Page 1 of 1
Barefooted with their hands
Posted: Tue Jan 19, 2010 14:21
by Экко
this impromptu barefoot will measure El. sopr. skin. Take the stereo cable and plug into the line input of pollutants. card.Next, take the DC power source: preferably, a battery 9V, but the power supply is connected to the network, connected through (the electrodes strengthened on hand, for example) to RCA stereo cable, which is inserted into the line input of pollutants. card.
Download virtual oscilloscope (
http://depositfiles.com/files/dfndqq84l)
Or write their own program that responds to the amplitude of the signal on Lin. the entrance and changing the tone or drawing a chart or even control objects in the game (as in mental games)
Posted: Wed Jan 20, 2010 22:50
by Наиль
didn't check well SERAVNO MOLODES!
Posted: Tue Mar 02, 2010 2:40
by Вадим Перелыгин
Hello ECCO.
Thank You for the interesting idea
. Downloaded Virtual oscilloscope Radiomaster.
Put stereosar from Innerpulse to the line in(blue) sound card Realtek HD. On the plug top-down contacts:L-left input.P-right Rin. On-Shared.
Calibration set for WW1.
Touch "L"=3.4 mV to P=WW2, to "O"=0.4 mV. Chain: Lion.hand – L, Right.hand –"A" = 2.5 mV.
Chain: Lion.hand – L, Right.hand – "+9V", "O"-"-9V"=3.4 mV. – without change. Can the voltage not enough?...
You should try to change the voltage by changing the frequency state of the brain. Just how to be in alpha and in Beta, to monitor the voltage?...
Posted: Tue Mar 02, 2010 13:04
by Экко
it was necessary to connect through on the "oscilloscope" don't mind the car, and a constant current source, and where the 12 volts...
Posted: Wed Mar 03, 2010 0:52
by Вадим Перелыгин
Of course I'm not using MM was connected to, and just stuck the first plug stereoscope into the line input of the Sound card and touched the top contact end of the plug.
The sine wave shows the change of the potential on the finger -8мВ to +8мВ. And at some point begins to show a 3.4 mV. Although the waveform is the same. I wonder how it can be interpreted. Need to buy to plug it in, solder 3 wires(Left input, Right input and the Common) and to experiment with different circuits, power supplies and acupuncture points.
PS. Wanted pictures of the screens to insert, but do not know how.
Posted: Thu Mar 04, 2010 13:20
by Вадим Перелыгин
In the photo
see the cycle 3000мкс = 0mV, 3000мкс increases to 10.5 mV, 3000мкс drops to 0. 3000мкс = 0mV, 3000мкс drops to -10.5, 3000мкс rises to 0, etc.
