Power supply InnerPulse.
I'm interested in this question: the documentation for the device specified external power supply 6 voltwhich is not included. Bought anyone from and its included? If so, what voltage it gives? The issue was taken not from the ceiling, because both know that on some power supply units Maisano, say "6 volt", and when measured, there may be tension and 9 and 12 and ... volts. Nourish your device napryazheniem with КРЕН5В - on the device comes - 5,94. By the way, 4 new batteries give a voltage of 6.4 to 6.5 volts.
- Has thanked: 1 time
- Been thanked: 182 times
- Contact:
Buster13 wrote:I bought this power supply.
Here are the stats written on it:
MODEL: DSA-31S FUS 6030
INPUT: 100-240V ~ 50/60Hz 0.2 A
OUTPUT: +6V 0.3 A
LEVEL 3
The voltage was measured.
If the written unit 6B and the measurement outputs 9-12V, then it is not stable, but under load the voltage will drop to 6V.
Of the writing shows that this pulsed power supply. They really give what is written on them. And about the fact that under load the voltage drops to 6V - you know exactly what not the fact...
Nevertheless, thank you all for the replies - what I was interested in - turns out.
Here miracles happen with my power supply. More specifically, innerpulse.
A week ago the machine refused to turn on: insert the connector adapter into the slot machine, and the machine will not turn on.
Changed pole connector: the machine worked.
Yesterday, again, insert the connector adapter into the slot machine, and the machine will not turn on.
Changed again pole connector: the machine working again.
What a miracle is?!
What a miracle is?!
- Князевский
- Contact:
And I also have a power supply with the machine does not work
I'm already at some point got scared. In the machine were normal batteries, but listened through the power supply. First lost blue color I was upset, but continued to listen with green. It's 2 of your favorite colors. After a couple of days is gone and green, decided glasses acting up, switched to what was left red. The day after there's nothing left, and only stopped when she realized the machine to put new batteries. Turned out I needn't have included the power unit, the machine worked from batteries. Maybe there is something does not fit, I don't understand, but when points again flashed with all the colors, my joy knew no bounds
>Check the polarity!!!Wink))and + SHOULD BE INSIDE!!!!!!!!!!!
but me - machine nobody uses.
So:
once I had to remove from the cord and deploy the connector of the adapter around its axis by 180 degrees and again to stick in the cord - it was an accident.
if the second time had to repeat this procedure - it's just a coincidence.
but if it happens a third time then this will be the pattern.
So:
- Contact:
What do you mean "the color is not appeared" ?Суламита wrote:I Have stopped working glasses, thought of the matter in them, bought others, but with new glasses color appeared. What could be the reason?
If the LEDs do not flash,then something broke in the machine,and if the lights are blinking,and the picture in the head is not colored,it's in the head
Hello!
In the 20's of December 2009. I bought in Alma-ATA "InnerPulse".
I use it for 3 months. The results of zero!!!
In this regard, please answer the following questions:
1. Maybe You have any recommendations for achieving at least a little bit of result? Tell me!? And then, I did not cut into the theme!
2. Connect to "heaven" 3 times a day, so the battery lasts for 20 days . I went to buy a adapter, then the thing – the adapter is with the "+" and "-". Tell me what to take "+" or "-"???. I'm afraid to burn the device when enabled through the adapter!
Please answer to my e-email, and the che Alma-ATA is not responding.
My car number SN334749
All the best,
Sergei Wise, Ust-Kamenogorsk
All the best,
- Димитрий
- Been thanked: 1 time
On the first question, oftop probably, but purely IMHO, you need to prepare yourself - exercise, read the forum, literature - sense if you wish, definitely will, don't lose Your perseverance!Anonymous wrote:Hello!
All the best,
On the second question - I bought the regular Chinese adapter 6W. and working with MM it was more than 2 years, sales are not zamarachivatsya where there is a plus or minus... although specialists will tell you better than I do.
- Contact:
Re: power supply InnerPulse.
With adapter for the mind-machine face some difficulties. From the battery powered device works fine, but when insert the adapter, removing the battery, the screen высвечиdаются strange characters (FrL), and other buttons are not active, you can only turn off the device and turn while you turn the same strange characters. Adapter took to complete with a mind-machine. In the early days this was not observed. I don't think that the adapter is not working properly, then the discussions said about polarity. Don't quite understand what it is and in this connection the question - how to reverse the polarity of the adapter there are no advantages or something like that I did not notice it. Who faced with similar, please write a review.
- к-13
- Has thanked: 31 times
- Been thanked: 129 times
- Contact:
On my inner too a couple of times, this error climbs although no unit I have (I use battery). But to eliminate it was enough to switch off and switch on again.
