Page 1 of 1
Power supply InnerPulse.
Posted: Thu Mar 01, 2007 16:33
by Виктор17
I'm interested in this question: the documentation for the device specified external power supply 6 voltwhich is not included. Bought anyone from and its included? If so, what voltage it gives? The issue was taken not from the ceiling, because both know that on some power supply units Maisano, say "6 volt", and when measured, there may be tension and 9 and 12 and ... volts. Nourish your device napryazheniem with КРЕН5В - on the device comes - 5,94. By the way, 4 new batteries give a voltage of 6.4 to 6.5 volts.
Posted: Thu Mar 01, 2007 16:41
by Андрей Кабанков
You can use any universal power supply with voltage of 6 volts.Not recommend eksperementy by feeding the machine more voltage,no effect ,except that it will burn will not be
Posted: Fri Mar 09, 2007 20:47
by Buster13
I bought this power supply.
Here are the stats written on it:
MODEL: DSA-31S FUS 6030
INPUT: 100-240V ~ 50/60Hz 0.2 A
OUTPUT: +6V 0.3 A
LEVEL 3
The voltage was measured.
If the written unit 6B and the measurement outputs 9-12V, then it is not stable, but under load the voltage will drop to 6V.
Posted: Sat Mar 10, 2007 19:25
by Виктор17
Buster13 wrote:I bought this power supply.
OUTPUT: +6V 0.3 A
LEVEL 3
Of the writing shows that this pulsed power supply. They really give what is written on them. And about the fact that under load the voltage drops to 6V - you know exactly what not the fact...
Nevertheless, thank you all for the replies - what I was interested in - turns out.
Posted: Wed Dec 05, 2007 11:38
by Pavel
Here miracles happen with my power supply. More specifically, innerpulse.
A week ago the machine refused to turn on: insert the connector adapter into the slot machine, and the machine will not turn on.
Changed pole connector: the machine worked.
Yesterday, again, insert the connector adapter into the slot machine, and the machine will not turn on.
Changed again pole connector: the machine working again.
What a miracle is?!
Posted: Wed Dec 05, 2007 12:38
by Dimas
Posted: Thu Dec 06, 2007 1:17
by Pavel
Jokes jokes, but still, what's the matter?
On the basis of which can change the polarity? I electronic not good. Therefore, fear for the life of his mind-machine, which just changes the polarity.
Posted: Thu Dec 06, 2007 13:13
by Dimas
Pavel
No idea..I also a goof in electronic gadgets...Maybe You confused something..but really,she is unable to change polarity,even I understand it..
Posted: Thu Dec 06, 2007 14:04
by Князевский
I do not suggest to use the power supply of this, and it is better not to juzat. Battery - probably safe.
Posted: Thu Dec 06, 2007 15:00
by Андрей Кабанков
Plus should be inside,minus outside.A voltage of 6 volts.
Posted: Thu Dec 06, 2007 20:40
by вероника
And I also have a power supply with the machine does not work
I'm already at some point got scared. In the machine were normal batteries, but listened through the power supply. First lost blue color I was upset, but continued to listen with green. It's 2 of your favorite colors. After a couple of days is gone and green, decided glasses acting up, switched to what was left red. The day after there's nothing left, and only stopped when she realized the machine to put new batteries. Turned out I needn't have included the power unit, the machine worked from batteries. Maybe there is something does not fit, I don't understand, but when points again flashed with all the colors, my joy knew no bounds
Posted: Fri Dec 07, 2007 12:36
by Dimas
Veronica
Check the polarity!!!;)))and + SHOULD BE INSIDE!!!!!!!!!!!
Posted: Fri Dec 07, 2007 12:53
by Pavel
>Check the polarity!!!Wink))and + SHOULD BE INSIDE!!!!!!!!!!!
but me - machine nobody uses.
So:
once I had to remove from the cord and deploy the connector of the adapter around its axis by 180 degrees and again to stick in the cord - it was an accident.
if the second time had to repeat this procedure - it's just a coincidence.
but if it happens a third time then this will be the pattern.
Posted: Fri Dec 07, 2007 12:55
by Pavel
Pavel wrote:but if it happens a third time then this will be the pattern.
and the conclusion will be simple:
SHE'S ALIVE!!!!
Posted: Fri Dec 07, 2007 18:32
by вероника
The power supply is 6V and + inside and also no one uses them. Now do without it. Without it easier.
Posted: Tue Feb 12, 2008 18:07
by champ0
First, voltage is always necessary to measure under load.
Secondly the batteries removed if it is desirable to connect the power supply.
I bought a universal power supply unit there is put what you need the voltage and an adapter to turn it so that + were inside.
And any problems never was.
Posted: Thu Jun 18, 2009 9:23
by Суламита
I have stopped working glasses, thought of the matter in them, bought others, but with new glasses color appeared. What could be the reason?
Posted: Thu Jun 18, 2009 9:53
by Андрей Кабанков
Суламита wrote:I Have stopped working glasses, thought of the matter in them, bought others, but with new glasses color appeared. What could be the reason?
What do you mean "the color is not appeared" ?
If the LEDs do not flash,then something broke in the machine,and if the lights are blinking,and the picture in the head is not colored,it's in the head
Posted: Thu Jun 18, 2009 13:51
by Суламита
Andrew, thank you, with the head all right, I did some digging on the forum, then in the settings of the machines, the color and light came, and now I have two different points, Thanks.
Posted: Sat Apr 03, 2010 10:49
by Guest
Hello!
In the 20's of December 2009. I bought in Alma-ATA "InnerPulse".
I use it for 3 months. The results of zero!!!
In this regard, please answer the following questions:
1. Maybe You have any recommendations for achieving at least a little bit of result? Tell me!? And then, I did not cut into the theme!
2. Connect to "heaven" 3 times a day, so the battery lasts for 20 days . I went to buy a adapter, then the thing – the adapter is with the "+" and "-". Tell me what to take "+" or "-"???. I'm afraid to burn the device when enabled through the adapter!
Please answer to my e-email, and the che Alma-ATA is not responding.
My car number SN334749
All the best,
Sergei Wise, Ust-Kamenogorsk
Posted: Sat Apr 03, 2010 18:33
by Димитрий
Anonymous wrote:Hello!
All the best,
On the first question, oftop probably, but purely IMHO, you need to prepare yourself - exercise, read the forum, literature - sense if you wish, definitely will, don't lose Your perseverance!
On the second question - I bought the regular Chinese adapter 6W. and working with MM it was more than 2 years, sales are not zamarachivatsya where there is a plus or minus... although specialists will tell you better than I do.
Posted: Sat Apr 03, 2010 19:11
by Андрей Кабанков
Plus inside.6 volts.
It's written in this thread above.
Re: power supply InnerPulse.
Posted: Fri May 15, 2015 13:56
by Алексей Александров
With adapter for the mind-machine face some difficulties. From the battery powered device works fine, but when insert the adapter, removing the battery, the screen высвечиdаются strange characters (FrL), and other buttons are not active, you can only turn off the device and turn while you turn the same strange characters. Adapter took to complete with a mind-machine. In the early days this was not observed. I don't think that the adapter is not working properly, then the discussions said about polarity. Don't quite understand what it is and in this connection the question - how to reverse the polarity of the adapter there are no advantages or something like that I did not notice it. Who faced with similar, please write a review.
Posted: Tue Apr 12, 2016 10:44
by к-13
On my inner too a couple of times, this error climbs although no unit I have (I use battery). But to eliminate it was enough to switch off and switch on again.
