Page 5 of 5
Re: Pillow Sleepsonic
Posted: Fri Feb 21, 2014 22:42
by Владислав Мадоль
Are there instructions. Are right, the sound is audible even with ear plugs (even clearer), the sound in my head. The effect of the rhythms may be even stronger than in the headphones. On the test track determined that the speakers are But are concerned about disk Explorer, there is particularly important part.
Posted: Fri Feb 21, 2014 22:44
Vladislav Madol
Yeah, it does, but on the contrary - is not fatal.
Posted: Fri Feb 21, 2014 22:59
by Владислав Мадоль
Partially widened, at first glance, the swap dynamics is not easy. If you say that the mismatch between channels is not fatal, it means leave as is or better to Tinker and change? Thanks for the replies.
Posted: Fri Feb 21, 2014 23:03
Vladislav Madol
Long wires something much different?
Check, if works for You (everyone is different), there is no need to bother...
Posted: Fri Feb 21, 2014 23:17
by Владислав Мадоль
You have to cut the meterial cushion to wire to get. Ie done efficiently)
Posted: Fri Feb 21, 2014 23:21
Vladislav Madol
Hmm, maybe You are on the side watching? There's usually a niche (gap) for the wires and cut anything not necessary. If another modification, it is just the foam of two halves...
