Session editors
Installation and discussion
Has thanked: 134 times
Been thanked: 556 times
Contact:
Post by Андрей Патрушев » Fri Apr 10, 2009 12:36
Ег!с wrote:From my previous post can be clearly seen that in the sessions, almost all the segments differ in the Duty Cycle plus 28 and 30 segments of different Phase Ramp. Compare programs...
...see no difference except the duration of the first segment.
Moreover, the discreteness of the Duty Cycle of both programs are the same, and the Phase Ramp just do not give izmenyaet
Oh well... :) And what, exactly, is the problem?
Ег!с
Post by Ег!с » Fri Apr 10, 2009 13:08
Um... There is 1 problem, 1 comment and 1 question (or comment). :)
Problem: With the editor (of this), you cannot create sesiu for new (Takao as I quoted).
Note : the Editor for Nova and pulse the same (for pulse newer).
Question-comment: If some parameters sassy from Nova differ from those for heart rate (in sessions with the same name) it turns out they have a little different effects? :roll: Where is the truth? :)
PS I'm still a novice.. only listening and wants to understand and figure out
Contact:
Post by Андрей Патрушев » Fri Apr 10, 2009 20:09
Ег!с wrote:Um... There is 1 problem, 1 comment and 1 question (or comment). :)
Editors are very similar, but slightly different parameters values and ranges. Therefore, if the editor to the Nova does not fit, so someone somewhere got something wrong... :)
In terms of creating these editors are really different.
Brain wave activity is the process, in some sense, stochastic, and thus the slight difference of the arguments plays no fundamental role.
User avatar
Камуи
Post by Камуи » Mon Aug 24, 2009 14:18
Good day!
The question seems idiotic, but ask anyway.
Without EEG to establish that sassy works exactly as it should?
Is there an inexpensive way available at home?
Contact:
Post by Андрей Патрушев » Mon Aug 24, 2009 15:03
Камуи wrote:good Day!
Because the duck session scheduled by functionality, not by EEG, so if you get the claimed result, it works, and don't get what this particular session specifically for You (perhaps more specifically at this time :)) is not working... :?
User avatar
Камуи
Post by Камуи » Mon Aug 24, 2009 17:30
Second stupid question
How to train multiple frequencies? Ideally, an active mind by Anna wise... As to suppress the frequency, i.e. the upper beta 30-40 Hz and lower beta 16-14 Hz, to get such a beautiful circle :)
Contact:
Post by Андрей Патрушев » Mon Aug 24, 2009 17:57
Камуи wrote:Second stupid question
To pray or (and) to do throat singing... :?
User avatar
Камуи
Post by Камуи » Mon Aug 24, 2009 18:03
Is this a joke? And what is it salt?
Contact:
Post by Андрей Патрушев » Mon Aug 24, 2009 18:08
Камуи wrote:is This a joke? And what is it salt?
Why joke - these patterns recorded at the praying monks in deep meditation. So mashinoi You train a certain state, and then exercises gather them into a pile... :)
User avatar
Камуи
Post by Камуи » Mon Aug 24, 2009 18:20
Wow! Have to believe, and whom to pray? And throat singing I try, but not really. thank you. Just try to focus on the feeling of gratitude to the world for the fact that my life is not worse. And this is great.
Contact:
Post by Андрей Патрушев » Mon Aug 24, 2009 23:43
Камуи wrote:Wow! Have to believe, and whom to pray? And throat singing I try, but not really. thank you. Just try to focus on the feeling of gratitude to the world for the fact that my life is not worse. And this is great.
It's important to say something, or(and) to sing...
User avatar
Просто_идущий
Post by Просто_идущий » Fri Oct 30, 2009 14:17
Hello, Andrey!
In the editor sessions, and the maximum value of the carrier frequency Pitch1 - 960 Hz, and Pitch2 - after 960 Hz, the values go from R-15 to R-1, then from r1 to r15.
What do they mean?
And another question. I really like Your session, but the maximum time I can put them in 30-35 minutes. For me it is enough! If in the editor to increase the time in segments it will affect the session?
Thank you!
Contact:
Post by Андрей Патрушев » Fri Oct 30, 2009 22:01
Просто_идущий wrote:hi Andrea!
What do they mean?
Thank you!
Hello!
The value of the beating between oscillators - monaurally beats.
In my sessions, the time can not be changed... :?
User avatar
тишина
Post by тишина » Wed Nov 17, 2010 0:03
Can you help? I have Innerpulse, through the program installed 4 of your session, no longer gives - limitation. Library downloaded I erased and now can not see, even for just installed((( How can I delete a downloaded session, but rather to see are already loaded in the machine on the computer screen to remove??
User avatar
тишина
Post by тишина » Thu Nov 18, 2010 20:15
Well, no one knows!!!???
Contact:
Post by Андрей Патрушев » Thu Nov 18, 2010 22:06
тишина wrote:Help to understand. I have Innerpulse, through the program installed 4 of your session, no longer gives - limitation. Library downloaded I erased and now can not see, even for just installed((( How can I delete a downloaded session, but rather to see are already loaded in the machine on the computer screen to remove??
Session convenient to put and remove using the library Lslib.exe we'll see how much free space on machince. Set session cannot be deleted, you can only overwrite them with new (menu item: download clear). Via computer nothing look impossible. :? Set session on machine seem like U01, U02, etc., you can find them pressing the Select button.
User avatar
Стейси
Post by Стейси » Mon Feb 14, 2011 18:55
Hello, dear friends!
Happy holidays to You :o
I HAVE AN URGENT QUESTION!!!
I want to try myself session, I wonder the same when in the machine so many opportunities. One wrote on the alpha chastotakh, prior examining the literary, and based on other session. Listen-there are soooo chustva and such raskolbas that was already scared.
So that's the question!
Is it possible to hurt your brain improvised sessions??? :roll:
And if there's any more detailed literature on the writing sessions?
I would be grateful to You for the answers!!!
Contact:
Post by Андрей Патрушев » Mon Feb 14, 2011 19:28
Stacy
Hello.
In the alpha range to hurt it is impossible (with normal brightness and volume). In others, only an insatiable classroom for several hours.
User avatar
Стейси
Post by Стейси » Mon Feb 14, 2011 20:46
Thank you, You reassured me, so will experiment :wink:
User avatar
Стейси
Post by Стейси » Thu Feb 17, 2011 19:31
Dear Andrew please help!
I'm here again with stupid questions climb of course :oops: but I am wondering if such a small amount of knowledge(in this issue) as I have an session whether to get something sensible, or but a headache and a bad mood I'm hardly what achieve?? :roll:
Answer pliiz :oops:
Contact:
Post by Андрей Патрушев » Thu Feb 17, 2011 19:41
Стейси wrote:Dear Andrew please help!
Answer pliiz :oops:
In the alpha range You can feel free to experiment with indispensable use. :ay
Денис Сош
Re: session Editors
Post by Денис Сош » Sat Jun 11, 2016 1:55
Good day!
Dear friends, please help with advice and share experiences.
Crawled a couple of years InnerPulse and plan to purchase the Navigator.
Please advise the most effective session for development of the pineal gland, the third eye and intuition.
Thanks in advance!
Sincerely,
Denis.
Contact:
Re: session Editors
Post by Андрей Патрушев » Sat Jun 11, 2016 10:55
Dennis SOSH
Hello.
You probably know that in all ancient esoteric schools it was assumed very long development path. So that's a huge part of this journey was aimed, IMHO, at the achievement of the alpha state.
You can use mindalin directly develop any epiphysis. no third eye or intuition because this can only be achieved with special exercises. But, You can significantly reduce (from ~20 years to ~1 year) period, the achievements of alpha status to the level where You will be able to hear your intuition and to perceive information from the third eye.
Денис Сош
Re: session Editors
Post by Денис Сош » Sun Jun 12, 2016 17:18
Good afternoon, Andrey!
Do you mean that you need to look for the development of these abilities through the alpha state? Easy to learn to dive and be found in him? If I understand correctly, then it makes sense to listen to the session associated with alpha channel? And I would like to learn more about the special exercises you mentioned.
Thank you so much for the answers!
Sincerely,
Denis.
Post Reply
