Page 1 of 5
Glasses standard, Premium ColorTrack - comparison
Posted: Fri Jul 25, 2008 14:48
by Владимир Никонов 2
Bought to Premium ColorTrack glasses and feel the difference! The effects are different.
As your experience points? Different than your standard, Premium ColorTrack?
Posted: Fri Jul 25, 2008 16:18
I would like to note that any points are the same in terms of the effectiveness of synchronization of brain rhythms with flashes (entrainment). all other effects belong to the entertainment side of things (entertainment). Standard glasses far differentiated in the rest of the background red glasses. They give the maximum amount of other colors and geometric images, and in this regard successfully compete with labor-white premium. Only in my opinion, the lack of red - it's sensitivity in some people (especially posttravmatical, either in the acute stress state) to red - I with open eyes can not see anything, and they complain - "too bright!".
I noticed an interesting effect - who to some points from the very beginning used to, the other glasses are usually poorly perceived and hardly gets used...
Over time, the sensitivity to light in humans is greatly reduced (VISCA sensitivity is actually a diagnostic symptom of stress disorder) and a person wants a little something extra... by the Way, dark-eyed people sensitivity to light is also much lower. So, I think the light and there were glasses of "premium".
Colortrak is somewhere alone, because it is able to generate all colors except white (pure) and, therefore, can save a lot of money, accumulating all the other points and even more. Also, Colortrac can be useful to those involved in color therapy. Noticed an interesting principle. If you look at the color (light), which you don't like long enough, you start to occur positive psychotherapeutic personality changes...
Posted: Fri Jul 25, 2008 18:24
Andrew, what about the difference of LEDs? In standard and Premium they appear to others (4 on each eye).
And do I understand correctly that standard differs from the Premium only brightness?
Posted: Fri Jul 25, 2008 18:26
Никонов Владимир wrote:Andrew, what about the difference of LEDs? In standard and Premium they appear to others (4 on each eye).
Yes, the brightness and a bit the size of the LEDs.
Posted: Fri Jul 25, 2008 18:41
Thank you. On the brightness of suitable standard glasses. In Premium I have to twist the brightness as much Shine.
Posted: Sun Jul 27, 2008 23:49
by Евгений495
I have a question:
to listen to the CDs Andrei Patrushev "Healing on the Magic river", "Explorer", "Endorphins" which is better to use glasses: Premium ColorTrack or or this is completely irrelevant and does not affect efficiency ?
Posted: Mon Jul 28, 2008 0:55
by Евгений495
and another question,
glasses-trovit this Premium ?
Posted: Mon Jul 28, 2008 12:34
Евгений495 wrote:I Have a question:
"Does not affect value"
Posted: Mon Jul 28, 2008 12:35
Евгений495 wrote:and another question,
Yes, is premium.
Posted: Tue Jul 29, 2008 5:02
by Евгений495
thanks for the quick replies
I think I'll take premium
Posted: Sun Aug 17, 2008 18:00
by Алив
Why there is no standard points blue? Or is it there?
I bought red, but for relaxation they say is not very good.
And I have a question. Is it safe for eyesight these glasses to use? After the session, I have a temporary color mismatch always happens. And if you open your eyes while watching, won't spoil if I vision? After all, loads podvergayutsya only the red receptors.
Posted: Mon Aug 18, 2008 9:29
Алив wrote:why no standard points blue? Or is it there?
says Who?
No not bad, do not mess up
http://www.mindmachine.ru/viewtopic.php?t=1438&start=0
Posted: Thu Oct 02, 2008 19:12
by Евгений_
What points connector, can be connected directly to the computer, I understand that a mind machine is a normal player with a few sesijami in memory, you can do without it?
Posted: Fri Oct 03, 2008 8:43
by Guest
Evgeni
Of course you can. Mindxplorer + Cowon IAudio + UltraSone Pro.
Posted: Fri Oct 03, 2008 8:45
by Guest
Guest
Cowon IAudio F2 is a super player.
Posted: Sat Oct 04, 2008 16:09
Anonymous wrote:Evgeni
Yeah, and glasses from mindmachine that light is not prevented, and the wire can be cut, not to hang out.
Posted: Wed Oct 29, 2008 11:49
by Илья
Question: ColorTrack glasses you can use with your eyes open?
Posted: Wed Oct 29, 2008 15:12
Илья wrote:This question: ColorTrack glasses you can use with your eyes open?
Why?
Posted: Wed Oct 29, 2008 21:53
by Илья
The person is in a coma, eyes open.... I want to act on it mindmachine closed when sleeping.
Posted: Thu Oct 30, 2008 12:43
Илья wrote:a Person is in coma, eyes open.... I want to act on it mindmachine closed when sleeping.
Clear.
It should be aware that nobody is investigated and consequences are not predictable. What are the doctors - is there any chance the natural way?
In a coma for the visual analyzer is disabled, and there are vysokomolochnye Delta rhythms and may be present hypersynchronization alpha rhythm (unfavorable for the output forecast). At the same time, some studies report that the auditory analyzer in a coma continues to function. Therefore, it may be better to try the disk Explorer through headphones or closely spaced small speakers to start?
If you stop at light stimulation, it is necessary to write session 45 minutes, where the frequency start at the low and end at 30Hz.
Posted: Thu Oct 30, 2008 13:57
by Илья
How to write the session? throw off the link with the description pliz..
Posted: Thu Oct 30, 2008 14:24
Илья wrote:As to write the session? throw off the link with the description pliz..
To do this, read the instructions that came with the editor is possible
you download on this site (free).
Posted: Thu Oct 30, 2008 15:34
by Илья
thanks, will develop!
Posted: Wed Nov 12, 2008 22:03
by Евгений_
What points connector, you can connect them to the computer?
Posted: Wed Nov 12, 2008 22:25
by Андрей Кабанков
Евгений_ wrote:What points connector, you can connect them to the computer?
Points from Jack, like headphones.You can connect it to your sound card.But work nothing will
