Page 2 of 2
Transparent corporation R. I. P?
Posted: Wed Apr 24, 2019 15:29
by АнтонМесмер
к-13 wrote: ↑Wed Apr 24, 2019 14:11
But on fresh system without updates (7) MWS rose without problems. The key is activated, a session in an audio file is saved. Most likely it's some fresh patch Microsoft security conflicts.
For gifted fellow like me, where the seven no updates take?
Posted: Wed Apr 24, 2019 17:22
by димыч
Put the virtual machine on a torrent full of all sorts of builds from different years...this dev can try to put
Posted: Wed Apr 24, 2019 18:48
by димыч
Although I see the output as if something somewhere is still working to create a portable version of the program and not worry
Posted: Wed Apr 24, 2019 19:01
by к-13
АнтонМесмер wrote: ↑Wed Apr 24, 2019 15:29
Torrent download, Google with Yash know hundreds of places where they are lying. But I would not hurry - just demolished it, cleaned the registry, and then without any problems set. I have then everything works. If that fails, here's the installation files, do you have broken:
https://yadi.sk/d/zf_7lXOToihewQ - old version of the installer (1.4)
https://yadi.sk/d/98JzwuFOpCD4WQ - the latest version (1.6)
Posted: Fri Apr 26, 2019 8:32
by АнтонМесмер
Drove shorter MWS in a virtual machine in Win7 does not work the activation key, please fix
Posted: Fri Apr 26, 2019 9:39
by димыч
And you key this as given? Did you send them the hardware id? And they sent the key?
Posted: Fri Apr 26, 2019 10:04
by АнтонМесмер
димыч wrote: ↑Fri Apr 26, 2019 9:39
I bought in General here on the website maindmachine.ru, what can I say bought, they provided only the key, and the program downloaded from the site where the MWS sold. Warned of course, that after three resets we need to change the key, but I already 5 times re-installed, everything worked, we can do all online over.
Posted: Fri Apr 26, 2019 10:06
by димыч
Well, if the server is dead no one to count the number of installations, I still on tinkering, and then accomplish your goal
Posted: Fri Apr 26, 2019 11:04
by АнтонМесмер
димыч wrote: ↑Fri Apr 26, 2019 10:06
I'm honestly very puzzled, why then the activation key is not correct ? Time on the same comp set
Posted: Fri Apr 26, 2019 12:03
by к-13
No restrictions on the number of machines or number of installations on a single key in program code no, the issue I discussed with the developers. Limitation - only one user (and for TCN and it was not). They want to the need to change passwords every six months (a lot of left users on the pirate Bay several times stolen the keys pop up), but I couldn't exactly realize (a lot of bugs there), so I quit.
Posted: Fri Apr 26, 2019 12:11
by АнтонМесмер
к-13 wrote: ↑Fri Apr 26, 2019 12:03
Well then, I don't understand, the program shows that the key is not correct, although it was initially installed on this laptop. The virtual machine does for example the ID of the disk cannot change?
Posted: Fri Apr 26, 2019 12:18
by к-13
How can you be sure that this is a problem of key? I time owned this I have changed 5 cars (in addition she is also on two laptops standing and on the computer of the parents), the key is not changed even once (I have TCN and versions of all prog at top speed). Moreover, when you log on to the website it was written that the key needs to be changed, I'm stuck with this question to the developers, they replied that this technology is still being tested for local users. It was a version for MWS 1.5, so for everyone else just after 1.4 came out 1.6.
Posted: Fri Apr 26, 2019 15:58
by АнтонМесмер
к-13 wrote: ↑Fri Apr 26, 2019 12:18
Well then I just don't understand what's the problem, since the problem is not the key when asked to enter a registration key MWS writes that the key is invalid, and I have one and no other. What else can you do?
Posted: Fri Apr 26, 2019 16:40
by АнтонМесмер
ID discs are way different. On the laptop 7C01-ABB8, and on virtualke 708F-4CCO, how to change?
