Page 1 of 6
New session for mind machines.
Posted: Sat Nov 11, 2006 18:22
by Андрей Кабанков
On our site You can get acquainted with additional sessions developed by photosonix and Andrei Patrushev,and also read the download instructions for these sessions in Your mind the car.
http://www.mindmachine.ru/sessions.htm
Posted: Tue Feb 20, 2007 14:25
Posted: Tue Feb 20, 2007 17:54
by Pavel
>InnerPulse -
http://www.mindmachine.ru/download/sess ... rpulse.rar
Nova Pro 100 -
http://www.mindmachine.ru/download/sessions/np100.rar
and what they eat? After all, the name predidushih sessions speak for themselves, but innovations without names left! It's like the cat in the bag :idea:
Posted: Tue Feb 20, 2007 18:11
This is not news.
This is for long-promised built-in session.
Posted: Fri Feb 23, 2007 16:18
by Pavel
And what are these sessions? For what they are? That took it and scanned the comments to him the impression that this is an accurate description of the sessions to Innerpulse? Maybe I'm wrong?
Posted: Sat Feb 24, 2007 15:59
This built-in (base) in these devices session (by popular demand).
Posted: Fri Mar 02, 2007 1:28
by Pavel
As I understand correctly: when you load sessions Patrushev on Innerpulse, they appear u01, u02, u03 respectively, evening, morning, alpha?
Posted: Fri Mar 02, 2007 11:30
Pavel wrote:As I correctly understood: when loading sessions Patrushev on Innerpulse, they appear u01, u02, u03 respectively, evening, morning, alpha?
It all depends on which order You load them in the library.
Posted: Thu Mar 15, 2007 18:41
by Евгений
And I wrote not clear what to download to the library for additional sessions, and you get a table with the inscription Light/Sound Librarian, and in it the inscription Access violation at address in module 0048D537 'Lslib.exe'. Read of address oooooooo but the window programulku after each such warning signs all began, and with the action (Download Library (Append) - set all sessions on your list, before adding them to the set) is again popping up the exact same icon table "hourglass"-type thinking. but not put, the machine doesn't produce any action. What to do?
Posted: Thu Mar 15, 2007 20:59
by Pavel
and it says Access violation at address in module 0048D537 'Lslib.exe'. Read of address oooooooo
See the topic "Installing the format of the sessions"
Posted: Wed Mar 21, 2007 11:51
Евгений wrote:And I wrote is not clear what to download to the library for additional sessions, and you get a table with the inscription Light/Sound Librarian, and in it the inscription Access violation at address in module 0048D537 'Lslib.exe'. Read of address oooooooo but the window programulku after each such warning signs all began, and with the action (Download Library (Append) - set all sessions on your list, before adding them to the set) is again popping up the exact same icon table "hourglass"-type thinking. but not put, the machine doesn't produce any action. What to do?
Now session in the archive together with the file in the library when you first start it is necessary to check the path and it will work at its best.
Posted: Fri Mar 30, 2007 23:25
by Шум
I can't record a new session (on the first attempt partially succeeded). Now, as I understand it, the memory of the mind-machine is jam-Packed? Can session in any way to overwrite?
Posted: Sat Mar 31, 2007 19:06
Well, memory there is still a lot.
During recording sessions there is a choice to append (add) and clear (clear).
Posted: Sun Apr 15, 2007 1:05
by ильнур
I am on a procedural matter with reference to Andrei Patrushev: Your session morning and evening recorded at alpha frequencies? Earlier on one of branches read that it should start with the alpha sessions.
Posted: Sun Apr 15, 2007 1:06
by ильнур
The same question about the same time and session for training, fun, meditation and creativity?
Posted: Sun Apr 15, 2007 22:25
by Шум
Recorded in the InnerPulse session of relaxation from NovaPro. For some reason, they were recorded with the prefix "u" instead of "r". If I try to record a session for meditation (they also think NovaPro 15), again, they will be recorded with the prefix "u", and, accordingly, the old session will be overwritten? (and before that was three alpha session from Andrei Patrushev was "u1","u2","u3". Turns out... they too worn?)
Posted: Mon Apr 16, 2007 8:33
Ильнур wrote:I'm on a procedural matter with reference to Andrei Patrushev: Your session morning and evening recorded at alpha frequencies? Earlier on one of branches read that it should start with the alpha sessions.
Yes, all my sessions recorded at alpha frequencies.
Posted: Thu Apr 19, 2007 16:32
Шум wrote:Recorded in the InnerPulse session of relaxation from NovaPro. For some reason, they were recorded with the prefix "u" instead of "r". If I try to record a session for meditation (they also think NovaPro 15), again, they will be recorded with the prefix "u", and, accordingly, the old session will be overwritten? (and before that was three alpha session from Andrei Patrushev was "u1","u2","u3". Turns out... they too worn?)
U means user. All additional session in Innerpulse are logged with this prefix. Nova Pro - the prefix where You have chosen to download, but with the additional point.
If You chose when recording the download mode clear all previous sessions has worn off, if download append, additional sessions were added after those already present in the order in which You put them in the library.
Posted: Mon Jun 11, 2007 23:56
Session is refreshed. A description of each session.
Posted: Mon Jun 18, 2007 1:19
by Влад
Andrew, the archive contains the following files :
Alpha trening.LSL
Amacher.LSS
Amedicare 1.LSS
Atrainer 2.LSS
Atrainer 3.LSS
Outro.LSS
HEALING.LSS
mind healing.LSS
Could you give advice what, in what order and at what time can use the beginner for 2 to 3 weeks of alpha-training.
More effective if your session embedded in Innerpulse in your opinion?
You gave such a recommendation for the built-in sessions(r0-r7,i2).
Could you give a similar recommendations for these sessions.
Posted: Mon Jun 18, 2007 4:40
Nothing special - variations on a theme of my favorite alpha waves. In each session there is a description for which it was created. The recommendation is simple - to be sequenced in any order first two to three weeks. Better two times a day with a break of at least three hours.
The question of effectiveness always rests on the question - for whom?
Posted: Mon Jun 18, 2007 11:52
by Влад
I understand Amacher.LSS , Outro.LSS, respectively, for morning and evening practice?
Amedicare 1.LSS-in the description it is written that experienced, that is, those who have finished alpha training. Is it useful for a beginner?
Atrainer 2.LSS and Atrainer 3.LSS I understand the day and Atrainer 3.LSS poeffektivnee will be based on the description.
HEALING.LSS and mind healing.LSS session for specific purposes and not specifically for alpha training.
So I decided to train under this scheme Outro.LSS, i02, Atrainer 3.LSS, Avesher.LSS.
Do you think it will be more effective than with the built-in sessions for relaxation?
Posted: Mon Jun 18, 2007 12:07
by Dimas
Влад wrote:I understand Amacher.LSS , Outro.LSS, respectively, for morning and evening practice?
And then!How!!!
Posted: Mon Jun 18, 2007 22:57
For "experimental" only because it requires a full range of brightness points. Beginners, especially burdened by stress, this brightness can cause anxiety instead of relaxation (and sometimes crossing the next day).
Posted: Fri Jun 22, 2007 12:02
by Pavel
Alpha trening.LSL
Amacher.LSS
Amedicare 1.LSS
Atrainer 2.LSS
Atrainer 3.LSS
Outro.LSS
HEALING.LSS
mind healing.LSS
some of them you can change the duration time?
