negligible quantities.
мимоходом wrote:Yes, man feeds egregors. But not just feeds, but creates them.
Well, Yes! So create your own! And we look at Your progress!
Egregors govern us! They are above us!
мимоходом wrote:Man is a Creator, it's worthy?
Man - biorobot! All he carries in the environment - a simple relay!
мимоходом wrote:Yes, and otherwise it will not work-then try at least five minutes not to pay attention to anything.
More proof it's not independence! Man - biorobot!
мимоходом
Post by мимоходом » Mon Jul 06, 2015 14:38
I think you are a bit excited )))
Смелый
Post by Смелый » Mon Jul 06, 2015 14:42
партос wrote:Here competent (?) you chew and put in his mouth
For that, it literate, a special thank you!
партос wrote:And hamsters in the background will shout hymns of praise :evil:
It's not at. In my opinion, certainly! You're new here. Ask around those who have been in the subject. None of the Oldies, never say that I'm a hamster, here singing hymns.
мимоходом wrote:General, can you describe what the conversation is now?
And what are You, the point of discussion lost? The thread of the conversation slipping away? So what are You doing here?
мимоходом wrote:And then I find it hard to enter a state of podergivani thoughts ))
You find it difficult to enter the state "hold thoughts". Do not pervert the meaning of the debate.
мимоходом wrote:Yes, like I need any wishes expressed
Can be! I'll have a look!
Смелый
Post by Смелый » Mon Jul 06, 2015 14:43
мимоходом wrote:I think you are a bit excited )))
Calm like a hippopotamus chewing gum.
мимоходом
Post by мимоходом » Mon Jul 06, 2015 14:45
the thread of the conversation slipping away?
Escapes ))) Tell us what the dispute )))
партос
Post by партос » Mon Jul 06, 2015 14:50
Anyways, against system you will not trample. This is the key point of "aid" money. It is impossible to offer, it can only impose.
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Mon Jul 06, 2015 14:52
партос wrote:Here you need to start to buy something.
Well, no fact. I've three years I communicated, with several mind-machines of other firms (and in General is representative of the hard-core competitor - still in the profile of their website is, or rather, he's mine, but dedicated to the support of the deceased are already set), then for a third of the price Navigator grabbed as one of the testers (below cost) and nothing more is bought. It is very nice here I feel))) And even some of the active users know that there is a lot to write and didn't buy anything.
партос
Post by партос » Mon Jul 06, 2015 14:57
K-13 What's the difference, where you have this infernal machine (Hello, friend ;))bought?) We are not talking only about this forum but about business in General.
Смелый
Post by Смелый » Mon Jul 06, 2015 15:04
мимоходом wrote:Yes, like I have no wishes were expressed.
мимоходом wrote:From my point of view with this forum you can delete everything except this topic (well, maybe a few more). And the level of the forum will not be affected
мимоходом wrote:Igor, I recommend to familiarize with the theme of the Unknown Talents viewtopic.php?f=5&t=5831
There are some information that will allow you to take it into account or not taken into account
A little, but there!
мимоходом wrote:Escapes ))) Tell us what the dispute )))
Yes, about anything!
партос wrote:Anyways, against system you will not trample.
So what's the problem? You can simply! Show the back. They don't shoot!
партос wrote:this is the key point of "aid" money
Well, Yes! We must assume that two of these quotes, being linked.... 've confused myself trying to walk through the reasoning.
And, behold! If someone wants to do me a favor, explaining that these products are not effective, a little effective, or not worth the money specified in the price - I personally, to this service/attempt to untie my eyes and ears, not paying attention. I have my own understanding and their own measure of values and money!
And I am not alone here.
партос wrote:It is impossible to offer, it can only impose.
Alas, it's difficult to impose something! The assumption is not true. For others will not speak. But I assume there are many. You assume otherwise. This is changing?<
партос
Post by партос » Mon Jul 06, 2015 15:07
партос wrote:Anyways, against system you will not trample. This is the key point of "aid" money. It is impossible to offer, it can only impose.
Although it is possible to impose and with good intentions, do not argue. Well, then what? What is the motivation? The more affluent person. Four options: 1) Money 2) Money, but honest ;) (noble :lol: 3) You are the messenger of Jesus (or anyone else) :) 4) You are the messenger of the devil :evil:
Post by к-13 » Mon Jul 06, 2015 15:12
Partoshi, dear.
The fact of the matter is that they did not buy, got one for helping manufacturers in the creation of the technical support forum (since that case came the fascination of light-sound stimulation), the second in gratitude for the decision of problems of a psychological nature (one might say, the first experience of work after graduation, so the payment did not want to take matter) the man who bought and failed to use. In this world is not all about money.
Post by к-13 » Mon Jul 06, 2015 15:14
The hundredth monkey effect is not taken into account. None of the warring for the souls of the parties related, by the way. Goal-something different for people.
