Page 1 of 1
EEG
Posted: Mon Oct 05, 2009 15:50
by Шалтай Балтай
And here is the tricky question
Where to take and how much is the most primitive of the EEG, which could determine the phase of sleep? (alpha, theta....)
maybe you can use EEG, and some other device?
Why is it necessary?
here:
http://www.mindmachine.ru/viewtopic.php?p=33401#33401
saved
Re: EEG
Posted: Mon Oct 05, 2009 17:34
Георгий_19 wrote:And here is the tricky question
here:
saved
Sleep cycles are divided into "deep" and "paradoxical." The first is dominated by Delta waves, the second - theta, alpha and beta.
To determine paradoxical vplne suitable dream Stalker. And dream Stalker Pro has the ability in the determination of this phase to enable the built-in player and navorotami You in my sleep everything You to pre-load... there Is no "gate"?
Posted: Mon Oct 05, 2009 17:54
by Шалтай Балтай
no, it's not.
it should cut the Delta that would get in tattoo or alpha.
and it should cut alpha that would blunt in tattoo
although, experimentation is possible.
even though it is not clear how.
well, suppose DS defined "paradoxical" phase, so what? The best he can to give the signal.
but if you fell, you - the mustache.... we must start with the jukebox first
Posted: Mon Oct 05, 2009 18:11
Георгий_19 wrote:no, it's not.
I'm in Your vocabulary don't get it...
But studies it conducted in the last century, showed that the material stored only in the paradoxical phase... So You don't have to "jump", you can just program yourself to release "at the right time in the right place"...
I want to see that Delta, theta, alpha and beta take place at the same time (and always)...
Posted: Mon Oct 05, 2009 18:20
by Идущая вперед
Андрей Патрушев wrote:I want to see that Delta, theta, alpha and beta take place at the same time (and always)...
I don't understand... how????
Posted: Mon Oct 05, 2009 18:31
Идущая вперед wrote:Андрей Патрушев wrote:I want to see that Delta, theta, alpha and beta take place at the same time (and always)...
Read Anna Weis.
Posted: Mon Oct 05, 2009 18:45
by Шалтай Балтай
I too do not understand...
probably also need wise to read
