ways audio and videoprogressevent subconscious
Hello.perhaps someone could provide answers
please))) I would be very grateful.
---the modulation of the speech frequency band (or pure tones) in the inaudible range.---what programs can I do that?and what it should be range? if the phrase is not heard-what's the point? the subconscious understands it?
---masking quiet speech loud music --the phrase must be audible and clear consciousness?
as well as running the phrase backwards -what programs, preferably free that can do this?
---supply on the ultrasonic (above 20 kHz) frequencies, the sound effects---the same question( in any of the programs you can do this?)
--- supply at infrasonic (below 20 Hz) frequencies of sound effects --the same question
--the phrase turned into a barely audible noise--the same question
----no visible consciousness of the text ,but the cat.the subconscious mind fully understands---the same question
---the picture inserted in any video-- between frames of a video--the same question
---------feeding on the visual information channel with a frequency of 180 Hz --the same issue
- a picture inserted in any video on one of the frames (25кадром)-same question
Re: ways audio and videoprogressevent subconscious
The point in the bypass the conscious blocks, such as: it happens only in fairy tales, I don't believe it, it is not possible, etc.бурислава wrote:if the phrase is not heard-what's the point? the subconscious understands it?
Not necessarily, the phrase can be even incomprehensible to the conscious language and with the right build will still be accepted.бурислава wrote:---cloaking quiet speech loud music --the phrase must be audible and clear consciousness?
Depending on the wording, the phrase will either be rejected or accepted. But in any case, the brain will hear it perfectly.бурислава wrote:--the phrase is turned into a barely audible noise--the same question
Do not visible what is it like? For example, if a person has poor vision and consciously he did not see, for example, advertising label, her brain sees perfectlyбурислава wrote:----no visible consciousness of the text ,but the cat.the subconscious mind fully understands---the same question
I think a crucial role to play what kind of information and in what form it is presented. For example, the scrolling text with a frequency of 6.6 Hz was well perceived.бурислава wrote:---------feed on visual information channel with a frequency of 180 Hz --the same issue
If you want a similar way to "download" some kind of goal, a crucial role is played by formulation.
Read the article by Andrei Patrushev, he has many different publications on the subject and branch "rainbow arc".
generally not visible to the consciousness of the text ,but the cat.the subconscious mind fully understands---the same question
no it doesn't, there is the image or phrase is coded something like this in background or other image that it generally neither bad nor good sight are not visible.
thanks for the replies). there have also been questions about the program in the cat.can all these items listed to do.
disparate video
Depends on how to encode and how will this information later to perceive.бурислава wrote:no it doesn't, there is the image or phrase is coded something like this in background or other image that it generally neither bad nor good sight are not visible.
The simplest coding example, place a picture on a flash drive, then pull it out from the port, put it in your hand and look
Or the other option is that its coded in a widget, here the thing is how it will be presented to the viewer. Likely that properly structured, then encoded, then the correct representation (as an option on the screen) user information to be perceived to be quite correct.
and what programs can it be done?ЗОМБИ wrote:disparate video
I would like to get answers to my questions what programs can be all of these these things to do?
Borislava
handles audio and video editing software
or rather, in what programs?cool edit or soung forge or Adobe of audition -some of these suitable?
what video editors?
what video editors?
and what the manual details how to do it estige then? and then the Internet I find only that it is necessary to do, for 10-5 minutes and parts of the picture
Borislava
who you such a manual will do... there are principles of audio and video for your goals... there helpy to editors... there are special.the literature on accustic and video processing... if you can master this, you will be able to do some things for firmware PS...
what exactly to recommend don't know...
