The conversion of the sessions
Post Reply
User avatar
Парапсихолог
Post by Парапсихолог » Sun Oct 18, 2009 19:28
I have a Photosonix InnerPulse. And there are many sessions from other devices and programs (MindLabPro, BWG, MindExplorer, MindSpa, TMM MIRAGE, iLightz Pro, a Mind-machine "Vizard" and others) Some session unique, and I'd love to run them on the InnerPulse. Are there any programs to convert those sessions in the LSS format? Or in the manual to do that? It is very necessary.
Guest
Post by Guest » Mon Oct 19, 2009 1:54
I have not found one. Every manufacturer is trying to impose a monopoly. If you have a description of the sessions on-time method-frequency is very possible to transfer manually or use a program from photosonix, or even simply editing the LSS file. If you still Wasmachine translation itself, I will provide possible assistance in the interpretation manual(now full of anglicisms, still not professional translators worked) and explanation.
User avatar
Парапсихолог
Post by Парапсихолог » Mon Oct 19, 2009 3:45
The only program that at least something can be I convert this MindExplorer. At least I don't know. MindExplorer can convert lss, ses, mxi format mxs. A I would like to convert in lss such sessions as:
clairvoyance
psychic abilities
remote vision
TRANS
chakra
APEK
And many, many others. And again the time to write just yet.
Guest
Post by Guest » Mon Oct 19, 2009 5:25
Send session and the program(you can link, but not the licensing), pokapatsya may all very easy to do...
My email(one of samovsky not want to Shine spam your main work) bolshayasvalka at yahoo dot com.
User avatar
Парапсихолог
Post by Парапсихолог » Sat Oct 24, 2009 18:12
Guest, send You the archive with the program Mindexplorer3.7 and any of my sessions from TMM Mirage. There is a session on the development of the chakras, APEK, Kundalini meditation, in trance, remote vision, ESP, clairvoyance, etc.
Can You get with conversion. It would be nice to translate them into a format Lss or at the very least in mxs.
Кириллка
Post by Кириллка » Mon Nov 02, 2009 0:43
how to connect PC to Nova PRO100?
User avatar
Парапсихолог
Post by Парапсихолог » Mon Nov 02, 2009 2:35
Kirillka read a little the forum.
Here are mine dastatochno says:
FAQ for installing new sessions in your mind machine
Кириллка
Post by Кириллка » Tue Nov 03, 2009 15:15
thank you
Чингис
Post by Чингис » Mon Nov 23, 2009 5:07
Here is a link to the way session NovaPro100 cars, converted for MindExplorer. With the description in Russian
http://depositfiles.com/files/g09rvzszx :)
Владимир Шумаков
Re: Convert sessions
Post by Владимир Шумаков » Tue Feb 14, 2012 16:30
Update the link please perezaleyte or the People
Do I understand correctly that session from NovaPro100 you can safely pour in Interpuls, or we need to convert them? Like extension is the same .lss ?
Владимир Шумаков
Post by Владимир Шумаков » Fri Feb 17, 2012 9:30
Himself and answer. Can and should :D I don't where on the forum my question is not answered. And that's understandable, as better Nebulosa for the price and convenience of cars I see. All the other marketing ploy for profit.
ВладимирЖ
Post by ВладимирЖ » Wed Oct 03, 2012 17:08
Hello!
Who understands lss sessions?
One incomprehensible moment. If you create a session like Dual Binaural Beats Pitch in column 2 it is possible to expose values from r-15 and r15. Did I understand correctly that the Pitch 2 value, in this case will be equal to 1 Pitch + 2 Pitch? But if Pitch 2 is negative, then Pitch 1 - Pitch 2?
Has thanked: 134 times
Been thanked: 556 times
Post by Андрей Патрушев » Wed Oct 03, 2012 20:18
Vladimir
You are absolutely right.
The Pitch 2 value, in this case will be equal to the Pitch 1 + r? But if r is negative, then Pitch 1 - r
ВладимирЖ
Post by ВладимирЖ » Wed Oct 03, 2012 20:43
Andrei Patrushev
Thank you!
Another question to be clear... r(X)=X ? Ie the number after voqui r equal to the unit of Hertz, which is added to Pitch 1? And then I began to think that it is the ordinal stave.
p.s. Now everything seems clear. az
Post Reply
