Page 2 of 2
Posted: Wed Oct 21, 2009 1:42
by ворон
binarnye beats as all of them are noisy, the subject is interesting, and that's the problem, the action depends on many factors the result depends on the mental state of the person, his suggestibility and heaps of other factors. The same frequency may cause not expected behavior. Currently in our scientific gatherings such technologies are not taken seriously, while the most authoritative foreign publications (e.g., Scientific American, Alchohol) regularly cover this problem, a gray foreign professors write thick books.
Posted: Wed Nov 18, 2009 13:18
by ворон
here is the tested frequencies, as expected, pure business
Posted: Wed Nov 18, 2009 13:56
by Dimas
Raven
Puerile was like,what, what criteria were used,what frequencies??
Posted: Sat Nov 28, 2009 17:02
by Мистер Андерсон
ворон wrote:that tested the frequencies, as expected, pure business
Ze matrix khez Yu.....
by Мистер Андерсон
Dimas wrote:Raven
why feed the Troll?
Posted: Fri Apr 16, 2010 15:38
by Лимонка
Андрей Патрушев wrote:Anonymous wrote(a):
Andrei Patrushev wrote(a):
Pineapple wrote(a):
and you can substitute the player to use the computer? and if you can how to connect?
In extreme cases, you can... Cord included: with headphone output to the AUX input.
what cord and what is AUX?
Cord complete with two pins (like from headphones) on both sides. "AUX" is such bukovki over the desired slot. Confused
Yes, but now glasses not responding.
Posted: Thu May 13, 2010 1:31
by Guest
I have a Nova pro 100, there is generally no AUX. Tried to connect using ComputerName cord, this computer is does not "see" this device. Could you elaborate, please, how to connect the machine to the computer and listen to the CD?[/code]
Posted: Thu May 13, 2010 13:18
Anonymous wrote:Cord complete with two pins (like from headphones) on both sides. "AUX" is such bukovki over the desired slot.
Some masinag instead of "AUX" written "EXT".
Yes, the computer does not see this device.
To listen to the disc connect the output from the sound card to the input of machine (appropriate cable see above) and switch the disc play on the computer. Machine should be included. To music without a built-in audiostrobe glasses do not react (almost). Music to listen on the background of any session. The work of machine and session this music is not affected.
