The simplest analogue of the Rem-Dreamer with their hands
Meet DreamCatcher. The Assembly of the device does not cause any problems (according to the scheme No. 1 for an hour). The program is working with her quite good and has a number of flexible options. If desired, you can modify the device (you will need to rewrite the program) and use with mindmachine and self-made points. The drawback of the device is to sleep only on your back but given the cost of the device shortcoming it can not be considered.
Just before loading we need to wait for 0.8 minutes . You first need click Free, then wait until the timer counts a time to start downloading. Then will appear the options and the picture which it is necessary to rewrite the password in the text field. After you start the download. No problems should arise.
